Question about Avermedia Avervision VP1 Document Camera Operation 275MMX100MMX360MM VISIONVP1 VIS
The document camera will not focus, not even with autofocus. I powered off, changed the cord that attaches it to the projector,... The computer projects clearly through the projector, so it's the VP1
Why does autofocus keeps moving in and out on some slides
The autofocus system isn't really "autofocus". It is a measuring system - you manually focus the first slide, which sets the distance from the front of the slide in the gate to the back of the projection lens. By the focus motor moving the projection lens, subsequent slides will maintain that same distance. Continuous focus adjustment suggests that:
1> The curvature of the slide is changing because of the varying heat absorption rate of the transparency.
2> The autofocus system is out of calibration.
3> The autofocus system has a bind (it is being restricted from free operation).
About the only thing a user can do is to make sure ALL slides are oriented the same way in the tray. Beyond that, you will need a service manual and 2 or 3 specialized tools. Parts and tools can be purchased from: www.micro-tools.com
Good Luck !! jim
Jun 24, 2014 | Kodak Carousel 5600 Slide Projector
Chords needed for elmo 400af
You are a teacher, and you don't know the difference between a chord and a cord ? Amazing. I think anyway you mean a lead - the one you require has a plug on one end to fit the projector, and a plug on the other to fit the camera. Look in the respective manuals.
Jul 17, 2017 | Elmo Projectors Elmo Ev-400 Af Video...
yes, but i dont even have a cord yet. what cord should i buy?
Sep 22, 2012 | Elmo Projectors Elmo Ev-400 Af Video...
Why wont my Nikon af nikkor 70-300mm G lens autofocus its self with my D5000 camera
The D5000 does not have a focus motor in the body, relying on the lens to have one. The old 70-300mm G lens does not have a focus motor, relying on the camera to have one. Thus, this combination will not autofocus.
The newer 70-300mm AF-S G lens, as well as the even newer 70-300mm VR AF-S lens, do have the autofocus motor and thus will autofocus on the D5000.
Dec 26, 2011 | Nikon AF 70-300mm f/4-5.6 G Nikkor Lens
I have a weird problem. When i put the 50mm 1.8 on my D90 it continues to autofocus even when I switch the camera body to M mode instead of AF with the switch. I would like to be able to manually focus...
You probably have a problem with the A/M switch on the body-- flipping that switch should extend or contract the autofocus pin that drives the lens. This particular lens doesn't have its own focus motor, so there's no way that it could be focusing on its own without the pin from the body driving it.
Try taking the lens off of the camera and looking at the autofocus pin as you flip the switch from auto to manual focus.
Mar 10, 2011 | Nikon Normal AF Nikkor 50mm f/1.8D...
How to focus my document camera
  1. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  2. If your Camera has Auto focus, Press the auto focus button on your document camera's control panel.
  3. Reset your camera to Default by Pressing MENU > Default > Yes > Enter. Then Power-Cycle your camera.
  4. Check your output device's focus adjustment.
  5. Power-Cycle your AVerVision Document Camera to reset the focus motor.
  6. If Manual Focus adjustment is available on your camera's remote control, try adjusting back to focal point from the remote.
  7. If your camera has a Manual focus knob, manually adjust the focus by turning the focus knob located on the camera head.
  8. If adjusting the focus knob does not focus the image, please click here http://support.averusa.com/kb_article.php?ref=9869-UMJQ-1105 for instructions on how to fix the focus ring.
Feb 02, 2011 | Avermedia AVERVISION 300AF+ PORTABLE...
Will not take pictures
Does your lens try to focus or it doesn't try at all? You will have to understand that for the camera to autofocus successfully, theere should be adequate light and contrast. That means, autofocus often fail to focus even colored walls or objects under dim light. If you tried all this in daylight, outdoors, then the autofocus sensor is faulty. Please reply with details of how you tried the af.
Dec 16, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Lost AutoFocus
Set focus - it is autofocus is it not? Take a few pictures and check whether they are sharp or not Also make sure your finger is away from the sensor window when holding the camera
Aug 07, 2007 | Samsung Digimax S630 Digital Camera
Focus malfunction
THere is a little switch on the back of the camera, just under the area selection Dpad. Make sure it is not in the 'L' setting. This locks the selected autofocus area.
Sep 14, 2005 | Nikon D70 Digital Camera
Avermedia Avervision VP1 Document Camera Operation 275MMX100MMX360MM VISIONVP1 VIS Logo
103 people viewed this question
Top Avermedia Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Avermedia Office Equipment and Supply Expert? Answer questions, earn points and help others
