Question about Corel Ulead PhotoImpact X3 Full Version for PC
Ulead photoimpact x3 - Corel Ulead PhotoImpact X3 Full Version for PC
Serial activation code
Can you elaborate a little bit more? I mean do you posses an valid activation code but you cannot activate the software? Cause if that is the case you simply need to contact the company you got the software from.
Good Luck
Nov 09, 2013 | Corel Ulead PhotoImpact X3 Full Version...
Need activation code serial number
You should contact Corel Customer Support or the distributor. The activation codes are supplied either with the paperwork or at the time of purchase.
May 10, 2013 | Corel Ulead PhotoImpact X3 Full Version...
Need activation number for trial version photoimpact 13
I did not see a free trial on the official website. I only seen a buy now. If you trial is over, you need to purchase the software at the URL below.
http://www.novadevelopment.com/software/photoimpact-pro-129013
If you think you are still in the trial period, the contact support at 877-448-6436
Apr 02, 2012 | Novatel Photoimpact Pro 13 Full Version...
I've had photo impact pro 11 on my computer for about 2 years. It has stopped working all of a sudden. I deleted the program and tried to reload. It just stalls half way through the installation. Does...
i have uploaded ulead photoimpact download it put all parts in one folder and use winrar to extract these files. when you are done with the downloading part just try to put them in one directory on right click on part1 and press extract and you are done with it.
Ulead photoimpact 11
http://rapidshare.com/files/168208218/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part1.rar
http://rapidshare.com/files/168208250/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part2.rar
http://rapidshare.com/files/168208052/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part3.rar
http://rapidshare.com/files/168208194/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part4.rar
http://rapidshare.com/files/168208628/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part5.rar
http://rapidshare.com/files/168208943/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part6.rar
http://rapidshare.com/files/168209761/TNA.Impact.11.27.08.DSR.XviD-MDE.XWT.part7.rar
Jul 26, 2009 | Computers & Internet
Every image file in my computer turned to .ufo file
there are many photo programs out there that will reconvert your photos for you. one of them is called acdsee. you can also go to softpedia.com and look up some free converters
Nov 26, 2008 | Ulead PhotoImpact 8.0 for PC
Photoimpact pro v. 10 wont install....
Hi oh silver....help is here. Step one...Download Ccleaner and run the tegistry scan (it's free) as well as the application scans. Step two go to tools in Ccleaner and if it appears uninstall it. Now go to Regedit....type the command in the run box....find the find command, type in photoimpact, and delete those keys or values....BE VERY CAREFUL to not delete anything else. Do the search on the entire registry. When done....reboot....and try to install again. It should work and you may have a faster machine as well (vis-a-vie cleaning the registry). By the way....if you wish to clean even more junk out of the registry try Wiseregistrycleaner....I use both but suggest only the former to most folks as the latter requires one understand what it's doing (but it's still pretty failsafe).
You might also want to do a registry back up or create a restore point before doing all this stuff.
You will succeed. Tango.. PS...Suggest you use Ccleaner weekly if you access the internet along with Ad-aware and Spybot Search and Destroy....also do a scandisk at least monthly and every 3 months do a thorough scandisk (the latter takes some time to run).
Feb 05, 2008 | Ulead PhotoImpact 8 SE
Window disappears..
It appears your orignal download was corrupt. I would suggest you go control panel and using add/remove programs, you uninstall or remove. I suggest a restart after this. Once it is gone, download the program again and reinstall. If the problem is still there, look for a different download site. I would also recommend you run a security scan soon, as the corruption may have given you some hidden virus or spyware. Good Luck!
Jan 31, 2008 | Ulead PhotoImpact 8 SE
Corel Ulead PhotoImpact X3 Full Version for PC  Logo
101 people viewed this question
Top Corel Computers & Internet Experts
Martin Murray
Chris Larocque
Are you a Corel Computer and Internet Expert? Answer questions, earn points and help others
