Question about Sport & Outdoor - Others
Fitness world treadmill model M1, showing error code 3
SOURCE: tredmill error code
Moat likely a problem with the motor control board. See treadmilldoctor.com
Posted on Nov 17, 2008
SOURCE: V-fit treadmill belt wont turn
call the threadmill cops. they will come and beat up that error
Posted on Nov 05, 2009
guru_fixya
  • 944 Answers
SOURCE: Vision Fitness T9450 Treadmill error code "E4."
E4 means
- Elevation parameters out of range
- Recalibrate it
If you want to calibrate it see the manual page no 5.
Click here to download the manual
post a comment for further assistance.
Thank you for using fixya have a nice day:-)
Posted on Sep 25, 2010
ercupa190
  • 12223 Answers
SOURCE: I have a new Athletes Fitness AF460 model treadmill that displays an E2 error code. Does anyone know how to fix this?
Dear Sir:
This is probably a 1) faulty speed sensor or the speed sensor is not plugged in properly.3) Its also possibly a faulty motor control board or lower board. 4) The error codes will differ between makes and models but could be e1.
attached diagram for adjust the speed sensor
2_16_2012_6_07_22_pm.gifsincerely. God bless you.
ernesto cuadra
managua, nicaragua. c.a
Posted on Feb 16, 2012
Testimonial: "We are replacing the motor control board which we hope will resolve the problem. Thanks"
ercupa190
  • 12223 Answers
SOURCE: error code 3
1) lube the deck belt
2) lube the rollers bearing
3) measure the voltage input motor, if there are the motor need repair
4) measure the output voltage board, for input voltage motor, if there are NOT the board is faulty.
see the block diagram.
God bless you
Posted on Jun 30, 2012
Er 1 shows up when I turn the treadmill on
Error 1 can mean lots of things. The best way to figure this out is to supply the make and model when asking for help. Er 1 is used in most major manufacturers treadmills. Using your model and serial number, you may be able to find the service manual with error codes at the following link. Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
Search Results
Nov 27, 2015 | Exercise & Fitness
The treadmill is showing error 2,what do i do/
Your treadmill manual should have a trouble shooting section with error codes and what they signify. If not contact the manufacturer for clarification of this code.
Aug 27, 2015 | Sole Fitness F63 Treadmill
Life gear error 3
error 3 means the waking belt starts moving without any command. Make sure that you are not moving the belt manually before the treadmill stars .
for more details check the link
electronics repair help LIFE FITNESS T3 T3i T5 T5i T7i TREADMILL ERROR...
Feb 08, 2014 | Life Fitness T3 Treadmill with Advanced...
How the error e02 on fit king treadmill be repaired
Dear sir,
I am having a treadmill of Fitking model no. W590 it is showing error code e02.
Kindly suggest what to do. I am eagerly waiting for ur response
Rgds
Yash Pal
Jul 15, 2013 | Exercise & Fitness
I have A Life fitness 9100 treadmill The display shows the message "maintenance notes wax over" how can I remove this error?the treadmill will not turn on HELPPP
see this steps and fix it. .Of course you must read your instr. manual or download from www. iconservice.com
When the treadmill is not in use, press the "Stop," "ENTER" and "QUICK START" buttons in rapid succession. The "RESET" button can also be used, in place of the "Stop" button.
  • 2 Press the "ENTER" button three times to access the treadmill's error log.
  • 3 Press the up or down arrows to scroll through the error codes, if necessary for club or personal logging purposes.
  • 4 To view the treadmill's odometer reading when a particular error code was elicited, press "SELECT" while a particular error code is displayed.
  • 5 To clear the error log, press "QUICKSTART" for a minimum of four seconds while viewing the list. Prompts will appear on the display and let you know when the log has been deleted.
  • Oct 17, 2012 | Life Fitness Lifestride 9100 HRT...
    My Exerpeutic TF1000 treadmill shows a E2 error, motor will not start.
    see this steps and fix it.God bless you
    This is probably a 1( faulty speed sensor, adjust it , clean it and tigh the plug very well see the diagram attached. 2( test the input voltage motor, if there are the motor need repair 3( test the output voltage board, for input voltage motor, if there are NOT the board is faulty see the block diagram . The error codes will differ between makes and models but could be e1. or e2
    Run the software calibration for easy diagnostic, troubleshooting, and fix it.
    God bless you
    Oct 01, 2012 | Ironman Exerpeutic TF1000 Walk to Fitness...
    Z8 is showing L5 cant seam to fix this
    Dear Sir:
    I will try to help you, please use the steps with patience and carefully: You must need some basics tools; Included Dvom (Digital Voltemeter).
    Instructions Things You'll Need for to Reset Code:
    • treadmill (all models applicable)
    1.
      • 1
      • 2
      • 3
      • 4
    Oct 19, 2011 | Spirit Fitness Z8 Treadmill
    York t500 treadmill model no:LQ6010 showing err07 when turned on
    Error 7 is a Safety Key Error..
    that's the red magnetic circular thingy on the console.
    Simply secure the safety key in place and try it again
    Jan 19, 2009 | York Barbell Home Use Fold-Up Treadmill
    Sport & Outdoor - Others Logo
    22 people viewed this question
    Top Sport & Outdoor - Others Experts
    Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
