Question about General Electric Hardware & Accessories
Program a wall switch timer 5325-71L3 - General Electric Hardware & Accessories
2 Suggested Answers
SOURCE: I HAVE UTILITECH 7-DAY DIGITAL IN WALL TIMER.
Great! I just bought one and am typing the directions from a blown-up scan so I can read them. This us the 3rd timer that doean't seem to want to be programmed and I am forced to operate manually!
Posted on Mar 14, 2010
I have a Intermatic self-adjusting wall switch timer and I can't program it even though I have followed the instructions 3 times.
Program 1 is ON, and program 2 is OFF, 3 is ON, and 4 is OFF, etc
Copy following link for EZ step-by-step programming for ST01C timer:
http://waterheatertimer.org/ST01C-program.html
Jun 05, 2012 | Intermatic Inc. ST01C Digital In-Wall...
I have a one outlet utilitech timer and forgot how to set it ....help
Utilitec makes 2 different plug-in timers.
Utilitec 0155671 is about size of baseball and has 5 buttons and two outlets. Programming is shown on link below.
http://waterheatertimer.org/How-to-program-Utilitec-0155671.html
Utilitec 0144506 timer is small and rectangular with 5 buttons and slide switch located on top of timer. This timer can turn lights on-off once a day and has 1 outlet. 0144506 Instructions are given in steps shown below.
Also see:
http://waterheatertimer.org/How-to-program-Utilitec-0144506.html
Steps:
-Plug timer into wall for 1 hour until rechargeable battery is charged and display shows.
-If battery will not charge, then check electricity to wall outlet, if electricity is good and battery will not charge, then timer is no good.
-Lamp has to be turned on for timer to work. Check bulb if timer stops working.
-Unplug timer to set program.
-Press reset button with paper clip to remove any programming.
-Slide switch on top of timer to 'Timer'
1) Set current time
Hold down Time button
Press HOUR until current hour am-pm shows in display.
Press MIN button until current minute shows
Since this is a one-day repeat timer, no day program is available.
2) Program ON > this is when you want lamp to turn ON
Hold down ON button.
Press HOUR until ON hour with am-pm displays.
Press MIN until ON minute displays.
2) Program OFF > this is when you want lamp to turn OFF
Hold down OFF button.
Press HOUR until OFF hour with am-pm displays.
Press MIN until OFF minute displays.
3) Set timer to operate
Make sure slide-switch on top of timer is set to 'Timer' to run program
Plug lamp into timer, and then plug timer into wall outlet
For manual override, move slide-switch to 'On' and light will stay ON
Nov 27, 2010 | Day-Timer Hardware & Accessories
How do you set this timer
http://www.intermatic.com/products/timers/in-wall%20timers/24-hour%20mechanical%20time%20switches.aspx
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/e1020%20-%20english.ashx
Timer shown is E1020 or E1010
This timer wires into a wall box
Grasp time dial firmly and pull until it comes free from timer.
Remove all silver ON trippers and brass OFF tripper using pencil or paper clip
Program the timer by inserting trippers
The minimum set time for this timer is 1/2 hour
OFF trippers should be spaced at least 2 hours apart from another OFF
ON trippers should be spaced at least 2 hours apart from another ON
Push time dial back onto timer
Current time lines up with time line located at top of timer dial
Next to the time line is the manual override.
Use manual override to reverse the timer program, so if lights are OFF, manual override will turn them ON.
Oct 28, 2010 | Heavy Duty Intermatic Wall Switch Timer...
I want to reprogram my timer to a new on time,and off time. do i have to clear the existing program,and start from scratch? if yes, do i use 6a an on/off program at specific times. next question: ...
To reprogram times, it might be easier to clear all programs. Read the manual. Sometimes you have to read it several times. Or scan it into computer so you can see print larger. Or go to manufacturer website and download manual. Some manuals are impossible to find, some have unclear instructions.
For programming help. Post brand and model number of timer so product is identified. Some products have nearly identical numbers but are very different. It's a zoo of products. So be specific.
Timers generally repeat 1 week or 1 day. Do you have a in-wall timer? Or box-type timer
Intermatic in-wall EJ500, ST01C, EI600 offer Daylight Savings & Dusk to Dawn operations. EI600 has 5 year warranty. Other two have 1 year warranty.
http://www.intermatic.com/products/timers/in-wall%20timers/electronic%207-day%20astro%20time%20switches.aspx
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/in-wall%20timers.aspx
Click product number to see manual. Download manual to your computer> go to File at top of browser, click 'save' -or- click 'print'
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;}
If you have a boxtype timer, Intermatic makes timer with photoelectric sensor
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
Aug 14, 2010 | Intermatic Inc. EJ500C Digital Wall Switch...
Hardware & Accessories Logo
139 people viewed this question
Top General Electric Hardware & Accessories Experts
jdthefixer
pawnpower
Are you a General Electric Hardware and Accessory Expert? Answer questions, earn points and help others
