My channels 9 go in and out - Audio Players & Recorders
I can't change off of channel 9
look for the channel 9 switch--it automatically takes to 9.
Oct 28, 2012 | Maxon HCB-30A CB Radio
Is channel 9 an official emergency channel?
The FCC has designated channel 9 as an emergency contact channel. With this being said, channel 9 is only valid in the United States, while other countries do not have an officially designated emergency channel that I am aware of.
Jul 18, 2012 | Cobra 19 dx iv 40 channel cb 05/10 19dxiv
Stuck on channel 9 wont change
Try pressing the emerg. or Cha.9 button....hope this helps...
May 06, 2010 | Cobra 18 WX ST II 40-Channels Base CB...
Most of the new singal have more than one channel how does one tune in with out going to a channel that one does not want to view. if I'am on channel 13 and I want to view 9-2 I have to go to 9 than to 9-2...
There should be a place where you can store "favorites" or channels that you like to go to quickly. Break out that awful owners manual and see what your set offers. Also, the remote should have a way of directly entering the channel you want. Thanks
Oct 26, 2009 | Televison & Video
"No Signal" on channel 9
Appears you are getting a weak signal at the channel 9 frequency. If you are using a signal splitter, try replacing it with an amplified unit since splitters always do the deed but they can and will reduce signal strength significantly.
Also remember that digital signals are not like the older analog ones that they replace. They are not subject to ghosting but are weaker and susceptible to all sorts of interference such as a leaf, rain, etc. Your antenna is good.
You also might try raising the antenna. The higher it is the better it works. (use some wire to further support additional height) Why do you think transmitters are so tall?!?!?
Mar 22, 2017 | Vizio VW32L 32 in. LCD HDTV
Wont change channels...stuck on channel 8
on this radio you have to put the norm and channel 9 switch to normal or up if it is on ch 9 positon it will not change channels.
Apr 16, 2009 | Midland 1001Z 40-Channels Base CB Radio
I have a Westinghouse 26 inch TV. Model # SK-26H590D. It will not scan channel 9. I have tried both the automatic scan and the find channel scan. It is hooked to a Phillips Mant 510 vhf/uhf indoor antenna...
I carried my Westinghouse TV to the basement. Unplugged the antenna from the digital converter box and connected it to my digital TV. I then re-scanned for channels and found channel 9. After carrying the Westinghouse TV back upstairs, I connected the original set-up and tuned to channel 9 which was now showing on the screen as no signal. From that point I moved my VHF dipoles until I had located the correct position for reception. A little labor intensive, but I was fortunate to have another antenna that was receiving channel 9.
Feb 19, 2009 | Westinghouse SK-26H590D Television
Ch 9
Hi larry, That is a normal ch 9 default on electronic channel changers. Small midlands/cobras also do that. Try taking the red/hot power wire loose and attaching it to a power source that is hot all the time. That way there will be power going to the radio with the key shut off and it should retain the last channel you were on.
Hope this is what you were looking for, let us know,, Mechanic
Feb 21, 2008 | Maxon MCB-30 40-Channels Base CB Radio
 Grubhead
Grubhead
