Question about Nordic Track NordicTrack Treadmill, A2550
A2350 doesn't start, just cycles through programs on display
Just set up our new A2350 treadmill but it will not start up. It just lights up and cycles through the programs. What can we do.The key seems to have no effect
  • 3 Answers
You are on demo mode.
Posted on Sep 02, 2009
This is just the store display mode it comes with - check the manual, it should tell you how to easily turn off the store display mode.
Posted on Jul 28, 2009
I have a Nordic Track A2350 treadmill and the display is blank. Anyone fix this yet?
If you wish to get some details; check the site linked here. Pull up older posts Nordic. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 10, 2016 | Nordic Track Exercise & Fitness
Keeps stopping. I turn off power and restart but it stops again after a few seconds. How can I reset it to quit stopping after a few seconds.
Hope the speed sensor have some problem may dust on it or the treadmill need lubrication. Most of the treadmill stop after some kilometres reading indicating that its time to lubricate it. After lubrication you have to reset the counter.
check the link bellow using the search tab find out details of NORDICTRACK A2350. and follow those instruction.
www.electro-medical.blogspot.com
Nov 01, 2015 | Nordic Track NordicTrack A2350 Pro...
Nordic track A2350 treadmill, I found this unit with lights blinking this afternoon, so I unplugged for 1hr and when plugged back in the only thing that happens is the red iFit logo comes on. What can I...
reset the treadmills, follow the steps and fix it.
God bless you
    • 1
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
    • 3
Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
    • 4
Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.move on to the next step.
    • 2
Locate the reset switch on the underside of the treadmill console. Usually the button
Oct 18, 2013 | Nordic Track NordicTrack COMMERCIAL 1750...
My a2350 treadmill just stopped working - console and motor stopped
plealse LUBE the deck belt + rollers bearing too . you must do it after 150 miles aprox.
2) adjust the REED switch see the diagram, clean it, test for open or faulty. Tight the connector very well.
Jan 25, 2013 | Nordic Track NordicTrack A2350 Pro...
Nordik track A2350 can't fit through door
see the video and proceed according.
God bless you
Jan 06, 2013 | Nordic Track NordicTrack A2350 Pro...
Fuse looks ok red light lit even without fuse no power to consol
1)Replace the batteries with full charges, with the same mark, do not mix another. with the same polarity
2) Clean the contacts cleaners very well
3) TIGHT THE spring contacts with long pliers for better contacts.
4) Adjust the REED swtich see the diagram, test for open or faulty, clean it, and tigh the connector very well.
5) TGITH the ribbon cables inside for keypds and tight lower connecer display vs lower board connector.
God bless you
Dec 13, 2012 | Nordic Track Nordictrack A2350 Treadmill...
Belt moves for split second then stops
1= Not rexactly, however you must LUBE the deck belt, this a problem because of lack of maintenance, probably a deck worn, this cause enough friction shut down the machine for protection electronic.
2)LUBE the rollers bearing.3)test the input voltage motor, if there are the motor need repair.4) measure the output voltage board, if there are NOT voltage, the board is faulty, see my personal TIPS, and see the block diagram. RUN the software calibration for diagnose, and troubleshooting.
God bless you
Jul 09, 2012 | Nordic Track NordicTrack A2350 Pro...
How do I turn it on? A2350
Make sure the power is plugged in then insert the red safety key into the front. If you are not receiveing power after that then check that it is a dedicated outlet, that is not a gfci outlet, and that the breaker is not flipped.
Aug 06, 2010 | Nordic Track NordicTrack A2350 Pro...
Nordic Track NordicTrack Treadmill, A2550 Logo
881 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Ross Metcalfe
Ross Metcalfe
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
