Question about Dacor Microwave Ovens
Microwave stops after 1 minute
It could be stuck on "easy minute" setting. It stops on any setting after 59 sec to 1 minute.
SOURCE: Shuts down after 59 sec
It was the damper motor. $10 part fixed it. Thanks
Posted on Mar 04, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Clock will run down to 1 second of the minute and microwave will stop
The surge probably didn't cause this. This common error indicates a problem in the convection damper circuit. It may be a defective damper switch, damper motor, or a jammed damper door. I have attached a drawing of a typical damper system. If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk You can order parts for Sharp models from Tritronics at http://www.wehaveparts.com.
Posted on Sep 22, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Microwave cuts out after 23 secs
In most cases, this is a problem with the inverter or a bad magnetron.
Due to the lethal voltages used and produced, I do not recommend that an inexperienced person work on these.
I would recommend that you contact your nearest Panasonic-authorized servicer. You can find one here:
http://www2.panasonic.com/webapp/wcs/stores/servlet/vServiceLocator?storeId=15001
Posted on Dec 17, 2007
MicrowaveSvc
  • 9098 Answers
SOURCE: Sharp model R-1871 shuts off every 59 seconds
This is a problem in one of the damper-related components, either the switch or motor or the damper door may be binding.
The damper is a door inside that opens or closes depending on cooking mode. If the controller senses that the door is not in the right position, it will shut down the cook cycle.
Sharp models stop after 59 seconds.
See the attached sample drawing for a typical damper assembly.
We have the applicable service manuals for these models and have uploaded it to our site here and here to help you.
If a switch is all you need, we offer a universal type for only $5 postpaid which you can order here.
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Posted on Aug 30, 2009
Testimonial: "traced to motor for damper. Would not have had a clue without this information provided by fixya"
miket756
  • 2702 Answers
SOURCE: Microwave/convection oven in our fifth wheel will
looks like the timer brain has packed up on you,,
how old is it,, it may be cheeper to just replace the microwave as there not very pricy now,,there is very little inside them that you could fix your self, however,, putting your hand inside the back could kill you? so dont try it, play safe buy a new microwave insted
Posted on Oct 26, 2009
Microwave stops after 59 seconds
Check that a "favourite" setting has not been selected. The unit may think that is the time that you want to cook. Im not sure about your model but see if there is any clear or cancel buttons to clear any pre programmed selections. If not, unplug the machine for 15 minutes to reset the controller and try it again.
Nov 25, 2013 | Electrolux Microwave Ovens
AFTER SETTING TIME COOK TO 1 MIN 60 SEC AND PUSHING START BUTTON 4O SECS MORE IS ADDED, I.E. TOTAL 2 MINS SHOW ON DISPLAY. CAN I RESET THE THE COMPUTER.
There are sixty seconds in a minute, so 1 min 60 sec is the same as 2 min. If you want 40 seconds less than 2 minutes then set it for 1 min 20 sec or for 80 sec.
Oct 03, 2013 | Danby DMW139 Microwave Oven
Hi when i set the microwave at 100 watts for 1 min it starts and stops working by itself when timer reaches 38 sec and it also dosent make the beeping sound in the end.please help
The first thing I would suggest is a hard reset. Unplug the unit for a minute or so. Then plug it back in, set the clock and try again.
If that doesn't work, leave it unplugged for about 5 minutes and try again.
Aug 31, 2011 | Bosch HMT9656GB Microwave Oven
The microwave stops itself everytime at 59 secs if put on for any time over a minute
Change the damper motor and switch. Cost for both approx. $30.00. Must remove cover to gain access to motor & switch.
ZephyrKnight
Feb 17, 2011 | Sharp Microwave Oven Microwave Oven
Stops every 59 sec.
Sharp models stop after 59 seconds. That's the giveaway.
We have the applicable service manuals for some of these models and have uploaded them to our site here and here to help you.
Hopefully these cover your model number, which you didn't mention.
William E. Miller
prototech@usa.net
Jul 07, 2010 | Sharp R-1870 Convection/Microwave Oven
I have a sharp microwave mod.#r-1870 you can set it for 5 mins.it will run 59 sec.then shut down you start it right back and it will run 59 sec. and shut down again.
i think there are some problem occured with the autocut n timer....its a genuine prob go to any electrician...thnx
Feb 26, 2010 | Microwave Ovens
Sharp r96st stops at 1 sec and halts whilst preheating oven
See the attached sample photo for a typical damper assembly.
Info on ordering Sharp UK parts / spares is here.
Jan 29, 2009 | Sharp R-1480 Microwave Oven
59 SEC NEED TO GET FRONT OFF MICRO
If your unit runs for 59 seconds then stops, the problem is the convection damper motor. (Sharp part # RMOTDA222WREZ).
Unfortunately, you cannot access this from the front - the whole unit has to come down as the entire outside cover has to be removed.
This is a pretty major job and the motor (located below and behind the magnetron tube) is rather hard to remove and get back into place. This is probably better left to an experienced technician. You can call Sharp 1-800-BE SHARP for a referral to an authorized servicer.
Jul 22, 2008 | Sharp R-1870 Convection/Microwave Oven
Microwave Ovens Logo
Top Dacor Microwave Ovens Experts
William Miller
William Miller
Jerry Greenberg
Jerry Greenberg
Steven Clarke
Steven Clarke
Are you a Dacor Microwave Oven Expert? Answer questions, earn points and help others
