Question about Indesit Kitchen Ranges
Hi260 Power to it,motor buzzing no fan running
BUZZING NOISE
Is this noise a motor buzzing noise? If motor has power but the start circuit is not energized, then the power through the run winding cannot start the motor and may make a buzzing. Need to address the type of buzzing and if the motor, then check motor circuit.
Jan 08, 2014 | Hoover Dryers
GE Microwave (JVM1860CD001) control board buzzes.
see this causes and fix it. God bless you
Magnetron If the microwave is loud or noisy only when cooking, the magnetron tube might be defective. The magnetron uses high voltage, high current DC power to generate the microwave frequency that cooks the food. Under normal circumstances the magnetron is nearly silent. However if it is damaged or nearly burned out it can begin emitting high pitched or growling noises. It's not normally dangerous to use a microwave oven when it makes these noises, but they are an indication that the magnetron is almost dead and will need to be replaced.
Exhaust Fan Motor If the microwave is loud when running the fan motor might be
Stirrer Motor If the microwave is loud or noisy the stirrer motor might be worn out. The stirrer is a metal blade which slowly turns around, deflecting the microwave energy in a random pattern inside the microwave oven. As the motor nears the end of its useful life it begins to make grinding noises. The microwave will not heat food evenly without this stirrer, the motor should be replaced.
Turntable Motor If the microwave is loud or noisy the turntable motor might be worn out. This is a common problem and relatively easy to replace.
Oct 10, 2012 | GE Microwave Ovens
Fan not working on outside AC unit
The buzzing noise is probably the fan motor. Is the compressor running? First make sure that there are no tripped breakers. After that kill the power and check the capacitor with a multimeter. If that checks good then check the fan motor windings with the multimeter. Let me know if you have any questions.
May 26, 2010 | Intertherm P3RA-060K Air Conditioner
There is a buzzing noise coming from the air con unit
if everything is running may just be contactor,if compressor is running not fan turn it off call service tech out(Fan motor bad)if fan is running but no compressor turn it off call service
Jan 06, 2010 | Mitsubishi Heating & Cooling
GE AGL05 Air Conditioner Problem
Try the fan only setting. If it still buzzes, that would mean a fan issue. An object obstructing the fan, or a bad fan motor. If it runs on fan only, but buzzes on a cooling setting, that would indicate a compressor issue.
Aug 12, 2009 | GE AGL05 Air Conditioner
Have a Ruud Achiever Model number UAKA-037JAZ that won't run since yesterday. When the air kicks on it simply makes a buzzing noise and the fan doesn't spin. Can anyone help?
try spinning by hand when the unit make the buzzing sound. to see if the capacitor is bad. If the fan runs replace the cap. If not motor probably is bad. See if it spins freely. this is a good starting place. need to check if the buzzing is the contactor and there is no power to the condensor. The contactor will buzz even though the main breaker is off or tripped
Aug 10, 2009 | Ruud UAKA037 Air Conditioner
Hampton Bay 52 in. white
If you manually start the fan rotating and then switch on power, will it start up OK? You may have a bad winding in the motor or the fan is mechanically bound up in a specific area but once it goes past that it may continue to rotate.. Or.. your fan motor may be damaged. Buzzing is normally associated with the motor unable to get past a bound up spot .. Hope this helps..
Aug 20, 2008 | Hampton Bay 52 In. White Redington...
Fan won't run, and buzzing sound
Motor's shot. New motor and capacitor should fix your problem
Jun 07, 2008 | Ruud UAKA030 Air Conditioner
Fan not blowing
Even when the power is off at the unit outside the thermostat will supply power to the contactor of the outside unit. This may give a hum or buzz as you stated. If when the power is on to the outside unit the fan tries to start but only hums the motor may be bad. Does the compressor start and run?
May 06, 2008 | Weather King 10AJA2501AH Air Conditioner
Ceiling fan
isolate the buzz: 1. completely disconnect it from the mount and have an assistant hold it...turn it on ms 2. if buzz stops, then remount using packaging foam (or wood tile under-layment foam) 3. if buzz, then electric coil for ms is faulty...new motor
Apr 09, 2007 | Hampton Bay 24002 Ceiling Fan
Kitchen Ranges Logo
57 people viewed this question
Top Indesit Kitchen Ranges Experts
Paul Carew
ptpumpman
Are you an Indesit Kitchen Range Expert? Answer questions, earn points and help others
