Question about HP Office Equipment & Supplies
Printer out of the blue started to print upside down. Information that should be at the top was printed at the bottom of page and bottom printed at top as well as the print being upside down
Was printing ok just before I changed yellow ink cartridge
futureloginn
  • 734 Answers
SOURCE: HP Photosmart 3200 All-In-One not printing yellow
Step1
If you're setting up the printer or changing the toner or ink cartridge for the first time, double-check the instructions to make sure that you installed the cartridge correctly and, for new printers, that you have removed all the pieces of cardboard or plastic packing material.
Step
Check to see whether paper is feeding from the paper tray. If it's not leaving the tray at all, try feeding a page manually (if that's an option) or using a different paper tray. Sometimes a problem with the tray can be traced to a broken spring or a piece of plastic.
Step
If paper is feeding from the tray but jamming in the printer, examine where the jam is occurring and then inspect the printer carefully to see if you can find what is causing the problem. A piece of paper, for instance, might be blocking the paper path.
Step
If paper is feeding through the printer but coming out blank, check to see whether the printer is out of toner or ink. A defective toner or ink cartridge could be the problem.
Posted on Dec 04, 2008
leroyal
  • 2120 Answers
SOURCE: new tri color ink cartridge will not print red
Probably bad, there's actually no way to check ink levels.
Posted on Jan 22, 2009
gwbm
  • 353 Answers
SOURCE: Epson Stylus C66 inkjet Printer does not print !
Have you tried a cleaning cycle? If not, try one. Now run a nozzle check using the status monitor (right click the little printer icon in the bottom right corner of the screen and select nozzle check). Is there any sign of ink on the paper. Try up to three cleaning cycles. If ink is now flowing, but not yet perfectly, don't carry out any more cleaning cycles. Just leave the printer for 24 hours (to allow any air in the print head to disperse). Then repeat the cleaning cycle/wait process. It may take a while to restore a perfect nozzle check print. If these actions produce no positive results, report back.
Posted on Feb 01, 2009
tstraub
SOURCE: Canon i960 printer won't print in blue
Your problem is the print head. You can buy one from Canon for about $95, or find them new from dealers on Ebay for $60 to $70. For a less expensive fix, try to remove the print head and clean it. (You don't need any tools, just remove the ink tanks and pull the print head forward and out. Over time, the receivers tend to get dry & crusted ink on them. Note that the inks used are fast drying inks to keep your pictures, etc. from smudging after you print them. Try not to use solvent. I use q-tips and hot water, then dry using another q-tip. If this does not work, there are commercial cleaning kits available for about $10. Short of that, your choice is to replace the print head or the printer itself. My i960 prints such good quality color prints and normal color printing, that I would fix it rather than replace the printer. I hope the easy cleaning does it for you!
Posted on Mar 07, 2009
gwbm
  • 353 Answers
SOURCE: only black and blue will print on test page; yellow and magenta does not. Ink was just replaced.
Did yellow and magenta print OK before the previous cartridges ran out? If so, it looks like your new cartridges are not working properly. Try another yellow and magenta cartridge - you can re-use the previous cartridges if they turn out not to be faulty. If new cartridges don't solve the problem, you can try soaking the print head, in case you have nozzles blocked with dried ink for some reason.
Turn the printer on, and as soon as the print head moves out of its parking position, pull the power cord out of the back, or turn the printer off at the mains. You may now carefully move the print head by hand over to the left hand side out of the way. Look inside the print head parking area on the right and you will see a small rubber cup that comes up to cover the print nozzles when the head is parked (to stop it drying out). Use a syringe or dropper to fill this cup with head cleaning fluid or distilled water. DO NOT USE TAP WATER. Carefully push the print head by hand fully into its parking position so that the cup full of fluid comes up over the print head. Do not turn the printer on at any stage in this process. Leave this for at least 24 hours, then turn the printer on and try a head clean/nozzle check again. If you get any magenta/yellow ink on the nozzle check, then there is hope! Repeat the head clean/nozzle check process 2 or 3 times, but not more. Leave for 24 hours for any air bubbles to disperse. If nothing, repeat the soak process once more. If still nothing, post a new comment detailing what you have done and the results.
Posted on May 05, 2009
Blue Streaks & "Shadow Prints" on everything?
Mam, try replacing the cyan (blue) image unit may have a bad cyan image unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 15, 2015 | Konica Minolta Magicolor 5450 Printer
Hi how do you print double sided please
This printer does not have a duplex unit and cannot print double sided prints automatically.
The only way to print double sided is to print page 1 and the insert the page back into the printer tray with the page upside down and then print page 2. Repeat this for the other pages.
You need to do a test print first to work out which way to insert the page upside down in the printer paper tray so the printed text is aligned correctly on both sides of the page.
Nov 29, 2010 | Canon PIXMA MP530 All-In-One InkJet...
Printer has been working fine. all of a sudden the paper started to load crooked and jammed. now it continues to do this...why?
Usually it's because something has fallen down the back where the paper goes. One person on here turned her printer upside down and shook it and a Bic pen fell out. I got one last week with a wood screw inside. sometimes I find push pins, candy or jewelry. If nothing comes out try looking inside with a light and small mirror.
Jan 25, 2010 | Lexmark X4650 InkJet Printer
My Hp PRINTER just started printing 1 page on to multiple pages ?
check paper size settings on both your pc and printer manu.
Sep 30, 2009 | HP Office Equipment & Supplies
Hl-4070cdw prints booklets with upside down pages
I had the same problem and finally figured it out.
When you select print and the print window comes up:
select Printing Preferences or Properties (depends on program you are using),
select the Advance tab,
select the icon that has 'A' and 'B' on two pages (near the top left),
select Booklet Printing. (then Okay and Okay/Print, depends on program)
In all honesty, I'm can't remember if this is what I selected to fix the problem, but the choice is on this page. Try this with each choice of "Flip on Left Edge" and then "Flip on Right Edge".
If neither works, unselect Booklet Printing and try "Flip on Top Edge" and if that doesn't work, try "Flip on Bottom Edge". Etc.
I know the solution is on this screen so experiment until you find it.
Good Luck!
Jul 26, 2009 | Brother HL-4070CDW Printer
Duplex Printer prints one side upside down
If it's the same as the Brother 4070 you go into printer proerties (press properties next to printer selector after sending a document to print).  Choose the advanced tab, on this tab near the top are five buttons with icons on, the second one shows two pages with A and B on, press this to access the duplex and binding options.  In there change from "flip on top edge" to "flip on left edge"
Jan 17, 2009 | Brother HL 5250DN Laser Printer
Biz hub 450
Change binding from auto to either left or top.
Jun 18, 2008 | Konica Minolta bizhub C450P Laser Printer
Duplex printing: 2nd page is upside down.
START PRINTERS & FAXES PRINTING PREFERANCES choose both the options - print on both sides - flip the page option apply ok close the printing preferances box try printing
Aug 18, 2007 | HP Photosmart 3310 Printer
Duplex printing problem
you will need to make sure that the printer software is set to align top-top or top-bottom. You will need to set this within the printer dialog set up.
Jun 14, 2007 | Adobe InDesign CS2 for Mac
13 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
