Question about Apple Computers & Internet
G5 fan cooling sensor problem - Apple Computers & Internet
    Top Expert:
  • Apple Master
  • 14,162 Answers
Posted on Feb 16, 2016
Cooling fan speed
It's not likely that you can adjust the fan speed directly. You might have to use the various power profiles in the BIOS - if this model even implemented them.
The fans are controlled by either sensors on the board or a Baseboard Management Controller - if installed.
It's not really something that you can control. They will ramp up under load and increasing temperatures. That's what they're designed to do.
If it's too loud then this is not for you.
Jan 17, 2014 | HP ProLiant ML150 G5 Server
High fan noise
This can be an issue with some dirt that are now on those cooling fan that you have that you will need to clean to avoid further damage.
Mar 14, 2013 | HP ProLiant ML370 G5 Server
Imac fan noise
Check for blockage under the screen(by your ram slots)
the fan runs to cool the ram and other things! if you have too little ram the comp over works, so get more ram??
Feb 11, 2013 | Apple iMac G5 Desktop
Hp proliant dl 180 g5 cooling fan issues fan given noise
I would power the server off. Blow it out with a can of air. Power it back up.. If it is still making a noise, you need to replace the fan.
Jul 27, 2012 | HP ProLiant DL180 G5 Server
09 Pontiac g5 over heats while sitting at idle cooling fans not working they come on with the ac which is normal and after you turn the ac off they will stay on until engine cools back down and they shut...
Try testing the fan switch,some models have a fan sw. and a coolant temp. sensor and some just use one or the other.The fan sw.should be in the side of the radiator either a single wire or two.Coolant temp.sensor should be located in the thermostat housing or real close.
Apr 29, 2012 | 2009 Pontiac G5
My IMAC G5 A1058 is shutting off from time to time
A good website that I have used in the past is www.applemacparts.com you can source what the part numbers are and prices usually in pounds sterling. Do not know your location but from the part number you may be able to source the part in your location. Hope this helps.
Jun 06, 2010 | Apple iMac G5 Desktop
PowerMac G5 Mac Desktop: It will not boot...
Is this a liquid cooled G5? What CPU is it? Need as much info as possible like what where you doing last time it turned on? Have you looked inside the case? Do you hear any clicking when the power cable is connected for the first time? A lot of the last G5's were liquid cooled and a lot have leaked in the past. This small leak eventually ruins the power supply and worse yet ruins the logicboard and CPUs. If you don't know if it is liquid cooled look for a warning stamp on the bottom near front by the CPU fans (inside the case). It states to shut off if liquid is viable (something to that effect). Most times the liquid cannot be seen as it drips into the power supply on the very bottom. I would take it to Apple and have them check it out.
May 17, 2010 | Apple Power Mac G5 Desktop
FANs running at full speed system locks up
Fans running at full speed means, the redundant fans start working. That means you have a problem with the cooling system. Check your air-conditioner at your data center.
Feb 19, 2010 | HP ProLiant DL580 G5 Base - Quad-Core Xeon...
Computers & Internet Logo
Top Apple Computers & Internet Experts
Paul Carew
Martin Buck
Martin Buck
Paul Bade
Are you an Apple Computer and Internet Expert? Answer questions, earn points and help others
