Question about EliteGroup ECS P4IBMS Socket 478pins Motherboard (MBECSP4IBMS)
ECS P4IBMS Motherboard CPU Voltage Jumper Settings
There are five cpu voltage jumpers on my ECS P4IBMS motherboard (VID0-VID4). I'm upgrading from a 1.75 V cpu to a 1.525 V cpu and am trying to find out what the jumper settings should be. The manual doesn't discuss these five jumpers. Anyone have the details? Thanks.
  • 2,567 Answers
I don't believe that there is a P4 motherboard that needs jumper setting to specify the CPU voltage. This used to be common for Pentium & Pentium II motherboards, & some Pentium III motherboards. But I have never seen a Pentium 4 motherboard that require this kind of setting.
Besides, I checked the motherboard's manual & I saw that there is a sub-menu in BIOS labelled "Frequency/Voltage Control". This should be the place where the CPU voltage should be set, & on most motherboards, CPU voltage & frequency are automatically detected.
Posted on Jul 09, 2009
WHAT IS P4IBMS SET DEAD SOLUTION?
All I can find is that ECS P4IBMS is a motherboard. 'Dead' normally means it's not working!
May 05, 2014 | Computers & Internet
How to adjust jumper settings of ecs mainboard mcp61m-m3
onbly jumpers on that board should be for bios cmos clear. the cpu setting snd such are to be adjusted inside the bios setup utility.
Mar 09, 2011 | EliteGroup ECS MCP61MM3 (V10) AM3 NVIDIA...
Currently i am using desktop computer celeron 1.7 Ghz which i am thinking to replaced by a P4(2.8 or 3.06) processor on the same motherboard. Apparently there is a voltage difference between 2...
If you motherboard will accept the P4 speed you want, you will NOT need to change anything. The board will automatically adjust the voltage when it sense the new cpu. I do recommend you upgrade your power supply that will support the voltage requirement. Most time when vendors build a pc with a low voltage cpu they usually use low voltage power supplies.
Check your motherboard specs, inparticular the voltage requirments and processor that are compatiable with your model board.
Good Luck.
C2Solutions
Jan 22, 2011 | Foxconn 661FX7MF-S Motherboard
I need jumper settings for ecs KT600-a motherboarb
Here are the settings for setting the CPU freq. I am not sure how the formatting will come out once I post this.
JP8 JP9 CPU Frequency
Short 1-2 Short 1-2 100MHz
Short 2-3 Short 1-2 133MHz
Short 2-3 Short 2-3 166 MHz
Short 1-2 Short 2-3 200 MHz
If that doesn't come through good enough, you can get all the jumper settings from the manual which you can download from:
ECS KT600-A Support
(The download is in zip format.)
Thanks for using Fixya.
Dec 03, 2009 | EliteGroup ECS MB KT600-A VIAKT600 SocketA...
When cpu switch on processor & power supply fan runs, no display
if you have swolen capacitors you are on the road the failure
buy a new mb and save yourself some time.
hope this helps
Dec 30, 2008 | EliteGroup P4IBMS Motherboard
CPU upgrade not showing correctly
Check the installation instructions; it may be necessary to change some small jumpers on the board if it is not designed to auto-detect the processor.
If you don't have the info on the board, check with Safemanuals.com or retrevo.com or Elite's website for a download.
Sep 21, 2008 | EliteGroup ECS P4VMM2 Supports Intel...
Processor upgrade from 1.6 to 2.4
Hi zmoonz,
you must be missing something. Please go over this Intel link:
http://www.intel.com/support/motherboards/desktop/d850mv/sb/CS-009910.htm
Double check your board revision. Instruction / location for this is on the site above. Even though you have the correct revision no# the Pent 4, 2.4GHz CPU can only run with the correct revision (AA numbers) listed.
There are no jumpers on the Intel D850MV MB to help increase the CPU speed nor bios menu to help. Enter the bios. Open Main. This bios does not allow any CPU options.
Mike
Aug 20, 2008 | Intel D850MV Motherboard
Soltek SL-86SPE-L CPU upgrade issues
Maximum you may go upto 2.4 GHZ. [p4]. Not dula core etc.
Best Regards
Rafique
Feb 17, 2008 | Soltek SL-86SPE2 Motherboard
Possible cpu upgrades for p4vmm2 motherboard
I see that you have already had this answered at Techspot.com They were right when they answered you, you need to check your MB manual to see if it is capable of upgrading to the CPU that you want to use, not all MB support all CPU's just because they both have 478 pins. I looked on the ASUS website and they don't even list your MB model on there.
Mar 20, 2007 | Pioneer ECS P4VMM2 V3.2A P4(478)/FSB...
EliteGroup ECS P4IBMS Socket 478pins Motherboard (MBECSP4IBMS) Logo
533 people viewed this question
Top EliteGroup Computers & Internet Experts
David
David
Alun Cox
Iqbal Husain
Iqbal Husain
Are you an EliteGroup Computer and Internet Expert? Answer questions, earn points and help others
