How do i clear a fault code 19-506-00 on a xerox 7785 printer
  • 990 Answers
SOURCE: Xerox WC Pro 423 fault code U4-6 & U4-4
Hello sir; The U-4 code all are fuser problem, there haave noway to fix it the only way is replace the fuser unit
Posted on Aug 23, 2009
  • 53 Answers
SOURCE: xerox 5225 fault code 010-320
that is a fuser overheat code suggest you have a techintion repair or replace the fuser
Posted on Jan 18, 2010
SOURCE: xerox 242 fault code 042-326
foult code 093-317
Posted on Apr 27, 2010
  • 241 Answers
SOURCE: Fault 127-210. Printer functional but can not connect to command Workstation.
i think it is the problem of Fiery installation
recently i am gone through the same
but i got some other code
u can try by installing fiery
Posted on Oct 08, 2010
SOURCE: Xerox Docucolor 260 Fault Code - 042-326
Posted on Mar 29, 2011
What does error code 99,013.00:49569 mean xerox 8570 color cube?
Process Drive Fault"
Do you have another kit you can take from another printer.
Switch the printer off.
Swap out the kit with the one from the other printer.
Turn it back on. If it clears the fault when the printer is ready put back the new kit
Aug 14, 2015 | Xerox Office Equipment & Supplies
How do I clear the fault codes on a xerox 3535 printer?
http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Feb 12, 2015 | Xerox DocuColor 3535 Copier
Xerox phaser 8500 error code 09, 038, 46:4597
Ink count sensor flags are stuck after melting 2.5 ink sticks. The following codes are recorded: 9,03x.41, where x= 5 for cyan, 6 for magenta, 7 for yellow, and 8 for black. (Your error indicates black ink loader failure)
Features on the bottom of genuine Xerox ink sticks actuate the Ink Out Sensor located at the forward end of each ink channel of the Ink Loader. The sensor indicates the passage of ink to provide a count of ink consumption.
Damaged or non-genuine ink sticks may not reliably actuate the sensors. This can lead to false Ink Out messages as well as Ink Stick count faults. Using 8400 model ink in a 8500/8550/8560 models will also cause 9,03x.4x ink stick count faults.
Ink Loader will need replaced and then diagnostics entered to run "Clear ISC Fault" test to clear the error.
IIf
Aug 11, 2013 | Xerox Phaser 8500/DN Printer
ERROR 09,038,46:11950
Fault codes associated when ink count flags are stuck after melting 2.5 ink sticks.(Black ink)
1. Are the ink sticks all Xerox ink? Are they the correct ink sticks for the printer model?
Yes)Go to Step 2.
No)Advise customer. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
2. Manually verify that the ink stick is able to advance in the ink loader chute. Check for broken or wrong type ink sticks.
Yes)Go to Step 3.
No) Remove any blockage and/or replace the ink stick. Run clear ISC Fault test to clear the error. The clear ISC fault menu item is located in the internal diagnostics function menu.
3.Run the appropriate Ink Melt [1, 2, 3, 4]
Heater test.
1 = Yellow
2 = Cyan
3 = Magenta
4 = Black
Did the test pass?
Yes)Replace the printhead.
No) Replace the ink loader assembly. Run clear ISC fault test to clear the error. The clear ISC Fault menu item is located in the internal diagnostics function menu. This must be performed following an ink loader replacement.
Sep 02, 2011 | Xerox Phaser 8500/DN Printer
Print error 09, 005, 40:5069 how do i fix this?
Hi
This error in Xerox 8560 printer occurs when Cyan ink melt heater is on but the ink is not dripping. To troubleshoot this issue please make sure that you are using genuine Xerox ink. If yes then run Clear ISC Fault test to clear the error. The Clear ISC Fault is located in the Internal Diagnostics Function menu.
Also check for broken or wrong type of ink sticks. After this try clearing the fault by running Clear ISC Fault option. If the sticks are also fine then run the appropriate Ink Melt (1,2,3,4) Heater test. If the test fails then there is an issue with the print head.
Daniel Scott
Jun 08, 2010 | Xerox Phaser 8560MFP Laser Printer
IT WONT WORK
here is how to print the fault codes.
http://www.office.xerox.com/support/dctips/dc99cc42.pdf
Not sure if it tells you how to clear or to call Xerox with the codes and know what is going on.
Good luck
Sep 17, 2008 | Xerox DC470ST Color Copier
Xerox xd100
See this thread, someone with a similar problem to you:
http://www.fixyourownprinter.com/forums/laser/24105
I'll summarize the solution:
The "software" H4 problem is quite common that Xerox has a resolution on its website
Solution: Perform a Fault Reset 14
Performing a Fault Reset 14 will reset your WorkCentre and will help to clear error codes.
1. Find the pink Clear button on the Control Panel of the WorkCentre.
2. Find the button below the word Auto.
3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto]
NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
5. Press the green [Start] button.
6. Press the pink [Clear] button two times.
7. The WorkCentre should now warm up and come to ready.
8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Feb 08, 2008 | Xerox WorkCentre XD100 All-In-One Laser...
Xerox Workcentre Pro 215
This should resolve that fault code
NOTE: Some Status codes will not clear even though the problem has been fixed. Status codes that will not clear must be manually reset using the 'Fault Reset 14 Procedure'.
  1. Locate the [C] (Clear) button on the Control Panel, at the far right.
  2. Locate the Image Quality button, below the Auto on the Control Panel, toward the left side.
  3. Press the buttons in the following sequence within 4 seconds. Press [C] (Clear), press [Image Quality], press [C] (Clear) again, press [Image Quality] again.
  4. The error code should disappear. If the Status code does not clear, repeat step 3 until the status code clears; but no more than five times.
  5. Use the [10] and [1] buttons to enter 14 on the Display Screen, as if you were to make 14 copies.
  6. Press the [Start] button. The machine should be ready to use.
  7. Make a copy, to check that the machine is working properly
Jan 24, 2008 | Xerox WorkCentre PRO-215 All-In-One Laser...
983 people viewed this question
k24674
