Question about iPhone Apps
Bt vision box not upgrading quotes error VDR102
yalmer
  • 549 Answers
SOURCE: codes for tuning bt vision box to sanyo tv
 There are only 2 codes for Technosonic. 0037 and 0556. I hope these help.
Sympton Problem Solution
Rolling Screen?
Black & White. PAL Video is selected in error. Click on the TV SYS button located on the DVD remote near the Power button.
Light to Dark Picture. Connection to VCR or TV/VCR combo. Unplug the DVD player from your VCR and connect the DVD player direct to your TV (bypass the VCR). If TV does not have audio/video plugs, or if you have a TV/VCR combo, you will need to purchase and install an RF modulator (available at most electronic retailers).
The light to dark picture? Condition is caused by the disc manufacturer's license encoding at the time of manufacture. It is not cause by the DVD102 player.
No Video. TV needs to be switched to the correct input mode. Your TV must be switched to the correct video input selection. You can only switch the TV to accept an outside video source by using the original factory remote. Locate the button on the factory remote that switches the TV input. The most common descriptions on remotes are: GAME, TV/VIDEO, A/V, VIDEO, INPUT or SOURCE.
Universal Remote Code. The code has not been published. The Universal Remote manufactures create the codes.
Region Error. Software issue. Return the DVD player.
Unit Displays No Disc Even After a DVD has Been Loaded. Defective unit. Return the DVD player.
Unit Displays Loading Even After Giving Adequate Loading Time. Defective unit. Return the DVD player.
Here is what I was able to find.
If not let me know and I will try finding more info
Posted on Feb 14, 2008
scousegitt
  • 8 Answers
SOURCE: BT VISION BOX
Bt vision service addres is not a physical address like your house, it is the ip number of the bt server which allocates connectivity for your vision box. This number is kept under wraps as bt will NOT give it out over the telephone, they insist that an engineer must call to input this number if they cannot do it remotely. I think that this is to prevent unauthorised access to their servers. A load of Bull...t i hear you say, well i agree it is totally stupid that they wont give you this number. this address is asked for by your box when a diagnostic fault usually CO3 error occurs. People who think that this address is like a house address or an address of where the box is located do not know what they are on about.
Jonn
Posted on Jan 22, 2009
SOURCE: I have a Bush 2878 TV and have just got BT vision
Thank you for the follow up. I have solved the problem by working my way through 4 figure numbers starting at 0001 and in fact the solution was 0009 - which was not a number that bt vision had suggested.
Nicky Spink
Posted on Oct 28, 2009
  • 11800 Answers
SOURCE: I have an Akura ATLDVD1930W-HD
The code for your tv is missing from the remote because there is an cross-incompatibility: at code level some of the commands for the tv are identical with completely different commands on the box. This is why when you press a key on the tv's remote the box freezes - it's commanded something that doesn't makes sense for it.
Unfortunately there's absolutely no way you can change that . All you can do is to stop using the remote of the tv and block its remote/IR sensor so it will not be messed up by the commands to the box. Or you could get a new tv.
Posted on Feb 01, 2011
Can I have a you view box free
Hi
I got my YouView box free when I signed up for BT Infinity (upgraded from standard broadband), and TV Essentials (replacing my BT Vision which had ceased). The link below will take you to a BT page which may help you,
TV Packages And Deals Online BT
although I found it difficult to sort out what I would get on line and in the end rang them
Cheers
Nov 13, 2014 | Computers & Internet
Why do's my bt vision box keeps rebooting its self
It sounds like it has a fault. Contact BT for a replacement.
It might be worth trying the following first: Restarting the BT Vision box Help BT com Help
Mar 03, 2014 | Apple Find My iPhone
BT Vision box re-booting
It sounds that the upgrade was not success. Contact any service technician. google.com/+GopakumarGopalan
Nov 25, 2013 | Toshiba 32AV500U 32 in. LCD HDTV
Bt vision box
you must call to the company supplier for to see if there are a problem with the upgrade, in the signal or model, and adjust.
If the problem is o.k so can reset the r.control in menu to factory default. Otherwise you must the TV with some repair shop TV for fix it. However you must setup in the MENU to go factory default. Retest any cable dirty or corrosion, clean it with solvent cleaner contacts, buy it from any stores from supplier electronic devices, like computer, etc
God bless you
Jul 12, 2013 | Televison & Video
I have an e-motion tv and am unable to set my bt vision controler up as can't find a code
Same problem solved through patient "trial & error" ... for my e-motion TV, the BT Vision remote works with code "0081"
To program the BT Vision remote, instructions can be found at:
http://bt.custhelp.com/app/answers/detail/a_id/13573/~/programming-my-black-bt-vision-remote-control
Mar 06, 2012 | Televison & Video
Cant get my bt vision [freeview] to come on. my box doesnot let me view freeview . on my bt vision box.
This system can only be used if you subscribe to BT Vision.
They have it configured so that Freeview only works once the box has checked your subscription.
I think this is a bit mean of BT because with their system Freeview is not free as you cannot access it without paying the monthly fee.
Aug 27, 2009 | Philips Televison & Video
How do you connect bt vision to a sony bravia kdl 37v4000.I have it working ok on freeview only but the bt vision appears on analogue channel 6 and the vision remote changes the tele channel not the vision...
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
Jul 23, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
BT VISION BOX
The Hard Reset you have been given is wrong, the one listed here is a Soft Reset, a Hard reset is done by unplugging the power cable and then on the V-box press and hold down arrow and ok buttons together while reconnecting power cable back in, the full software install should take 20 to 30mins depending on your b/band speed, you will also need to have a NEVOSS account setup for the v-box to register on the server (i'm a BT Vision Engineer)
Feb 29, 2008 | Samsung LE32R73BD 32 in. HD-Ready LCD...
iPhone Apps Logo
202 people viewed this question
Top Apps Experts
Erin Wood
Erin Wood
Are you an App Expert? Answer questions, earn points and help others
