Question about Blaupunkt Car Audio & Video
Reset blaupunkt usb interface - Blaupunkt Car Audio & Video
Blaupunkt 40/148 tv. how do i record programmes to usb ?
I could not find an owners manual for this TV but if it is like most TV's usb is for playing media, Not recording. I found a site that talks about your TV. The first reviewer explains the usb is for watching (not recording). I have a different TV and same holds true. IF you really want to record TV and have a computer with Windows 7 or Windows 8 you have capability to record to the computer and then move it to a usb to watch it elsewhere.
Customer reviews for Blaupunkt BLAUPUNKT 40 148
I hope this helps.
Jan 29, 2015 | Televison & Video
Password reset on blaupunkt tablet
How do I reset the device to factory settings?
Tap on: Settings---Back up & reset---Factory data reset, to reset the system to
factory settings.
http://www.blaupunkt.com/uploads/tx_ddfproductsbp/HW-Manual-Vollv_Android4.0.3_Endeavour_TV_seven_Engl.pdf
Mar 25, 2014 | Tablets & eReaders
How to Reset Power On Password if I Forgot
You can reset computer password with Windows Password Recovery Enterprise
Step 1: Install and run the program.
You should take this step with an accessible computer and then quickly and correctly launch the program.
Step2: Burn a password recovery disk with CD/DVD/USB.
After launching the program, you will get an interface as below. Next insert an empty CD/DVD/USB flash drive to the accessible computer. Then you just follow the wizard on the interface to burn the password recovery disk step by step.
Step3: Reset computer password with the burned disk.
Now take out the burned disk from that PC, and insert it to the target computer. Next boot that PC and set it to boot from CD-ROM or USB in BIOS. When the BIOS settings finishes, the PC will restart automatically. Soon you will see the below interface. Next, you just need to follow the wizard displayed and do 3 mouse clicks to complete changing computer password.
Souce: http://www.recoverlostpassword.com/article/change-computer-password.html
Jul 25, 2012 | Compaq Presario CQ62238DX Laptop
How to reset your computer
Jul 25, 2012 | Computers & Internet
I need usb kabel for travelpilot lucca mp3
The Travelpilot Lucca does not have the capability to be connected by USB cable. The connector socket on the bottom of the device is intended for a cradle built into a car that provides connectivity to compatible Blaupunkt car radios. It is a proprietary connector unsuited for PCs.
MP3 files are transported to the Lucca via SD cards only.
Jan 04, 2011 | Blaupunkt TravelPilot Lucca MP3
I need a code for my blaupunkt -serial number VWZ1Z1T7090203 tHANKS IN ADVANCE
The only way you can get the code for your radio is to call Blaupunkt\ Robert Bosch for the code. That is providing that your radio code is not a self programable code which alot of Blaupunkts are.If that is the case and you forgot the code you would have to have a service dept "reset"it for you.
Nov 25, 2010 | Blaupunkt Car Audio & Video
Blaupunkkt 5 disc changer
to take it out, you need two special toolsto insert in the four small holes on the sides. Since you probably don't have them, you can use four allen wrenches of the appropiate size. Just insert them and they will unlock the unit. (you might need something else to help you pull the unit very gently from one of the slots).
To reset the unit, I am not sure what do you meen by that. Just remember the unit has to be set up to work in the car's setup with the dealers interface module.
Aug 18, 2009 | Blaupunkt IDC-A09 5-Disc CD Changer
Just bought a boat with Blaupunkt radio, never received the code - trying to decode.. Model#47001402 / B472601189
you will have to ask the orig owner for that code or send it into blaupunkt to have it reset
Aug 14, 2008 | Blaupunkt Car Audio & Video
TravelPilot DX-N Manual/Wiring diagram
http://www.blaupunkt.de/fileadmin/user_upload/Service/SERVICEDOKU_ZIEL/EA/GB/7612001460001_EA_GB.pdf
Jun 11, 2008 | Blaupunkt TravelPilot DX-N GPS Receiver
What cd changer do I need for the Blaupunkt Sydney rcm 126W head-unit
where can I get a replacement display for my blaupunkt sydney rcm 126
Nov 26, 2007 | Blaupunkt CDC-A08 10-Disc CD Changer
Car Audio & Video Logo
15 people viewed this question
Top Blaupunkt Car Audio & Video Experts
xxxxxx xxx
Colin Stickland
Colin Stickland
Are you a Blaupunkt Car Audio and Video Expert? Answer questions, earn points and help others
