Question about Compaq Presario 700 470024-192 Notebook
Sony laptop speakers problem - Compaq Presario 700 470024-192 Notebook
IS SONY SPEAKER VGP SP1 INPUT CONNECTION DIFFERENT FROM VGP SP2 SPEAKER CONNECTION
There may be many different power supplies that will work for your speaker system, but they must comply with the following:
1. The output voltage of the power supply should be correct as what the speaker system requires. (seems like 12 V in your case)
2. The specified maximum current output of the power supply should always be a higher value than the Amperage spec of the speaker system.
3. The output wires or pins of the plug on the power supply should correspond to the (+) and (-) on the power input of the speaker system.
A multimeter will come in handy to determine a power supply's output voltage and polarity.
Jan 25, 2016 | Sony Computers & Internet
Sony laptop speaker not work
Amazon or newegg.com are the best places
May 26, 2013 | Computers & Internet
I am using Sony Vaio VPCEA24FM. I have facing some issue with the sound . My laptop's right speaker is not working. I have checked the volumne balance and even lowered the left speaker volume and kept...
Hi....Just check the sound with stereo headset.If it is working properly ,right speaker has to be replaced.If the situation persist same before,you may have to check the motherboard .
Aug 12, 2011 | Sony VAIO Notebook
Bose Companion 2 Speakers won't work with Sony Vio Laptop
You don't write which operating system you use, but generally you should be able to choose where the sound output goes in the Sound Properties in Control Panel.
If however Sony decided to put some special software that does the thinking for you, and directs the sound output via the HDMI when connected, then you have to dig deeper...
Oct 30, 2009 | Sony Audio Players & Recorders
Sound is not working on my Sony VAIO PCG 72DL laptop. Help!
First sound is stall or not stall look in device ma nager. if not stallit. and go on control panel and look speaker setting. speaker is not in mute? if you look three ting u can solve your problem. if not your hardwere/speaker is damage. thank (nepal)
Jun 28, 2009 | Sony VAIO Notebook
Sony speakers not working
Th problem seems to be that you need to go into your sound control options and make sure that the playback devices are for your internal speakers. When changing that you should unplug your external speakers. Let me know if this helps!
Jun 18, 2009 | Audio Players & Recorders
Sony speakers do not switch on
I think ur sound driver not properly installed plz reinstall again properly .
May 26, 2009 | Sony SRS-D2100 Computer Speakers
Laptop Speakers Dont Work
Start, control panel, sounds and audio devices. Check "volume" and check if to see if the speakers are "muted". If not, select "sound" the sound profile should be "windows default" if not change it by using the down arrow on the side. Try the "sounds" by clicking on one of them like "asterisk" then clicking on the "right" arrow beside the "browse". This should play the selected sound if the speakers are working.
May 12, 2009 | Sony VAIO Notebook
CMT-BX5BT SONY spkrs aren't pulling in music (via BT) from laptop
I had the same problem. Here's the fix:
Control panel- Hardware & Sounds- Manage Audio Devices (under Sound)- Select Bluetooth Stereo Audio as default (right click- default) and Enjoy!
Dec 31, 2008 | Sony CMT-BX5BT Shelf System
Compaq Presario 700 470024-192 Notebook Logo
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
