Question about Ovens
I need to put a new door latch on my Beko dv5631 oven
I can't seen to get the manual anywhere, to see how I replace the latch.
Master_Tech
  • 770 Answers
SOURCE: Thermador built-in double ovens p/n SCD 302 TP
post your email i will send u the manual
Posted on Jan 26, 2008
Techjoel
  • 79 Answers
SOURCE: latch does not catch on oven door.
Possible solution: The clean oven safety latch is in the latched position already. Move latch to opposite side and try closing door again. Latch not usually needed except during cleaning cycle.
Good luck,
Techjoel
Posted on May 08, 2009
SOURCE: remove beko oven door
Top oven of my double wall oven is stuck on lock mode. How do I get the door to unlock so i can open
Posted on Jul 15, 2009
kel1guy2002
  • 3740 Answers
SOURCE: Moffat 3000 oven
Can you please provide a Model number. Moffat has a huge appliance line. I do realize this can also either be a gas or electric oven. Possibly E32MS/2 or G32MS/A25 as a model number. Thanks
Posted on May 01, 2010
  • 327 Answers
SOURCE: Oven door will not latch
STEP 1:Grasp the handle on the Whirlpool oven door and open it to the first position.This will be a 4-inch opening
STEP 2: Place your hands on either side of the oven door
STEP 3: Pick up the door from the first position gently.Keep lifting the oven door until the door is clear of the hinge.
Thanks
Posted on Jun 02, 2010
How do i refit the main oven door lock, i need a step by step guide or something?
Oven Door Latch (part #9761013) - How To Replace ...
? 4:32
https://www.youtube.com/watch?v=rbMZ8NgiKm8
Oct 31, 2012 - Uploaded by AppliancePartsPros
Buy the new Oven Door Latch 9761013 ... How to replace yourcooker hinges. - Duration: 8:50. how-2-repair.com 84,238 views. 8:50.
How To ReInstall Your Oven Door - YouTube
? 2:12
https://www.youtube.com/watch?v=EBhJk85mc1Q
Dec 28, 2010 - Uploaded by HavillFiles
Did you remove your oven door and now you can't get it back on? The manufacturers forget to tell you about locking the latches first! ... Oven Door Hinge (part #W10347466)-How To Replace - Duration: 9:25. ... Hygena / Whirlpool / Electrolux / Phillips ovencooker door removal (others with same hinge) ...
How To Replace an Oven Door Lock Assembly ' Repair ...
www.searspartsdirect.com/repair.../how-to-replace-an-oven-door-lock-as...
Main Menu; Recently Viewed ... This step-by-step range repair guide shows how toreplace the oven door lock motor assembly for a self-cleaning oven. The door lockmotor assembly locks the latch to keep the oven door shut during the ...
Jan 08, 2016 | Ovens
Oven not working
F9 Door Latch Error Check latch and latch circuit
F9 Door Lock Warning Check door lock circuit or Replace Clock
F9 Program with door circuit Check wiring
4 different brands of stove indicate an issue with the door lock circuit. Hunt down the the tech manual for your machine on my youtube channel video
May 05, 2013 | Ovens
We have a 24" wall
The problem is due to the door latch and specially one of the two micro switches is not contact properly that is why when you cracked little the oven can work little better. So all you need is check the latch at the back and if nessesary replace the latch
Also you can find a new latch at the links and here
Sep 19, 2011 | Kenmore Ovens
Upper oven turn on and off then puts f9
F9 indicates a problem with the door latch circuit. Holding the door in the open position, push in the door switch until the cavity light goes off. Put the upper oven in the clean cycle and watch to see if the door latch cycles.
If the door latch mechanism is working correctly, the latch should stop in the closed position (the door will not shut all the way now). If the door latch does not even move and the F9 error appears, which is highly likely, you definitely have a problem with the latch circuit. (If the door latch did cycle to the closed position, cancel the self-clean mode to cycle the latch back to the open position.)
First, check that there are no loose wires on the door latch switches. Also check that none of the wires are pinched between the latch mechanism and the Oven Control Unit. Repair any wires that may be damaged and reconnect any connections that maybe loose. If you have just made any repairs, try putting the oven into bake mode with the door closed and test.
If there was no wiring that needed repaired and all connections looked good, test each of the door switches to be operating properly. Disconnect the wires from one switch at a time and perform a continuity test on the switch. In the open position your meter should read "OL", in the closed position it should emit a tone, or read "0.0". If either switch fails this test, replace the switch and test your oven again.
If none of the above conditions exist, the Oven Control is not reading input from the door latch sensor and needs to be replaced.
Apr 15, 2011 | Ovens
We have a wall mounte singe maytag oven. When I go to set the oven temp. the panel reads"door" and I am unable to set it. I have opened/closed the door and put the lock lever on and off, but to no avail....
Hello there:
Here is all of the possible error codes for the door and what they mean and what to look at
DOOR Bake or Broil
· Defective latch switch
· Shorted wire from ERC 10-pin connector, pin 10 to ground
· Door latched Replace latch switch if defective.Replace wire from 10-pin connector if defective DOOR Self-Clean
· Open wire from ERC 10-pin connector, pin 10 to ground
· Door not latched Replace latch switch if defective.Replace wire from 10-pin connector if defective LOCK Not in Self-Clean
· Oven temperature sensor resistance too high Check oven temperature sensor resistance, wire harness and connections, replace defective component
Sep 28, 2010 | Maytag MEW6527DDS Electric Single Oven
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Oven door lock pin broke
how did you fix it?? i have the same problem!! :(
May 12, 2010 | Ovens
Beko dvc62 main fan oven stopped working, doesn,t get hot but fan still works, it tripped circuit breaker and hasn,t worked since, peter
This tutorial will show you how to check your Beko element and how to replace your Beko cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
    1.Your Beko oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Beko manual.
    2.If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
    3.When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer
Paul is from the Naturally he would appreciate beer How to Repair Home...
Jan 14, 2010 | Ovens
Ovens Logo
14 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
