Question about Dryers
Wont ignite the pilot wont heat up, leaving the clothes wet
    President:
  • 1,136 Answers
Hi, Please get a model# so I can give you instructions to repair this issue. Each brand is a little different.
Thanks
Vic
Posted on Jun 20, 2009
    Sergeant:
    Champion:
  • 266 Answers
Does it have a damper if so test the switch,clean out all lint compartments if its gas make sure the gas valve is opening
Kenmore model 90 dryer electric will dry the clothes takes a long time. Leaves the floor surrounding the dryer damp actually wet just not puddled
Are the clothes wet AND hot? If so - check the exhaust / vent hose for kinks or obstructions. That includes the cap / flap on the outside of the house.
If the clothes are wet AND cold, then the electric heating element isn't heating likely due to a broken or poor electrical connection, burned out heating element, defective thermostat, etc..
Jul 14, 2015 | Kenmore Dryers
Kenmore 500 dryer
If you mean that it is not heating and stays cool, most likely the pilot sensing thermocouple needs replacing (if you have a gas drier with a pilot light) or the electronic ignition contacts need replacing (if you have a gas drier with electronic ignition). Not sure about an electric drier, but probably the heating element needs replacing, or the thermocouple sensor (most likely). None of these are very expensive.
Jul 23, 2014 | Kenmore Dryers
Maytag DG410 gas dryer-no flame, no heat. I replaced the ignitor - that apparently isn't the problem. Other ideas?
Motor runs, but main burner will not ignite
1.heat switch set wrong---correct switch setting
2.defective timer or timer circuit---check timer wiring--replace timer motor or switch as needed
3.defective centrifugal switch in motor---clean switch or replace as needed
4.gas supply valve closed----open gas valve
5.inoperative solenoid coil---test coil for open circuit & the voltage to it
Pilot burner goes out
1.insufficient gas supply---- low gas pressure or clogged pilot filter or partially closed gas valve
2.carbon deposit on thermocouple tube---clean tube & check pilot burner for proper combustion
3.improperly adjusted pilot flame--adjust pilot flame until faint yellow tip begins to appear
4.faulty ignition or reset valve or thermocouple---replace
Clothes not drying, but dryer runs & heats
1.defective operating thermostat---test thermostat, replace if defective
2.fan or it's pulley loose on shaft---tighten set screw
3.incorrect heat or timer settings---reset timer
4.clothes to wet when placed in dryer----wring out or extract water from clothes before placing in dryer
5.clogged lint screen or duct (little air motion)---clean out lint screen & duct
Sep 22, 2011 | Maytag PYG4500A Gas Dryer
My gas dryer is working but there is no heat so my clothes will not dry. I've got all these wet clothes and I need to get this dryer to heat up. Please heat!
Your ignition unit may be worn out and will need to be replaced. Generally, a heating element comes on and once it reaches a certain temperature, it ignites the gas pilot. Then the heating element cools off because the gas is now burning and producing heat. When this heating element stops working correctly, it will not reach the right temperature to ignite the gas. You'll need to have a professional perform the repair. If the dryer is still under warranty, this might be covered.
Check your owner's manual.
I really hope this solves your problem. If it does, please come back to Fixya and rate my advice
Jul 16, 2011 | Dryers
Machine wont dry my clothes
Gas or electric? Gas - Igniter unit needs replacing. Electric - Heating element needs replacing
Apr 15, 2009 | Dryers
Where is the pilot light on the Whirlpool Ultimate Care II Dryer?
Hello gigiknoll
Welcome to Fixya
My name is Huum,
This model should be electronic ignition and does not use a pilot light.
The igniter may be faulty.or the gas module may be faulty.
Pilots are a thing of the past!
This requires a tech to test it with equipment.
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Feb 01, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Hw120m washer/drier
Check if the dryer is heating, if it is not heating check the following There's no heat
Oct 16, 2008 | Hoover H130E Front Load Washer
My indesit widl126s
my washer works fine but the dryer wont heat up or dry the clothes it goes onto dry but all the clothes are still coming out wet and the drum is cold
Apr 01, 2008 | Washing Machines
Dryers Logo
56 people viewed this question
Top Dryers Experts
Marvin
Marvin
