Question about Whirlpool GFE461LVS Stainless Steel Electric Range
Whirlpool GFE461LVS oven error message - Whirlpool GFE461LVS Stainless Steel Electric Range
My GFE461LVS Whirlpool Electric Range overshoots temperature.
William muller, We would like to inquire further about your post with you. Please respond back to this email address Whirlpool_Reviews@Whirlpool.com with your name, user id (William muller), phone number, street address, zip code, reviewer name, model & serial number, and date of purchase on the appliance.
Apr 15, 2017 | Whirlpool Kitchen Ranges
Error message on Whirlpool Range Oven Model GFE461LVS Feature Not Available
The Feature not available message indicates that the range's internal computer (electronic control) has found a problem with the range. You need to access the diagnostic program to determine the fault and try to reset it. Press Cancel, Cancel (a second time) and then Start. You should see Test On. Then press Temp > Time > + . Press + again to move through the various test and information sections. Eventually you should get a list of Faults (F followed by a number or F number E number). Record these. After you press + again, the diagnostic program should enter an "Auto Test". Press Cancel to exit the test. Then press Start Time to clear the fault codes. Then try to use your oven.
Some faults mean that the oven can't be used until you fix the problem. These can be problems with the ERC (electronic range control), high temperature limit sensor, or wiring harness. Some of the parts for your range are available here: http://www.appliancepartspros.com/search.aspx?model=gfe461lvs . Without the error code, I can't pin down your issue. So please add a comment with that information after you try the diagnostic.
If your range is under warranty, contact Whirlpool for a service call.
I hope this helps.
May 10, 2016 | Whirlpool GFE461LV Electric Range
I have a electric whirlpool self cleaning oven, after the cleaning process the door is still locked. It's beeping and error message E1 F5
Assuming the door is still locked after cooling, then either the door switch is bad or the wiring from the control panel to the door switch has a problem. First disconnect the power from the oven. Then check the wiring and connectors (from the control to the switch and back). If those are fine, you need to replace the door switch. After replacing the switch or fixing any bad wiring/connections, reconnect the oven to power. Press and hold any key on the panel for at least one minute to clear the error. You should see F2 on the LCD panel. Press Cancel to clear the error then check to see if any new error (or the old one) message occurs. (Usually a new error message will come up within a minute.)
Which model Whirlpool oven do you have? If you add a comment with the model number, I may be able to provide a parts list and diagram of the unit.
I hope this helps.
Nov 22, 2011 | Whirlpool Kitchen Ranges
Whirlpool Gold GFE461LVS electric range, oven gets very, very hot. Only two years old.
Most likely a defective temperature sensor.
Disconnect the temp sensor and use a volt meter to check the ohm resistance.It should be 1100 plus or minus 50 ohms. If more or less replace the sensor.
If the sensor is OK,replace the electronic control.
Jun 15, 2011 | Kitchen Ranges
My RBD275PDB14 Whirlpool double electric oven started displaying an E6 F2 error message and intermitently shutting down after a power outage. I replaced the control panel but it is still displaying the...
F2 - E6 Cancel key drive line open 1. Check keypad connector for firm connection (keypad connects to control board).
2. Press CANCEL. If error code returns after 60 seconds, replace keypad (also called touch pad or membrane switch). Some models incorporate keypad in to control board as one unit. In this case, replace control board (also called ERC or clock).
Nov 03, 2010 | Whirlpool RBD245PDS Electric Double Oven
ERROR MESSAGE F 08 SHOWING ON WHIRLPOOL OVEN AK2456/1X
Error code F08 is indicating that the heater relay is not being activated.
You need to check all the connections on the module, the pressure switch, and the heater element.
Jul 17, 2010 | Whirlpool AKZ159IX Oven
Whirlpool double ovens error message e6 f2
good day,
hope this link below will solve your problem.
ovens
Mar 26, 2010 | Whirlpool RBD245PDS Electric Double Oven
F2 error on Whirlpool RBD245PD Double oven
F2 is a bad temperature sensor.
The no lights function is a bad clock control.
Jan 10, 2010 | Whirlpool RBD245PD Electric Double Oven
Microwave error message
unplug your unit for 1 minute and plug it back again, you'll be surprised ...it will work again cheers
Nov 26, 2008 | Whirlpool GH5184XPQ Microwave Oven
Whirlpool GFE461LVS Stainless Steel Electric Range Logo
90 people viewed this question
Top Whirlpool Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Are you a Whirlpool Kitchen Range Expert? Answer questions, earn points and help others
