Question about GE JGBS23 Gas Kitchen Range
GE Range JGBS 23...The Broiler does not shut off
GE Range JGBS23. The broiler does not shut off when I turned the knob to off. It has been on for over two hours.
  • 1 more comment
  • cyrusjavid Jun 20, 2009
    It is a gas range. How can I unplugg it? I can't find the gas valve shut-off.
    Thank you for all your help. I called the fire department.It is getting dangerous. I will keep you posted.
    Fire Dep. came in and shut off the gas valve and unplugged it. Now I need a new range. Thank for all your help.
  • 1,165 Answers
The switched has malfunctioned. you must unplug the stove to turn it off do not leave it on be very carefull unplugging it do not touch the prongs its 220 volts?
Posted on Jun 20, 2009
  • 1 more comment
  • Steve Sweetleaf
    Steve Sweetleaf Jun 20, 2009
    trace the line from back of stove find regulater and turn it off you either have a tank or meter if u have a tank it has a shut off.so does the meter on a pipe get it off its dangeruous especially gas.write back
  • Steve Sweetleaf
    that was my next call to u gas company or fire department that gas is craeting alot of carbonmonozide open windows
  • Steve Sweetleaf
    no problem glad all is ok now u can rst peacefully.take car
Broiler won't turn off unless you unplug the entire range.
Walt,
Sounds like you have something wrong with whatever switches on your broiler. If it is a turn knob controller, you would need to replace the that controller behind the panel. If it is a digital controller, you will need to replace that controller. Hope this helps!
Jun 22, 2015 | GE Kitchen Ranges
GE oven/broiler problem: oven works, broiler does not light. Model JGRPP17WEW4WW
This would also go for the broiler also...
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or
Oven not Heating
Oven Problems
Replacing the Igniter
heatman101
Dec 24, 2010 | GE JGBS23 Gas Kitchen Range
Have a GE gas range. Broiler doesn't work while
First clean the terminals at the control and check for tight wires at the incoming terminal block. Check the neutral wire for a good conection. If the ignitor reads less than 3 amps it does not have enough resistance to open the gas valve. Turn the gas off. Put a clamp on amp meter on the broil ignitor wire. Turn the broiler on. If less than 3 amps.replace the ignitor.
Sep 30, 2009 | GE JGBP28 Gas Kitchen Range
BROILER ELEMENT WOULD NOT TURN OFF WITH OVEN
I just had the same problem! I would not have known that the broiler was still on, since the red light was off, except that the oven got so hot that the drips started to burn. The only solution was to turn off the circuit breaker.
This sounds like a serious safety issue!
My guess so far is that there is a broiler relay that has shorted in the on position and will need to be replaced. Until then I cannot use the stove or oven.
Apr 30, 2009 | GE Spectra JBP78 Electric Kitchen Range
Viking pro. gas range/oven leaks when all knobs turned off
check both oven ignitor and broiler by turning the oven first, and time the time that the ignitor takes before the flame lights up, it should not take more then 60 to 70 seconds, and do the same to the broiler.the one that takes the longer passing that mark of the 70 seconds needs replacing it 's not getting hot enough to light the burner on time that's the one that passes gas with out igniting. replace that one.
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven will not shut off broiler element stays on
The control knob more than likely operates a relay that has gotten stuck in the energized position. If this isn't the case then the Temp sensor or thermostat probably shorted internally. Unplug the unit before attempting any work.
Nov 16, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
GE JGBS23 Gas Kitchen Range Logo
448 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
