Question about Toshiba Office Equipment & Supplies
Feeder printing horizontal line
When scanning in the top feeder, a horizontal line appears near the bottom of the page. This does not happen when placing copies on the glass. I restarted the printer and made copies but got the same result. I checked and cleaned the glass the feeder used as well.
Nitrotrike
  • 589 Answers
SOURCE: Black line left on copies from the document feeder
Ah, the beauty of digital manipulation :)
In the old days you would have to change the paper in the tray too...
I've been looking online for the glass, and can't locate it. They will charge you a bundle for a piece of glass anyway (I know Konica charges about $50 one).
As to the question of a sensor. If there's no wire on it, there's no sensor. Some manufacturers use a "coating" that goes to a ground wire for anti-static, etc. Most likely, yours doesn't require this.
Also, to prolong the life of the new glass (now don't tell ALL of my secrets) use armor-all, car wax, even pledge (the wood stuff) on a rag and buff the glass. Just a dab will do.
I'll keep looking online for the part for ya.
Posted on Feb 15, 2008
SOURCE: Copying with page feed results in a vertical line on every page
There must be a strip of glass about one inch wide, next to
the large glass. There is the problem !
Clean that strip thourougly. When you use the feeder the pages
are scanned thru the small strip of glass.
Posted on Mar 28, 2008
SOURCE: Print Problem - vertical lines
I have MFC 7820N. Noticed same problem as other when making copies. Vertical line used to appear.
Open the Scanner where you can see the glass - Flatbed ( where you put the documents to copy)
Make sure that Glass is Clean.
Now make there is Glass on left side about 1x9 inch. Make sure this glass is clean. I had rubbery stain on that I had to rub it off.
Vertical line does not appear when I make copy from Feeder or Flatbed.
Posted on Dec 15, 2008
leroyal
  • 2120 Answers
SOURCE: mfc-7420 Black Line horizontal across paper in 3 places
try moving the small blue slider on top of the drum cartridge side to side 10 times.
Posted on Mar 10, 2009
Arius
  • 446 Answers
SOURCE: Xerox WorkCentre 4150, 3 vertical white lines in all feeder scans
the problem is in the scanner, open it up and see if you can find any smudges, and clean any obstruction, any ink, liquid eraser residuals, can cause this part to appear as lines on your copied faxed image.
dont concentrate on the printer this is a scanner problem
Posted on Jul 28, 2009
Horizontal line on printed page
When you use the flatbed the copy is perfect because the ccd sensor is under the glass cover and obviously is free form dust/ dirt.
On the other hand if you use the feeder the ccd sensor is located in between the roller assembly (not sure exactly for this model).
This means that the page is scanned by the ccd in the feeder, any dirt on the ccd will appear as a black line. I assume that you are feeding papers from the side and not from the top that is why you get a horizontal line.
A quick test to see if the ccd sensor is dirty is to feed the paper from the top side to the feeder. If you get a vertical line it is a proof that your ccd sensor needs to be cleaned.
The worst case is that the sensor in the feeder assembly has a tiny spot that is damaged and it is causing the black line.
So , first try the test, then open the feeder assembly, locate the ccd and clean it. Hope that this helps.
Aug 31, 2016 | Samsung Xpress SL-M2675FN Laser...
My Toshiba has horizontal lines on bottom of screen and burs in and out on bottom also? What could be wrong with it?
Check and replace damaged component/s at its horizontal scan output section circuit. Check the LOT (Line Output Transformer) too for damage. Replace the horizontal scan output transistor. Check the input voltage to LOT. If the voltage is absent check the feeder resistor; if any. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Type in this key phrase " my service table today " in the search box at the top right of the display window of the home page, to get gathered some pages which has the details of practical experiences to the author of that site.
Feb 15, 2016 | Toshiba Televison & Video
Copier leaves a black line when printing through the top paper feeder. Ok coping from the flatbed
When copying from the feeder the page is fed across a fixed point at the head of the flatbed. Any dirt etc on the glass at this point can present as a dark line running vertically down the printed page. When copying from the flatbed, the scan head is moved down the page so any dirt on the glass will only appear as specs. Try cleaning the glass, especially at the head of the flatbed where the feeder is loading the page to be copied.
Jan 12, 2014 | Office Equipment & Supplies
Scanner leaving black streaks
There are two possible fixes.
Download the latest firmware update by CLICKING HERE
The following is provided by courtesy of Lexmark:
Problem Vertical lines; Auto document feeder scan anomaly; ADF scanning problem; Scan issue; Scanner issue; Visible line; Streaks show on page; solid line down the page; Top to bottom line; Smudge runs down the page; Opaque line; Broken line; Bar all the way down the page Solution Overview
This article provides the self-diagnostic steps necessary to evaluate top-to-bottom streaks that appear when copying or scanning.
Important! This is seldom a scanner hardware failure.
The main reason for this anomaly is debris or marks on the scanner glass that is used for Auto document feeder (ADF) page scans.
Printed or Scanned Page Illustration
Who should consider this article?
Any user of an MFP or All-In-One printer experiencing the following symptoms:
  • -Vertical lines only when using the Autodocument Feeder (ADF).
  • -Observed with any type of scan job (e-mail, ftp, solutions, fax).
  • -However, normal expected output when the page is scanned from the scanner flatbed.
ADF scan behavior
Think of it this way:
  • -The page is pulled from the ADF.
  • -The moving page slides across an ADF-designated portion of glass.
  • -The image sensor, which is located under the glass, reads and interprets the moving page's contents.
  • -Contamination on this ADF glass is seen by the image sensor for the entire length of the page.
  • -The image processor interprets the image sensor's repeated capture of this contamination as a vertical solid line.
  • -Any ADF scan function now exhibits a vertical line.
Suggested Diagnosis and Fix
Step Action 1 Locate the portion of the glass designated for ADF scans.
HINT: The glass location differs by model. This area is often separate from the scanner flatbed. Please reference User's Guide for more information if you are having a difficult time locating this designated area.
2 Perform a visual inspection for any of the following recurring culprits:
  • -Clear adhesive tape
  • -Glue
  • -Ink pen
  • -Paper
  • -Marker
  • -White out
  • -Staples
  • -Environmental dust or dirt
HINT: Ink marks can be especially hard to see and almost translucent at first sight. However, the image sensor (CCD) registers them as a mark. 3 Use a clean, soft, moistened cloth to thoroughly clean and remove any marks or debris. 4 Inspect the underbelly or underside of the ADF for any marks or debris. 5 Perform another scan to see if cleaning the glass alleviated the issue. 6 Repeat the procedure if a vertical line still appears.
Remember! Printing and scanning from the scanner flatbed work fine.
7 This time, place an intentional mark on a blank sheet of paper and take note of its location. Now place that sheet of paper in the ADF and make a copy.
8 Evaluate the distance of the vertical line to the your mark. 9 Inspect that area of the glass for further debris or marks and clean as necessary.
Other Possibilities
If... Then... Vertical lines appear only when printing... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear when you lay the page on the flatbed... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support. Vertical lines appear on ADF-fed printed copies, but they do not appear on scan-to-network [e-mail, FTP, folder (PC), solutions]... Consider other printer-related topics such as toner cartridge, charge roll, photoconductor, transfer roll, or fuser. Contact Lexmark Technical Support.
May 01, 2012 | Lexmark International LEX90T9005 Inkjet...
4215 all in one office yet. When making a copy
Sounds like you're having a problem with the automatic document feeder. The scanner is continuing to scan but the paper is not advancing as it should during the first part of the infeed. Check to see if something is inside retarding the path of the scanned document. Or it could be worn rollers in the ADF.
Jul 18, 2011 | HP Officejet 4215 All-in-One Color Photo...
2" black horizontal line appears on paper when I fax, print,
Check the wondow where the paper passes to be scanned. You will probably find some debris or white out stuck on the glass. That is usually the cause of vertical lines on sent faxes.
Sep 17, 2009 | Office Equipment & Supplies
A line appears down the length of the page on all copies, printing and scanning. How do I get rid of the line?
All you need to do is clean the top feeder which opens into two parts. make sure you clean the black rollers as well as the small strip of glass you will find when you open the second part of the top feeder . don't be afraid to pull open the top feeder it won't break
Jun 01, 2009 | HP OfficeJet 9130 All-In-One Thermal...
HP Laserjet 3330 printed dark page especially around the middle
Does this happen both when copying and printing?
For printing solution, try another toner cartridge.
If lines continue to appear when copying (primarily through the automatic feeder) then lift the auto feeder, and clean the glass -mainly the narrow piece on the left side.
please rate solution :)
Apr 07, 2009 | HP LaserJet 3330 All-In-One Printer
Mar 26, 2008 | Canon PIXMA MP780 All-In-One InkJet...
22 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
