Question about Ricoh Aficio Mp C2550 Copier
Remove hard drive from ricoh - Ricoh Aficio Mp C2550 Copier
I wanted to know if the hard drive on a Ricoh Aficio 1018D is a memory or physical hard drive.drive please advise
Most newer printers have a regular hard drive, which retains most information that has been entered. It is advised to remove the hard drive when disposing of the printer.
Mar 02, 2018 | Ricoh Office Equipment & Supplies
I need to locate the hard drive in my old Ricoh Aficio 1018D Sesure Fax prior to disposition
Not all models of the Ricoh Aficio have a hard drive, but if your model has it, it will be located on the rear left side of the machine, near where the network port and phone jack (if you have the fax option) are.
To get the hard drive out you would remove the big rear plastic cover, then the gray metal cover beneath that, and then disconnect the hard drive from the controller board that it is mounted on (with the copier off, of course).
Where is the hard drive located on a ricoh aficio 2022
i don't think there is hard drive, but there is memory inside
Feb 02, 2011 | Ricoh Aficio 2022 All-In-One Laser Printer
How do I remove the hard drive from a Lanier LD328c. This needs to be done for security reasons.
You should contact a Lanier or Ricoh service technician to remove the hard drives for you, but if you have to do it yourself the hard drives can be removed by unscrewing and sliding out the controller board (on the right side of the copier). The hard drives are connected to the controller board by three screws and four connectors.
Sep 23, 2010 | Lanier UNKNOWN
Describe how to remove a hard drive from Ricoh Afcio 2045
Remove the back cover, It should be located directly on the right of the machine. Just requires a phillips screw driver. REMOVE POWER FIRST .
Jul 26, 2010 | Ricoh Aficio 2015 Copier
Hard drive scrub - Ricoh 1022.
Ricoh offers a Data Overwrite Security kit, but I don't think it will work with the 1022. Your best bet is to remove the hard drive, attach it to a computer, and wipe it with a program such as CCleaner or Hard Disk Scrubber (both of which are free to download).
Jun 02, 2010 | Ricoh Aficio 2022 All-In-One Laser Printer
I want to buy a Ricoh 1085 that looks in good condition, but the hard drive was removed for security reason, Will it work with out the hard drive?
No, the 1085 needs the hard drive to run. You're better off trying to find a newer copier anyway -- the 1085 is ancient and you probably won't be able to get a lot of replacement parts for it. You can probably find a 2090 or 2105 for a good price -- those machines are still supported and will run for a long time.
May 27, 2010 | Ricoh (400614) 6 GB Hard Drive
My ricoh aficio 2232c was unplugged and when I plugged it back in it keeps saying Please Wait across the screen and doesn't do anything else. Please help
If no error code comes up then you have a hard drive error in your Print controller.
Remove the back cover (unplug machine) remove the cover for the controller (controller is in upper right on rear side of machine and disconnect the hard drive.) Plug machine back in and see if it comes to ready. if so replace the drive, if not controller is bad.
Jan 19, 2010 | Ricoh 6513 Copier
AP3800c ricoh hard drive
The hard drive store some data about your machine but only uses about 200 mb of the 40 gig .you can use the machine for locked , stored , sample , hold prints , it is for mabe if you got 20 users and they dont want to print and everyones doc;s get mixed up , so it holds the job until you go to the rinter and rints it out
hope this helps you
Nov 03, 2007 | Ricoh Aficio AP3800C Laser Printer
Ricoh Aficio Mp C2550 Copier Logo
155 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
