Question about C & A Scientific Goggles
No taste. No smell
No taste. No smell
Keurig drinks taste bad like plastic
try running viniger threw it then flush it out
Aug 29, 2012 | Cars & Trucks
KitchenAid fridge ice cubes taste and smell bad
Permanently place a black coal in your fridge to avoid bad smells.
Apr 12, 2012 | KitchenAid Superba Architect KSCS25INSS...
We have a strong "plastic"
try washing with vinegar solution. it is just the new factory smell and taste.
Feb 03, 2011 | Samsung Refrigerators
Awful smell and taste to water boiled in a stainless steel kettl
I have the same problem. Noticed it was in two different pots. The comment number one must be correct because I only use VERY high alkaline water to boil my foods. I had a feeling it was my water. So interesting! I will clean it w white vinegar and see if the smell goes away. SAME weird chemical smell- turns your stomach.
May 25, 2010 | Kitchen Appliances - Others
Drinking water has a bad taste and smell.
You will have to trace where the foul smell comes from by tracing the water line and testing the source. Check if it is before or after the filter you get the smell, if it is before the filter, you need to check if it is on the line which comes from the source or it is from the source. Most likely cleaning or probably a replacement of the part if cleaning does not help.
Sep 21, 2009 | KitchenAid (KSRD22FKST) Side by Side...
Ice tastes funny and a strange metallic or plastic type smell
Sometimes the smell comes from something in the freezer or even the refrigeratior and makes the ice taste funny. My suggestion is to clean out the freezer compartment of anything frozen that has been there a while and may have freezer burn. That may be the funny smell you are experiencing.
Hope this will help you.
Jan 15, 2009 | KitchenAid KSRS25IL Side by Side...
Water smells/tastes like freon
freon has no smell or taste and in any case doesn't get anywhere near the water. look elsewhere like your water supply
Nov 04, 2008 | Kenmore 53463 Stainless Steel Side by Side...
Plastic Smell & Taste
Just because its made of plastic doesn't mean it should taste like plastic! The engineers made a mistake in design! Get your money back and don't risk taking in carcinogens!
Feb 25, 2008 | Mr. Coffee 072179228578 12 Cup Coffee...
C & A Scientific Goggles Logo
51 people viewed this question
Top C & A Scientific Science & Laboratory Experts
William McMath
Tom Chichester
Are you a C & A Scientific Science and Laboratory Expert? Answer questions, earn points and help others
