Question about Brother Disney PE-400D Computerized Sewing Machine
Bother PE400D
The bottom thread will not connect with the top .The window says it the tension.
akylas
  • 26 Answers
SOURCE: Brother PE-150V bobbin thread
For embroidery, and zig-zag, and because the needle makes side movements, it needs more needle thread.
So try to keep you needle thread not very tight,
and tight up your bobbin case tension more, so that the two threads meet under the meterial.
Posted on Jun 10, 2008
SOURCE: Tension problem Bottom thread is loopy and sloppy
SALUDOS, MI MAQUINA HACE ESACTAMENTE LO MISMO UN DIA DERREPENTE DEJO DE BORDAR Y TIRA TODO EL HILO, LO HACE BOLAS POR LA PARTE DE ABAJO, Y DESCUBRI QUE SE ROMPIO UNA LAMINITA QUE LLEVA FRENTE A LA LANZADERA DONDE SE COLOCA LA BOBINA.
TAL LAMINITA SE LLAMA RESORTE PERO NO TIENE NUMERO NO LA HE PODIDO ENCONTRAR, DICHO RESORTE VA INSTALADO AL LADO DERECHO EN EL MISMO LUGAR DONDE ESTA INSTALADO EL LASER. AGRADECERIA ME DIERAN EL NUMERO PARA PODERLA COMPRAR. MIL GRACIAS.
Posted on Aug 15, 2008
louislevel_2
  • 374 Answers
SOURCE: Thread looping on top and bottom of fabric
hi! there,
on this condition,you can avoid wasting time and material try on this, the problem is your set up of tension thats why.,but you should follow upper theading. see figure,c978815.jpgthis just sample of exact threading,next bobbins set up see fig.the thread should be clockwise rotation on winder5a00a72.jpgfollow this set up,and upon inserting be sure
you have clean feed dogs and shuttle race free from fabrics and threads chips.set dial tension to #3 to #4 and stitch dial to #12.then try this set.and you can watch on you tube sewing. try this stuff on internet address type www.youtube.com then on search box type sewing machine,have enjoy and have a nice day.don't forget to rate me,
Posted on Apr 14, 2009
  • 55 Answers
SOURCE: On my Brother sewing machine The tension is all
check lower tension, make sure upper tension is correctly aligned
Posted on Nov 23, 2009
  • 1116 Answers
SOURCE: I get loops on top and/or bottom of fabric during
Top tension back to 4 and leave the bobbin tension as is.
Make sure you have a new needle for the type of fabric being sewn installed with the flat side to the back of the machine. A bent needle can sometimes go unnoticed.
Always thread the machine with the presser foot up and this will give proper tension to the stitch.
Check the manual to be sure you are threading correctly (always with the presser foot up) and that the bobbin thread is feeding in the correct direction from the bobbin spool and through the guides.
Take hold of the thread at the needle as you lower and raise the needle to pull up the bobbin thread. Take both thread ends under the presser foot and to the back of the machine.
Posted on Mar 11, 2010
My bottom tention of Bernina Deco 340 is to loose. How to I correct is. The top treat shows to much at the bottom
Um, the top thread is showing on the bottom of the fabric? The top tension is too loose. The two threads create a tension battle, one pulling against the other. To pull the bobbin thread up, tighten the top tension. The tension is accurate when the two threads meet "in the middle" of the fabric. On thinner fabric, you might see a tiny spot of bobbin thread on the top and a tiny spot of top thread on the bottom.
Aug 24, 2017 | Bernina Sewing Machines
The bottom thread in my sewing is looping and baggy.
There are several reasons to this. First, your top thread is not at equal/adequate tension and may be routed improperly. Second, your bottom thread has very little tension due to either improper shuttle adjustment and/or missing screw at the tension plate. Additionally it could be caused by excessive accumulation of fluff, which prevents tension mechanism from doing its job. In summary I suggest checking top and bottom threads for proper routing and tension in accordance with machine manufacturer's specs. I am almost positive that you will find a problem there. Good luck and report back if needed.
Dec 11, 2014 | Sewing Machines
How do I fix the bottom bobbin thread
THE BOTTOM AND TOP THREADS ARE IN A TUG OF WAR. WHEN THE TOP IS TOO LOOSE THE BOBBIN WILL BE PULLING HARDER THAN THE TOP THREAD SO A GREAT DEAL MORE THREAD WILL END UP ON THE BOTTOM. TO CORRECT THIS YOU INCREASE THE TOP THREAD TENSION. IF THE TOP THREAD IS PULLING HARDER THAN THE BOTTOM THEN A GREAT DEAL MORE BOBBIN THREAD WILL END UP ON THE TOP. TO CORRECT THIS YOU WOULD LOWER THE TENSION ON TOP.
Dec 12, 2014 | Sewing Machines
How to thread the bobbin on a brother vx-810
The sewing on the bottom is loose because you don't have enough tension on the TOP thread. First, make absolutely sure you are threading the machine correctly. Next, while using 2 different colours of thread, tighten the top tension dial one number at a time and then checking the stitching, continue tightening the top tension until the sewing is even on the top and bottom of your cloth.
Apr 02, 2013 | Brother Sewing Machines
I have a singer 7258 that I can not get the tension to loosen up on. The top stitch is straight across and adjusting dial doesn't help.
Hello
Adjust the tension
Load your sewing machine with one color on top, threaded through the needle. Load the second color thread into the bobbin and thread.
Fold the scrap fabric in half, and sew a straight stitch at least 2 inches long. Look closely at the seam. If you see loops of the bottom color thread on top of the fabric, proceed to Step 3. If you see loops of the top color thread on the bottom of the fabric, proceed to step 4.
Loosen the top tension. Since the top tension is so tight, it is pulling the bottom thread up through the fabric. Loosen the top tension by turning the numbered knob on the front of the sewing machine counterclockwise by one number.
Tighten the top tension. Since the top tension is too loose, the bottom thread is pulling the top thread down through the fabric. Tighten the top tension by turning the numbered knob on the front of the sewing machine clockwise by one number.
Sew a straight stitch 3 inches in length. Check the stitching. It is perfect if the threads meet in the middle, and you can only see the top thread on top and the bottom thread on bottom. If it still needs adjusting, go back to step 2 to repeat the needed steps.
Using two different colored threads makes it easier for you to see which thread is being pulled.
Always use proper precautions when working with electrical machines.
Aug 01, 2011 | Singer Sewing Machines
It is the bottom bobbin tension and it is model 621B not 6218 as I had originally typed. The bottom bobbin makes oddles of loops while sewing and the top tension is fine.
What is wrong is that you haven't got it threaded right on top. Try this test, with your presser foot up, pull on your top thead and it should come smoothly, then put the presser foot down and try it. it should hardly move. That way you know that the tension discs are connecting with the thread. Whenever it is not right on the bottom, always look at the top threading, just the opposite of what you think. Also, put in a new needle and make sure that you thread is of good quality and not tangled.
Oct 21, 2010 | Singer Sewing Machines
The bottom thread gets all knotted up when I sew... everything locks up and there is a mess of thread on the underside of what I'm trying to sew. help?
The tension in the top thread is controlled by a dial, and the tension in the bottom thread is controlled by a small screw on a spring on the bobbin. The tensions are supposed to be exactly equal in order to make the stitch perfectly in the middle of the cloth. Uneven tension will pull the stitch up or down from there. You can tug on each thread to feel how much tension there is. Often the bottom will get too much tension by just inserting the bobbin upside down. Leave the bobbin door open, and watch the operation. The top thread is pulled down around the bobbin. See if it is getting caught on anything?
Dec 18, 2009 | Singer 3116 Simple
Thread looping on the bottom
Thread looping on the bottom means you have a problem with the top thread. In your case there is no tension on your top thread. Take all the thread out of the top and start threading over. Make sure you follow the correct path and make sure the thread goes through the tension discs. Then at the time of sewing, make sure your foot is down (this closes the tension discs and gives the thread the tension.) You may have worked on the tension setting while not realizing the thread was not in between theses discs, so also make sure the top tension disc setting is in the average before sewing.
Good luck.
(If you see loops on top, it means you have a problem with the bottom thread)
May 25, 2009 | PfaFF Tiptronic 2040
CONSEW 206RB5 TOP THREAD NOT FORMING STITCHES AND BREAKING
you have your thread tension too tight that's why it is pulling the bottom stitch all the way through it looks good from the bottom but not good on top. Its pulled the stitch all the way through the material.
I had my own upholstery shop 18 yrs and tension gets you every time.Just loosen the top tension.
Jan 18, 2009 | Euro-Pro 8260 Mechanical Sewing Machine
Bernina 1008 - tension problems
Make sure the presser foot bar is UP before you thread the machine, otherwise the thread doesn't connect propertly with the tension discs. Top thread should reel-off in clockwise direction.
Jan 02, 2009 | Bernina 1008
Brother Disney PE-400D Computerized Sewing Machine Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
