Question about Bosch Washing Machines
Bosch alarm 3h - Bosch Washing Machines
Turning off bosch axxis washer alarm
The alarm is a tricky one, especially if it went out without any reason. You should either call a professional to solve it, or check the manual/troubleshooter below this article:
Bosch Axxis Washer Manual
Sep 29, 2013 | Bosch Washing Machines
Bosch alarm pnl 488
call product company & have them walk you threw the steps or send some who can do it for you
Jun 06, 2013 | Home Security
Display flashes 3h
Hello sir; H3 code require a reset procedure as follow;
press "clear", "expoaure", "clear", "exposure", then enter 14 press start, it will back to normal.
Oct 02, 2009 | Sharp AL-1642CS Copier
END OF CYCLE ALARM
The manual on my Bosch 500 plus 4.2 says to select a cycle and then push and hold two option buttons until you hear the beep to turn off the audible end of cycle alarm. Hope this works for you! P.S. It says not to try this with a load of laundry in the machine.
Jan 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
How do I turn off the alarm on our Bosch tumble dryer, it's a Bosch Logixx
We had a similar problem with our Bosch dryer... every now and then when we were using the dryer an alarm would go off and it would stop drying. We checked through the manual and it had no information. Then one day I noticed that there was a flap on the end of the exhaust vent outside the house. As an experiment I propped the flap open so that it never fully closes.  Now we never have the problem with the dryer. I suspect what was happening was that as the dryer was reaching the end of the drying cycle it was pumping out less and less exhaust to the point where it was too weak to open the vent flap, and the build up of exhaust in the ductwork triggered the alarm. I don't know if that's what's causing the alarm with your dryer but its worth checking.
Aug 23, 2008 | Bosch Dryers
Sharp AL-1631 has 3H error code
3H error means overheating...what you can do is supply new fans or clean the unit for dust and others. check for the exhaust fans if its still working. this will reslove your problem.
hope this helps
Jan 27, 2008 | Sharp AL 1631 Copier
Washing Machines Logo
14 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
