Question about Fargo Pro L ID Thermal Printer
You should clean the platen roller every time a new laminate roll is installed.
2 Suggested Answers
SOURCE: Lam Error/Out
I contacted fargosupport.com and a technician walked through the solution, free of charge.
Posted on Jul 18, 2008
The roller does not hold paper tight so will not roll or advance
on either end the platen roller has collars, some you can sqeeze and lift the roller out.some have release and turn type mechanism. under the platen roller there are several smaller rollers . 6 to 8. inspect this area for foreign debris. clean with 70% alcohol. reseat the platen roller and test.Platen will lock in if not its in that latch.the worst case is you have a broken gear.
Jul 24, 2015 | Brother Ml-100 Electronic Typewriter -...
How do I feed New laminating film through straight? Top roll of new film is wrapping around bottom heat roller
go to youtube and watch the video on GBC ultima65 film loading. sounds like you are not using a threading card to load laminator. Manila File folders work great to load laminators Westco Laminating Svcs 405-324-6092
Aug 30, 2014 | Gbc HeatSeal Ultima 65 Laminating System
When typing the letters pile up on each other
Most likely it needs lubrication. WD40 is a wonderful thing. Make sure that you put rags under the typewriter to catch the mess. As you press keys and the space bar, spray under the platen as it moves. You want to lube the escapement and the rails. When finished, use denatured alcohol to clean the platen and rollers. (But try really hard NOT to get WD40 on the rollers or the platen. The rollers can be hard to get to). DO NOT do this if this is an electric. They have a rolling platen under the typewriter to provide movement to the keys, etc. If the roller gets oil on it, it will stop working! You can keep cleaning the roller, but as the oil keeps dripping on the roller, all the movements will slip. Eventually you might get it clean, but it is a pain.
Apr 17, 2014 | Smith Corona Sterling Vintage 1940s Type...
Laminate Film Disconnected
Un-coil the lower roll and feed it through by hand.
Dec 06, 2013 | Gbc HeatSeal H425 Laminator
The front rollers on the laminator will manually move but will not roll when motor is turned on.
look at the transmission chain between the motor and the rollers maybe it is broken.
Sep 10, 2013 | Ledco Compass 27" Roll Laminator
Paper rolled on heater roller. How do I remove?
I fix roll laminators for a living. Its best with GBC machines to remove wraps where the film is stuck to the roller hot. trying to remove ilm adhered to the roller cold can not jusst remove the film but the rubber roller surface. Do note GBC heat rollers espically the red ones are over 500 bucks each:( Its easy to damage those rollers making the machine junk....
This question is old but I answered it for the benefit f others coming here bob haller service and sales 412 366 4906 pittsburgh pa. I answer all phone questions for FREE, and in the pittsburgh area offer free no cost no obligation estimates
Oct 04, 2011 | Gbc HeatSeal Ultima 65 Laminating System
The sheet im laminating rolled up inside, cannot get it out
Water-based cleaners will not work with this type of adhesive. Rubbing alcohol or a citrus-based cleaner (eg, Goo-Gone) will be required.
Feb 22, 2011 | Xerox Staples XRX LM1910 Laminator
Label stuck under typewriter platen/roller of Adler Royal
Roll a new piece of paper the best you can. Dribble a little paint thinner on the paper, letting it run down under the roller. The thinner will disolve the adhesive on the label. After a couple minutes, you should be able to roll out the paper and the laber with no problem.
Aug 28, 2009 | Office Equipment & Supplies
Ibico 2700 laminator
I need to replace the rollers on my IBICO 2700 laminator. I will need to order the new rollers can you help?
Apr 24, 2008 | Office Equipment & Supplies
Fargo Pro L ID Thermal Printer Logo
108 people viewed this question
Top Fargo Office Equipment & Supplies Experts
Safe-Card ID...
Are you a Fargo Office Equipment and Supply Expert? Answer questions, earn points and help others
