Question about Panasonic Toughbook Computers & Internet
Forgot my password for my toughbook cf-31 - Toughbook Panasonic Computers & Internet
SOURCE: Install XP on Panasonic Toughbook CF-27 ?
sxcss
Posted on Apr 30, 2008
asish_shrm
  • 121 Answers
SOURCE: no sound cf 48
download Astra software...run it on your computer.....you will get information of all devices through this software.....check the chip set manufacturer and the number for the chip set do a google search for that particular audio driver chip set you will be good to go
Posted on Nov 10, 2008
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
  • 15 Answers
SOURCE: I have a panasonic toughbook CF-T5 which is
hi if its a BIOS password try taking the clock battery out for five minuites then replace restart the com and set time and date,if that fails try turning off the comp and turn it on at the sametime tap F8 REPEATEDLY ,it should start up in safemode if that works click on safemode their you can change the password,hope this helped
Posted on Mar 09, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
Panasonic toughbook cf-31 "plugged in, not charging"
Are you sure that you are using the authentic Panasonic Toughbook AC Adapter? The Panasonic Part Number is:CFAA5713AM
The correct Voltage and Amperage is: 15.6 volts and 7.05Amps.
When the power supply is 3Amps then the total watts is less than half, which is enough to power the computer but not enough to charge the battery pack. Good Luck.
From Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
May 07, 2014 | Panasonic Toughbook CF-31ATNAA1M 13.1 LED...
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    How do you obtain the hard drive serial numbers for CF-30 and CF-31
    Try this freeware program, SPECCY at: http://filehippo.com/search?q=speccy Install and start, look at the HARD DRIVE section. You will find useful info to ID your Laptop's hardware/software OS.
    Aug 24, 2013 | Panasonic Toughbook CF-29 Notebook
    My tough book 31 screen brocken
    You maybe able to get a replacement screen from this WEB site.
    LCD screens and Inverters www.lcdparts.net
    Dec 15, 2012 | Panasonic Toughbook Laptop 31 Cf-31jegax1m...
    Panasonic ToughBook CF-31 and VersaPad
    Probably a firmware/driver bug if anything, maybe there's an updated driver for the trackpad here
    Dec 07, 2012 | Computers & Internet
    Forgot password
    if your using a windows XP OS then press CTRL+ALT+DEL then a window will pop up then in the user feild enter "Administrator" and click ok fron this user you can change your password
    Aug 29, 2012 | Panasonic Toughbook CF-73 Notebook
    Forgot my password
    1. Start up into safe mode (press F8 at startup) 2. log in as 'administrator' 3. go into control panels, users, and clear the password on the account that you have a problem. 4. restart.
    May 25, 2010 | Panasonic Toughbook CF-27 Notebook
    Computers & Internet Logo
    35 people viewed this question
    Top Panasonic Computers & Internet Experts
    micky dee
    Computer Repairing
    Computer Repairing
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
