Question about Mineralight Multi-band Lamp Model Uvsl-25
Buying replacement bulbs
I need to replace the 2 lamps in this model. Does anyone know where to get this size - 1 bulb says UVP inc J-204, the other bulb JVP inc 50054. The original bulbs were made in Japan. Thanks for the help.
Headlight replacement holder.harness for 2006 JIANSHE JY50QT-2 scooter
Donna Donna Donna, you know my blood pressure goes up when people with motor scooters that have names I can't pronounce ask me questions about parts concerning a model that has been discontinued, you're killing me. The way I see it you have 2 options:
1. Solder the offending connection.
2. Take it to someone that has not done his good deed for the day.
Good luck and have a wonderful day. Gregg
May 31, 2017 | Motorcycles
Samsung HL-S5087W (" CHECK FAN # 1") is displayed
hello Harley,
Lamp # 1 is lamp fan, Lamp # 2 is DMD board fan.
Lamp # 1 is located behind the lamp.
Pull assy angine out you will fine fan # 2 , clean it or replace it if not rotate properly.
Fans displayed on screen because fans are dirty or air flow not smoothly.
Good luck.
Mar 30, 2011 | Samsung HL-S5087W DLP TV
My rca dlp doesn't turn on
You probably need a new projector bulb. Google up your model and buy the best warranteed one you can find. Buy a "caged assembly" and not just a bare bulb.
Then unplug your tv and get a screwdriver. Follow your model's instructions and just snug down the electrical screws. Do not overtighten them.
Then consult your manual on how to reset the lamp timer so it knows you put a new bulb in and fires up from the first try.
Treat yourself because you've just saved yourself a trip from a repairman!!
Aug 11, 2010 | RCA HDLP50W151 50" Rear Projection HDTV
How do I change the lamp? Lamp came with no directions. This is a HD72.
Hello there,If your movie projector light bulb has stopped working, there are some simple steps to take to get your movies playing again. The hardest part may be finding the correct replacement bulb. There are so many different models with their own specific bulb. Here are some steps to follow to replace your burned out light bulb.
  • Locate the bulb in the movie projector. You may need to use a screwdriver to open the bulb compartment. Check your owner's manual for proper procedures.
  • Step 2.Remove the movie projector light bulb or lamp. The bulb must be cool before you take it out. Use a tissue or cloth to remove the bulb because the glass bulb is very fragile. Do not throw away your bulb yet, you may need it to help find a replacement.
  • Step 3.Find replacement bulb. The Better Lamps website offers a wide variety of light bulb models. From their homepage select the brand of movie projector you have and using the model number from your old bulb, buy a replacement.
  • Step 4Replace the movie projector lamp or light bulb. Do not touch the bulb with your skin. This can transfer oils from you onto the bulb resulting in a hot spot which can make the bulb burst. Use a tissue or cloth to handle the new bulb to screw it back into place and then replace the cover.
  • Jul 31, 2010 | Optoma HD70 DLP Projector
    Sony KDF50E2000 lcd tv has burned out it's second bulb. Replacement bulb was OSRAM brand. It only lasted 10 months, now it won't come on. Should I be looking at the ballast or did I just get a poor...
    Hi,Osram lamps average around 3000-4000 hrs.Normally 1 -1 1/2 yr.I do think the lamp went out.The ballast is a possibility,when it's going bad it will make clicking noises or attempts to light the bulb.I recommend to get the Original Philips lamp for they average 6000-8000 hrs 3-4 yrs.
    Mar 25, 2010 | Sony KDF-50E2000 50" HDTV
    How do I open the top of the projector to replace the light bulb?
    Hi, Follow :- http://www.wikihow.com/Replace-a-Projector-Lamp There is a Video as well on the same page.If you wish to Purchase the Bulb, you could consider :- http://www.partstore.com/minisites/projectorLamps/HowToReplaceProjectorLamps.aspx Let me know, if needed further assistance, Hope i helped you. Thanks for using ' Fixya ' and have a nice day!!
    Feb 10, 2010 | Televison & Video
    I HAVE A RAINSOFT UV AIR FILTER IN MY AIR DUCT WHERE DO I GET REPLACEMENT BULBS, AND WHAT IS THE PROPER BULB AND SIZE?
    Cleanwater also has them. Clean them with rubbing alcohol, do not let your fingers touch the bulbs. And check your 24V ac adapter. If it starts going you will get a power light but the other lights will come and go. I have one and the bulbs are nearing the end of life, not a cheap fix.
    http://www.cleanwaterstore.com/O1002250-p-clearwater-tech-parts.html
    Jan 02, 2010 | Air Purifiers
    Where is a good place to buy replacement bulbs?
    Try Healthy Technologies, Inc. - 1-877-710-0057.
    Mar 31, 2009 | Ecoquest Fresh Air Air Purifier
    Sony KDF-50E2000 50" Lamp replacement
    1.you have 10hrs
    2.you can find them everywhere try eBay
    3. It is easy except one thing you must have the original remote to reset the lamp counter
    May 16, 2017 | Sony KDF-50E2000 50" HDTV
    Mineralight Multi-band Lamp Model Uvsl-25 Logo
    46 people viewed this question
    Top Mineralight Science & Laboratory Experts
    Gareth Cockram
    Gareth Cockram
    William McMath
    ray gallant
    Are you a Mineralight Science and Laboratory Expert? Answer questions, earn points and help others
