Question about Maytag Performa PAV2200
Pav2300aww spinning very slow,and not draining
Washer is spining very slow and not draining. it was working yesterday and now it is spining very slow. there was a loud noise before it stop working.
  • Anonymous Nov 21, 2007
    have the same problem with maytag Performa Washer
    It goes thru all the cycles but does not give a good spin dry
    I opened up the washer and sprayed a rust buster into the shaft housing and then packed it down with heavy grease. I took a while but now it spins so fast it seems like a helicopter taking off. On occasion it goes back to its old ways and i just try packing in more grease. . Now when it does a poor spinIi reset the washer to spin cycle and turn the washer drum ontil it locks tight and then its back to a roaring spin cycle. Gotan extra five months so far out of the maytag ... will buy another brand soon maybe
  • DonnaInLa Dec 09, 2007
    I am experiencing the same problem--it wasn't spinning the clothes dry very well--leaving alot of water in them. Now it won't spin at all or drain and the motor sounds terrible. I have only had this machine since Feb'06--it has given me problems--I won't buy another one--Maytag, yeah right.
    Scholar:
  • 196 Answers
In all these Cases it sounds like a faulty lip seal. These special seals have Sealed bearings inside. Water gets through the seal and into the bearing which causes it to thump (like a helicopter) or squeal very loudly. As far as draining, the machine has to reach a curtain speed before the pump can turn fast enough to work.
Posted on Jan 08, 2008
My maytag pav2300aww will not spin at all yet it agitates and drains well I was told to clean the agitator so I took it off yet the washer still don't spin the switch look wore out to me so I by-passe
Check the water level sensor and the lid safety interlock. Many washers will work fine with the lid open EXCEPT during the spin cycle, so this is the first logical place to look. Try bypassing the lid safety interlock switch.
Dec 12, 2012 | Washing Machines
Maytag Performa pav2300aww stops and starts
If it's stopping during a wash cycle, suspect the heater elemant not heating up and moving the controller on. See if it runs fine during a spin/drain cycle. If it is very slow on all programs, try the noise filter capacitor before condemning the controller.
May 18, 2012 | Washing Machines
Maytag performa PAV2300AWW does not spin (wash cycle works fine). During the spin cycle the tub does not rotate...but i can hear the motor running...water drains...Pls help
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Aug 29, 2010 | Maytag PAV2300 Top Load Washer
Spin Cycle is slow
new belt or there is a thrust bearing above the drive pulley that wears out.
May 22, 2010 | Maytag PAV2300 Top Load Washer
The spine cycle seem slow need to run more then once
check the tub to pump and pump to drain for blockages of debris,the pump should drain the bulk of the water,then it should spin out the rest unless the belt is that glazed,get to the spin cycle and pull out the washer drain hose out of the house drain stand pipe and see how much force water is while being pumped out while just pumping and not spinning,there should be the water stream the size of the inside of the drain hose and good velocity of water flow to the drain
Mar 13, 2010 | Kenmore 88752 Top Load Stacked Washer /...
Not spining out good. Looks like its spining slow
Make certain that the spin speed is where you want it (e.g.: high spin). Also, make certain that you aren't overloading the washer. A heavier load will slow down the spin.
You may have a worn drive belt (loss its tension on the pulley). Contact an appliance service company.
Feb 20, 2010 | Amana NAV5805A Top Load Washer
GE washer not spine
First thing you can due is to manually move the time to drain and spin mode. This will check your timer to see if your timer is working. If it start working then it is your timer. It will be your timer gone bad.
Dec 05, 2009 | GE Washing Machines
My Kenmore washer somtimes won't go threw spin cycle
kenmore washers have a 2min. drain before it spines if leting it drain for 2min does not work u proberly need a new lid switch. haundi24
Jul 03, 2009 | Kenmore 22422 Top Load Washer
Washing Machines Logo
247 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
