Question about HP Deskjet 6980 InkJet Photo Printer
Printer prints collated order- change
How do I change the collate setting on my HP 6980 Deskjet?
IB4G2008
  • 3587 Answers
SOURCE: HP Deskjet 6980
start with a fresh set of US based drivers, and follow those instructions. get em here
Posted on Mar 09, 2008
Bubbabear64
  • 2794 Answers
SOURCE: How to change black ink cartridge of HP Deskjet 6980
Lift the cover up.
The ink jet carriage should park in the center of the carriage.
Gently lift on the front of the ink jet until it removes. Some you have to lift up and some you have to lift down on. Just be careful.
HP inkjet cartridges tell you on the front of the stick by a dot weather it is tri color or black.
Posted on Jun 13, 2008
acdr
  • 1913 Answers
SOURCE: does not print the whole page
install pirnter driver again.alos reset your printer to factory defaults.
Posted on Oct 21, 2008
SOURCE: unable to store job at printer, printer not configured to collate
Problem -=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-=-
Error “Unable to store Job at Printer”
Reason “Printer not configured to collate”
Solution “Install an EIO hard disk”
Usually when trying to print a multi page document.
Solution 1. Start > Control Panel > Printers
2. Locate the printer > Right Click > Properties.
3. Device Settings > Mopier Mode > Set to Disabled.
4. Apply OK
Posted on Mar 21, 2009
  • 20 Answers
SOURCE: HP 3055 printing black lines when using collate feature to copy
All you need to do is to clean the small wide glass (that at the LEFT of the main flat big class). The Auto Document Feeder (ADF) specifically uses this glass to scan for copy (and fax). When it is dirty (such as small dirt or particles on the surface which is easy to gain in long run), it will create thin vertical line(s) as the result.
Posted on Jul 07, 2009
I have a MFC7860DW, How do I set it to collate copies?
You can download the manual from here: Reference page 24: "Collate With the Collate check box selected, one complete copy of your document will be printed and then repeated for the number of copies you selected. If the Collate check box is not selected, then each page will be printed for all the copies selected before the next page of the document is printed."
Mar 02, 2015 | Brother MFC-7860DW Compact Wireless...
I have a hp psc 2210 all-in-one recently when I go to print a letter, etc. the printer has the collated box checked. I would love to delete the collate option from my printer.
one way to reset the settings would be to remove and then reinstall everything related to the printer.
you could try going
start -> control panel -> printers and faxes -> your printer, right click properties -> find the setting and uncheck it.
Jul 23, 2008 | Office Equipment & Supplies
Printing page order
under print settings make you have "collate" option checked. There are different ways to find this depending on which operating system you are using.
May 26, 2009 | Brother HL 1440 Laser Printer
Unable to store job at printer, printer not configured to collate
4. Apply OK
Feb 25, 2009 | HP LaserJet 2300L Printer
Print error job storage
The printer needs to have RAM drive off, mopier mode disabled. Also the device settings for the printer needs to have Printer Hard Disk set to not installed and job storage and mopier mode set to disabled.
Jan 15, 2009 | HP LaserJet 4200 Printer
Xerox Phaser 7300DN will not collate
Try using the PCL driver from the Xerox website, rather than the Postscript one supplied with the printer.
I had the same problem and installing the PCL driver solved it.
Sep 27, 2008 | Xerox Phaser 7300DN Laser Printer
Multiple copies
Look for a small "Collate" box and make sure it is checked. That way it will print each set in order.
Sep 26, 2008 | HP DeskJet 5550 InkJet Printer
I am running Microsoft Word 2003 and have an HP 1320n printer. My problem is that when I print more than 1 copy the pages do not collate even if the collate box is ticked in the print dialogue book and so...
HP 1320 print driver is a universal print driver covering several printer models.  Collating only works on HP printers if you have a multiple exit tray system for commercial based laser printers similar to finishers on a copier.  They have to have room to keep the copier together before they can be collated.  On a standard configured 1320 there lacks any space for finishing tasks.
This support bulletin on hp.com can provide you the answer:
http://bizsupport.austin.hp.com/bc/docs/support/SupportManual/c01366409/c01366409.pdf
Sep 10, 2008 | HP Computers & Internet
KONICA MINOLTA C450 VXL Printer - When stapling multiple copies it staples all the copies together rather than each one separately as required. I use vista operating system.
There is an issue with the Konica Print Driver and the MS Print Driver. If Collate is turned on in both the drivers, you will get this problem.
The solution is to turn off Collate on one of the Drivers. Usually you will have an initial Print Dialog window that pops up when you can select your printer, how many copies and if to collate or not. De-select Collate. Then you should also see Preferences Tab. If you select that tab, select Collate and Staple, your print jobs should now Collate and Staple correctly.
HP Deskjet 6980 InkJet Photo Printer Logo
15 people viewed this question
Seeker5211
Seeker5211
