Question about Samsung DV448AEE Electric Dryer
Samsung dryer check filter flashing and turns off
Samsung dv331aew/xaa check filta
You can still operate it while it is drying.There is a bad sensor much like an O2 sensor on a car.
Jan 24, 2015 | Samsung Dryers
LG DLG5988W
check your door interlocks and connections
Mar 15, 2008 | LG DLG5988 Gas Dryer
Turning off and on in timed cycle
Sounds like you have it on wrinkle prevent, a feature that keeps your clothes from wrinkling before you pull them out of the dryer. Check your user manual.
Nov 07, 2013 | Samsung Dryers
Lights all flashing while running, buzzing sound
Check to make sure there is no lint buildup and the filter is clean.
Mar 31, 2012 | Samsung DV218AEW Electric Dryer
Light flashing says check filter. Dryer wont heat up? What filter and where is it located
The filter screen check light is just a reminder indicator. It will always come on whenever you turn on the power. As for the heat, you didn't state whether it's electric or gas.
Jul 15, 2011 | LG Dryers
Dryer not working, indicates "lint filter" When I try to use the dryer (Bosch Nexxt), i first turn the dryer to the setting desired (regular or perm press, and time) it immediately has the "lint filter"...
This is a common complaint with this dryer.The probe generating this problem,is at fault.It likely has a film on it,from the dryer sheets.Remove the lint screen,and wipe down the probe that sticks into the air box.Should fix the problem,if not ,replace the probe.
Sep 01, 2009 | Bosch Nexxt WTMC 3300 Electric Dryer
Dryer won't power up, says check filter
Check the door switch first.Than look for possible thermal fuse has cut off.
May 22, 2008 | LG DLE2514 Electric Dryer
Dryer shuts off on own lights blink
Turn off breaker wait an hour turn back on.
Apr 03, 2008 | LG DLE2514 Electric Dryer
Samsung DV448AEE Electric Dryer Logo
51 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
