Question about Cub Cadet Garden
Throwing oil out the carb - Cub Cadet Garden
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Cub Cadet Master
  • 1,917 Answers
Broken or bad rings on pston
Posted on Dec 17, 2014
What cause echo pole chain to lose power?
Plugged carb jets. Pull the carb and spray it down yourself, or bring it to a small engine repair shop and they can throw it in their ultrasonic cleaner. Most 2-stroke engines are not meant to idle (oil in the fuel clings to parts); they're meant to be full throttle for 90% of their operating time.
Aug 07, 2014 | Echo Garden
Tickover to fast when warmed up.
I don't know the term tickover. If you mean it idles to high then lower the idle. It's a carbed bike right? Idle screw is on backside near front of carb but remember these Twin cams run on oil volume not oil pressure. The bike needs to idle between 1000 - 1200 rpm to maintain proper oil circulation. If you turn the idle down to get that lope or potatoe sound from the bike you can starve the engine of oil and burn it up. These aren't throw away rice rockets of yesteryear.
Jan 19, 2013 | 2000 Harley Davidson FXDL Dyna Low Rider
Yamaha wr250f backfiring whislt starting
has it been sitting? if so its going to need a carb clean, its just starving for fuel, also you might want to throw a new plug in it #CR8E and one more thing and this is a very common mistake, make sure the air filter is installed and has filter oil on it, believe it or not that filter and the oil thats supposed to be on it play a major role in the runability of that bike.
Oct 09, 2012 | 2004 Yamaha YZ 250 F
Craftsman 4 cycle weed wacker throwing oil
check the oil and see if its over full the carb might be leaking fuel into the crankcase
Aug 08, 2012 | Craftsman WeedWacker Gas Trimmer 29cc...
Oil and smoke shooting from the muffler. Please help!
check the oil to see if it smells like gas if so a carb problem was it stored other than flat?
Jul 07, 2012 | Garden
My 12.5 hp on my wheel horse starts and runs for about 15 seconds and then starts throwing what looks like a mixture of oil and gasoline out the carb and then stalls out
the needle valve in the carb is not seating replace the needle and seat and change the oil let it run without a load and change it again
May 18, 2012 | Garden
Breather tube throwing oil into carb
Oil coming via the engine breather can mean a worn engine, it could be as simple as an over filled sump, or the breather valve itself is not working, the breather valve allows the crankcase pressure out of the engine.
Apr 20, 2012 | Cub Cadet Garden
1995 suzuki sepia 50cc 2stroke doesnt run
Two strokes are bad with fuel/oil mixure. If this is premix theres a problem,if injected you may not be getting oil injected. Topends will heat up fast without oil. Fouled plugs and the wrong gap will also cause these problems. Check carb boot for cracks as air leaks will also starvel fuel out. Spray WD40 into carb throat with out tank hooked up, if it fires up, clean carb and reset float. Make sure the spark gap is correct. Check to be sure you have not slipped a keyway on flywheel which would throw timing off and it will only start by accident once every so often.
Feb 25, 2010 | 1995 Suzuki VX 800
Honda GX390 stalling in go cart
I believe its the the oil sensor. The engines are equipped with a low oil sensor and when you go around turns, accelerate, decelerate, the oil will flow from side to side and throw the sensor off, causing the engine to shut off. Remember, this is because the engine is from a pressure washer and pressure washers arent meant to be driven LOL.
Mar 14, 2009 | Honda Garden
Engine oil was throw in the gas tank, engine would not start.
You will need to clean other parts of the engine aswell, especially if it was pulled over with oil in the tank. First of all buy some carb cleaner. Now remove the bowl from the bottom of the carb by unscrewing the central bolt (10mm) underneath. You can leave the float and needle in place. Now spray the carb clean over these parts and also direct some up the jet in the middle of the carb body. Clean and replace the bowl. Now remove and clean the spark plug. Before refitting it pull the starter a few times to throw out any oil that might be sitting on the piston. It may also be wise to remove and check the exhaust (12mm) for oil. When it is all refitted the machine should start after a few pulls. It will probably still have some oil in the sytem so don't be alarmed if it smokes (white) for a couple of minutes. Once this has all burned off you should be fully operational again.
Oct 28, 2008 | Honda Garden
Garden Logo
Top Cub Cadet Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
roeb
Are you a Cub Cadet Garden Expert? Answer questions, earn points and help others
