Question about Vulcan 36" WIDE ELECTRIC(Click Here): WALL MOUNT 36" Kitchen Hood
My zephyr savona vent hood makes humming noise when turned on
Zephyr savona vent hood will not work. it makes a humming noise when it is turned on
Savona zephyr light switch is burn out.How do i replaced it.
Did you ever find a source for the switch assembly? Janderson@andersonpangia.com
Feb 19, 2011 | Zephyr Savona ZSV-E30AS Stainless Steel...
My Zephyr hood model zto-m79s lights don't work. The unit was installed in 2007. Sometimes they sputter, flashing briefly, then nothing. Do I need a service call or can I fix it myself? Nancy
Try taking out the bulbs and wiping with a clean dry cloth. Sometimes when bulbs get hot the connection loosens, when you screw them back in do not over tighten.
Dec 13, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona range hood quit work on low spds-hi still works
Motor Speed may not be working and this means the either the motor is bad or switch is bad for motor Low Med Hi Switch
May 27, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Range hood is making noies
use a good 3 in 1 oil. Don't use WD-40 it will only clean it then dry out the bearing. the problem will be worse than when you started.
Feb 06, 2009 | Zephyr Savona ZSV-E30AS Stainless Steel...
Light blub burnt out
The easiest way to remove the light bulb is to wear a rubber glove, use your palm to press against the bulb, and turn counter-clockwise.
The suction created by the rubber glove should allow you to remove the light bulb easily.
Jan 12, 2009 | Zephyr Savona ZSA-M90S Kitchen Hood
Need to change lightbulb of Zephyr Savona Zsa-m90s
I'm not sure if my Savona is the same one, but on mine, just remove the filter and you can see the base of the light bulb up above the fan base. You can see where the bulb screws into the fixture. Grab the ceramic portion of the bulb, and turn that part. You may want to steady the socket with your other hand because it is very flimsy.
Dec 12, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr Savona Range Hood only speed 3 works
had same problem (w/in a few months)
switch assembly poor design
thay sent a replacement (i put it in)
seen other complants
Jul 15, 2008 | Kitchen Ranges
Push Button Switched
zepher sent replacement sritch.
had to wait a while -parts from italy (heh)
so far ok
design is poor
Feb 29, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
How to install the ventless Zephyr ZSA-M90AS
Here is the link that has the rough in you need pls review me. Thanks
http://www.zephyronline.com/docs/brand_essentials/products/manuals/savonaa_manual.pdf
Jan 20, 2008 | Zephyr Savona ZSA-M90S Kitchen Hood
Zephyr ZMI-M90S stopped working
The company doesn't list such a part. Probably, you have a bad connection in the unit. With the power off, remove the motor housing. Find the connection box and fix up the connections.
Nov 20, 2007 | Zephyr Savona ZSA-M90S Kitchen Hood
Kitchen Ranges Logo
82 people viewed this question
Top Vulcan Kitchen Ranges Experts
Oloyede Monsuru
Dan Webster
Dan Webster
Are you a Vulcan Kitchen Range Expert? Answer questions, earn points and help others
