Question about Lexmark X544dn All-In-One Laser Printer
CHECK CONFIG ID x204n - Lexmark X544dn All-In-One Laser Printer
What does the error Lexmark X204N error 31.05 mean?
Try cleaning the toner contact springs with cloth damped with a little alcohol it will make continuity more sensitive to the toner cartridge chip
Dec 15, 2016 | Lexmark X204n 4-in-1 Laser Printer
How to fix935.12 services mirror monitor for lexmark x204n
call 1-800-LEXMARK (800-539-6275) if still under warranty you will get a repalcement.
Feb 06, 2015 | Lexmark X204n 4-in-1 Laser Printer
Lexmark x204n
Lexmark x204n 931.01 error
Nov 04, 2013 | Office Equipment & Supplies
X204n lexmark,900 firmware error to continue,
The 900 error usually indicates a software or communications problem. The first thing to check is the base printer.
Turn off the printer and disconnect every cable, except for the power cord.
Turn on the printer and see if the error returns.
If the error does not return, try to print a test page from the Test Menu.
If the test page prints correctly, the printer's hardware is most likely working correctly. The source of the problem is probably outside the base printer.
Jul 27, 2011 | Lexmark X204n 4-in-1 Laser Printer
Lexmark x204n will not receive fax
Please click on the linkbelow to see instructions on how to go about the procedure. http://bit.ly/owditc For further assistance,please contact Lexmark Technical Support.
May 03, 2011 | Lexmark X204n 4-in-1 Laser Printer
My scanner wont work on my lexmark x204n . the printer works .
Please download the scan driver from support.lexmark.com. After installing the scan driver, please check the scanner under Imaging Device from device manager. If scanner shows under imaging devices, open the scanning program and scan a document.
For further assistance, please contact Lexmark Technical Support.
Feb 18, 2011 | Lexmark X204n 4-in-1 Laser Printer
"900 firmware error" on our Lexmark X204n printer. how do we fix it?
Jan 21, 2010 | Lexmark X204n 4-in-1 Laser Printer
Lexmark X544dn All-In-One Laser Printer Logo
56 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
