Question about Poulan Pro 22" Self Propelled High Wheel Mower
Poulan pro jump start - Poulan Pro 22" Self Propelled High Wheel Mower
2 Suggested Answers
  • 17 Answers
SOURCE: I HAVE A POULAN PRO 46 WON'T START
Well you might want to check that the ring gear on the flywheel and the teeth of the starter motor are meshing properly. My Craftsman which is a good machine I had to replace the plastic flywheel with the new aluminum one as the teeth seized together and would not turn. It seems unlikely with two hours that you have this problem though.
I would suspect that the battery has a dead short that is drawing a massive amount of power when you go to boost it just gets worse. Did you try to spin the motor with your hand, does it turn. Try taking out the plugs and see if it turns over easy or at all. It should spin easy with the plugs out. If not you have a starter problem or battery problem or a seized motor which I rather doubt with two hours on it.
I hope this helps.
Posted on Sep 21, 2009
I have a poulan pro 500ex I would not start it does not even click at the soienoid. hrs. guage comes on. lights work. jumping the solenoid starts engine. but won't start by the key???
Sounds like a classic case of a corroded battery terminal. Take them off, scrape them clean and reinstall them. Slather some grease on them after you are done to keep them from getting corroded again.
Apr 19, 2016 | Cars & Trucks
WHERE IS FUSE ON POULAN PRO 17.5 HPE
Hi June, Check all safety switches as well, Good luck and CHEERS..
Apr 03, 2016 | Poulan Garden
Where is located the alternator poulan pro pd24ph42st
Just about all the smaller type engines the alt. can be found under the flywheel. The alt is a combination of both the flywheel and the stator ( the electrical windings ) atached to the engine block under the flywheel. Watch out...if you use a vehicle to jump your tractor, it will fry the stator if you the jumper cables on after it initially starts!
May 31, 2014 | Poulan 42-Inch Steel Deck 17.5 HP Briggs &...
Poulan Pro riding mower won't turn right. I can
there is a plastic connector that holds the steering shaft down into the drive gear the plastic cracks and wears out then the gear jumps passed the teeth its about a $15 part
Jun 14, 2012 | Garden
I hope this helps.
Sep 21, 2009 | Poulan Garden
Starts, runs, and dies...starts, runs and dies...starts, runs, an
Sounds like a common fuel problem you need to remove carb & fuel tank and unless you can get a compressor they need a good blast out you may even take carb apart & check diaghram they have very small jets in fact most lawnmower shops have a sonic bath for this
Apr 25, 2009 | Poulan Pro " Pro" Self Propelled Mower
Poulan Pro 36cc won't start
Spark should jump at least 1/8 inch gap.You would need the correct coil for the application spaced at 10 to 12 thousands inch.
You might unplug shutoff wire and try,it might be shorted a lttle causing weak spark.
Feb 19, 2009 | Poulan Pro Chain Saw 46cc 20"
Poulan Pro Lawnmower
i have a 950 zx poulan pro lawn tractor. it will start but when i release the brake it cut off . i can start it up with out sitting in the seat.
Jun 14, 2008 | Dryers
Poulan Pro 22" Self Propelled High Wheel Mower Logo
21 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
