Question about Panasonic PT-LB20SU Multimedia Projector
Pt-lb 20su service manual
Lenses fall off housing. need to find proper order
3 Suggested Answers
SOURCE: Service manual dealer
purchased from paradise manuals, I can try to email it to you if you still need. my email address is fpeltier@aol.com
Posted on Mar 25, 2008
borg70
  • 14 Answers
SOURCE: Need PT-51HX41E Service Manual
You can download service manual from elektrotanya:
http://elektrotanya.podzone.net/?q=showresult&megnev=panasonic&megnev2=PT-51HX&kategoria=&kat2=schematics
Posted on May 01, 2009
I need to have a fuse box diagram for a 2006 PT Cruiser. I don't see it in the owners manual. Thank you.
All of the electrical current distributed throughout this vehicle is directed through the standard equipment Totally Integrated Power Module (TIPM). The molded plastic TIPM housing is located in the left front corner of the engine compartment, just behind the air cleaner housing and the battery. The TIPM housing has a molded plastic cover. The TIPM cover is easily removed for service access and has a convenient fuse and relay layout label affixed to the inside surface of the cover to ensure proper component identification.
Feb 08, 2011 | Chrysler PT Cruiser Cars & Trucks
How to replace headlight assembly on a 2007 gmc sierra 1500 sle
try t
  1. Remove the radiator grille. Refer to Radiator Grille Replacement.
  2. Loosen only, do not remove, the lower outside hidden headlamp bolt (2).
  3. Pull the lamp assembly slightly forward to access the electrical connection.
  4. Disconnect the forward lamp harness main electrical connector from the headlamp harness.
Headlamp Screws (Qty: 2)
Notice: Refer to Fastener Notice in the Preface section.
Tighten
Tighten the screws to 6 N·m (53 lb in)
Headlamp Screw (Hidden)
Tighten
Headlamp Housing Support
Tip
Depress the housing support tab with a flat-bladed tool downward in order to release the headlamp assembly from the support.
Tighten
Tighten
Tip
his.
Nov 11, 2010 | 2007 GMC Sierra 1500
My panasonic hdtv seems to have developed a yellowish tint to the screen
Sounds like the polarizing film is burnt on one of the three colored lenses that are located next to the projector itself. In order to fix this this it is necessary to remove the ballast and projector units, then disassemble the projector housing to expose the lenses. there are green, blue and vermillion (reddish) lenses. the vermillion lense is the one that causes the yellow tint after it has been damaged.
searching for the pt-43lc14-k service manual (the 'k' version is the more complete one) will provide you with daigrams and such.
I am currently undergoing this repair myself, thus far we have disassembled the television and are waiting on new vermillion polarizing film in order to complete the reapir. Good Luck, it isn't too difficult. Just take lots of digital camera pics (for screw location and sizing) and you should be fine.
May 31, 2010 | Panasonic PT-43LC14 43" Rear Projection...
User manual & info to order lenses
You can find a manual at this web site:
Look down the page for your telescope model:
http://www.opticsplanet.net/bushnell-warranty.html
Dec 10, 2009 | Bushnell NorthStar 78-8846 (675 x 114mm)...
I need a radio wiring diagram for a 2004 pt cruiser
There is a sticker behind of the radio, but if you don't have radio, here some help: B+ 1 PK/LB B+ 12 PK/LB Panel lamps 3 OR IGN 2 RD/WT PCI 14 VT/YL GND 11,22 BK LeftRear+ 18 RP/YL LeftRear- 19 BR/LB RightRear+ 21 DB/WT RightRear- 20 DB/BK LeftFront- 10 DG LeftFront+ 9 BR/DB RightFront+ 7 VT RightFront- 8 DB/RD
Jan 04, 2009 | 2004 Chrysler PT Cruiser
Do i have a problem with my lense housing
YES there is! Its called coolant Fluid/ some call it Projection TV Fluid cost 8oz 7.99 and 16oz bottle 12.99 per bottle plus shiping You can order it at http://www.electronix.com or call 1-800-223-3205
Dec 11, 2008 | Panasonic PT-51HX41 51" Rear Projection...
Clean filter
In order to clean the air filters properly. The projection unit must be removed from the rear. This unit is very expensive! I would recommend calling for service. But you can find the service manual online for free if you feel daring.
Oct 18, 2008 | Panasonic PT-52LCX65 44" HDTV
Mar 19, 2008 | Panasonic PT-53TW53 53" Rear Projection...
Panasonic PT-LB20SU Multimedia Projector Logo
26 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
CheckitRight
CheckitRight
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
