Question about Dell 1720dn Laser Printer
My dell 1720dn printer is continually going offline. it is not networked, it;s connected via usb, straight into the pc. the other message says no toner level available. before finally printing, I received a garble text on one page then the printed copy next. the message box shows it's spooling
  • Dell Master
  • 6,487 Answers
OK since its only connected via usb cable try this, Go to control panel and go to printers and faxes then click on Add a printer select local printer and follow the wizard and if the wizard detected the printer just go ahead and reinstall it that way and when its finish try to print and that should correct the problem,,,
Posted on Jun 20, 2009
HOW TO FIX...PRINTER IS OFFLINE BUT IT IS ON...WE ARE UNABLE TO PRINT.
If you are getting a status message as the printer is offline on your pc,and afterward you can't ready to print the reports.
Steps to Resolve the Printer Offline Issue:
Step 1:
At first, you need to check your network through the HP Scan Doctor which encourages you to discover and fix the printing issues.
Steps To Run the HP Scan Doctor
    •Open the HP Scan Doctor tool by double tapping the symbol.
    •Start- - >Select your printer- - > Fix Printing
    •Then the list of issues displayed on the screen as result.
    •If the tool shows the white checkmarks at that point there is no issue.
    •If the tool shows the white wrench then the issues are found and repaired
    •If the tool shows the yellow shout point then the issues are found however that can't be solved or skipped.
    •If the device shows the red stamp then you have to take after the on-screen guidelines to determine the issues.
    Step 2:
      Set Your Printer as Default Printer
      •Search your gadget on your PC and select your printer and uncheck the Pause Printing and Use Printer Offline
    •If you can capable print implies your printer is online.
    Officejet 4650 keeps going offline then proceeds with following step Step 3:
    Check Whether You Connect With Correct Port
      •Go to printer- - > Printer Properties - >Port
      •For USB association utilize USB or DOT4
      •For Network Connection use WSD, organize, Standard TCP/IP Port Step 4:
      •Update the printer firmware which may resolve your issues
      Step 5:
      •Manually connect the wired or wireless connection
      Step 6:
        •For network connection just you have to add the second printer to your Windows.
        •Select your printer - > Properties - >Add Port - > Standard TCP/IP Port - > Next port
        •Now you can ready to print implies stop the troubleshooting. Still get the same issue mean you need to connect the printer customer support via +1-800-836-3987
Jan 08, 2016 | Office Equipment & Supplies
Want to reset assigned Ip address on a dell 1720dn printer
When the Ready/Data light ready_light_icon_0.jpg is solid, press the Continue button continue_button_0.jpg to print a menu settings page and a network setup page.
Select TCP/IP heading on the network setup page.
There you can change your IP address.
Aug 10, 2011 | Dell 1720dn Laser Printer
PRINTER GOES OFFLINE
cheak printer connection is proper & paper setting is proper then still printer is offline may be a problem of sensor or datacable give me a status reply
Apr 19, 2011 | Dell 1815dn All-In-One Laser Printer
1720dn Laser Printer: printer offline. unable to set online....
I Open my browser....I signed in to my router as administrator ....
Mine is 192.168.1.1 ....
I went to status in my router ....
Then to local network ....
Then to DHCP Clients Table ....
This is how I found what printer address the was.... Then I typed the printer ip address into my browser
Mine happened to be 192.168.1.105 ....
Yours will probably be different....That got me to the 1720dn printer menu ....I clicked on Configuration ....
I clicked on Print Server Settings
I clicked on TCP/IP
I clicked on Set static IP address.
I changed IP address from 192.168.1.105 To 192.168.1.125
and Submit....Now you can get to the printer menu at 192.168.1.125
Go to run....
Printers & Faxes
Right click on Dell laser printer 1720dn
Properties. Ports ....
Add port ....
Double click on Dell Enhanced TCP/IP ....
I named the port My dell laser 1720 dn....Where it said enter a single IP address or host name I entered the new address 192.168.1.125
the clicked OK ....
Properties....Ports
Choose your new port ....
May 06, 2010 | Dell 1720dn Laser Printer
Keep getting "Printer Offline" from Dell 1700 printer
go to the start menu
click on run
type services.msc
on the list go to Print Spooler
double click on print spooler and select automatic on startup type
now press on start.
if that doesn't work go to this microsoft website and click on the Fix It icon with the little man holding a wrench. run this and it will fix it.
Dec 03, 2009 | Dell 1700n Laser Printer
Printer is connected to wireless network but getting offline mess
1st you try to ping the the wireless device ip address if you getting the replay that means your wifi is working fine .check the usb cable also for testing directly install on your pc and check it.
Nov 17, 2009 | Canon PIXMA MP600 all-In-One InkJet...
Dell printer 1710 n .
In Control Panel - Printers, Right-click the Dell 1710N and remove check for Offline.
Jun 12, 2009 | Dell 1710n Laser Printer
Dell Printer 1720dn - Unable to reset drum counter..
"Press & hold the cancel button untill all lights start flashing in a sequence and then i release the button and close the front cover." "DO NOT release the button, but continue to hold down it while you close the front cover.
Printer offline: Right click on your printer in the "Printers and Faxes" folder and "UN Check" use printer off line,
May 11, 2009 | Dell 1720dn Laser Printer
Will not print ''offline error''
are you attached to this printer thru a network cable cat5 cable or by way of a usb cable if network you need to print a settings page by holding down on of the buttons on the printer and check to be sure tcp/ip is set to static not dhcp and that the address matches what you have set on the pc side
Mar 26, 2009 | Dell 1720dn Laser Printer
Dell 1720dn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
