Question about Hamilton Beach Kitchen Appliances - Others
I unscrewed the screws from the bottom of the toaster but I still can't separate the bottom to clean the inside
  • 351 Answers
SOURCE: clean out bottom
Hi .. turn the toaster upside down. There should be an access door there to allow you to clean out the bottom of the toaster.
Posted on May 04, 2010
espressonist
  • 1711 Answers
SOURCE: Dualit 4 slice toaster.
Yes correct
Posted on Sep 01, 2010
mc1bean
  • 3053 Answers
SOURCE: How do you clean the inside bottom of Sunbeam 6223
Hello, gerald
I was trying to help you out here. Maybe this will help some? I was going backto some customers that asked questions in the recent past and even fartherback. It appeared that no one answeredsome of them, So, I thought I would take some of my personal time to see if Ican help. Even though this Informational site may not have your exact model orbrand, this site will help you a lot. Here is a site link about everything you want to know about toasters andpossibly yours, from
repair to trouble shooting it. http://home.howstuffworks.com/how-to-repair-small-appliances1.htm
Please if this helped you at all, if you can find the time and in your heart torate my help and some kind words written would be appreciated for my free help, I would appreciate it.
Here is also my direct link to my own pages of other areas of my expertise forother problems you might have in Automotive, Appliance, and Electronics. DropIn anytime for my help.
Thanks, Mike
http://beta.fixya.com/users/mc1bean
Posted on Oct 28, 2011
  • 10 Answers
SOURCE: how do i get the screws out of a breville toaster
I took a 3/16" common (straight) screwdriver bit from one of my cheap universal driver bit sets, chucked it vertically in my shop vice, mounted a grinding disk in my Dremel tool, and ground a 1/16" wide by 1/16" deep slot in the center of the bit. It worked perfectly.
A hacksaw blade carefully placed could produce the same tool.
Posted on Dec 15, 2011
raewing
SOURCE: removing bottom cover to access fuse etc - toaster not working
Wiha Tools. Order M2.3 spanner, item 30523.
Posted on Aug 17, 2012
INSTRUCTION to dismantle toaster
Hi benbecula. I cannot find a repair manual for you. The normal way top dismantle a toaster is to remove the screws beneath the toaster. They are usually self tapping screws that hold the polished stainless steel cover to the base. The knobs on the front of the toaster have to be prised off so the cover comes off. Make sure the toaster is removed from the power before attempting and examination or repair.
Hope this helps,
Michael
Jun 04, 2014 | Russell Hobbs 13767 4Slice Toaster
How to clean the inside of a toaster
Slide the bottom door under the toaster and it will open, I would suggest doing it over a waste can or sink. You can take a small thin brush and get the crumbs out. Then your toaster will be back in working order. Crumbs that are stuck in the bottom of the tray is what causes it to burn the toast.
Nov 21, 2013 | Dualit CTS4E 4-Slice Toaster
I have a Breville toaster and the lever will not lock when toasting. I was able to remove the screws, but I am unsure how to remove the handle on the lever to allow the case to be removed.
1. Remove bottom screws;
2. Remove side handle;
3. Only pry up the casing from the black bottom base;
4. Turn the toaster back in up-right position;
5. Facing the lever end, (may be easier with a helper), lift the casing about 2-3 inches and unplug the wire on your left side then lift it up completely but be careful because another wire on the right side will remain attached;
6. You are now facing an electronic card and behind it lays the source of your problem. A small 3/4" x 1" white plastic. An electro-magnet. Some bread dust, not crumbs but real dust. You need to clean them all. probably easy with an air compressor or even a can of compressed air duster used for computer. The worse scenario is to unscrew what hold the electronic card in place and the 2 screw that hold the electric cord in place. Then you get a very good access the the source of the problem.
Even after 19 months, I did get a new toaster from our canadian Breville's distributor but after another 24 months, this time they offered me a 40% rebate to purchase a new one. No thanks, I decided to try to fix it or buy a different brand. We succeeded, my son and I. Good luck to you.
Oct 25, 2010 | Breville CT75XL 4-Slice Toaster
My 4 slice Dualit toaster stopped working! Repair?
I had an issue where it wouldn't stay down, or heat even if I held it down. No power at all.
Firstly unplug it.
To take it apart, turn it upside down. You have to get the 4 security bolts undone which are underneath (Mine look like they have six holes around them).
Also, you need to unscrew the bobble by hand which you use to push the toast down. You can then pull the cover off, from the back first. The timer dial is connected to the cover, but I didn't disconnect this.
Note: You don't need to undo the bolts inside the toaster. (They only hold the metal base to the plastic base), the 4 torx screws holding the side panel on, or the 4 twisted pieces of metal which hold the toaster internals to the base.
Inside, there are 4 prongs which are pushed together when you push the toast down. On further inspection, I found the main blue power cable had become corroded, and had melted and become disconnected. So simply unscrewed the 2 screws hold this section on,(simply for easier access) and resoldered the blue cable back onto the correct prong.
And now it works again!
May 24, 2010 | Dualit CTS4E 4-Slice Toaster
Clean out bottom
May 03, 2010 | Tefal Avante Deluxe 2 Slice Toaster
The lever to push down the toast will not lock in to start the toastng cycle
Inside the toaster (behind the toast, bagel, etc. Buttons) there is a magnet, this needs to be clean for the taster to lock. First, unplug the unit. Now remove the cap on the thumb lever and the four screws at the bottom, separate the toaster. Now you will see the magnet, remove any debris with a dry towel or with your finger tip. After properly re-assembled this should work.
Dec 20, 2009 | Oster 6330 4-Slice Toaster
Repair of 1939 Toastmaster Toaster Model 1b6
remove bottom plate.....remove 10 screws holding the bottom brown plastic base...loosen screw under push down lever....romove light, dark knob small center hex screw....cover will now lift off....gently....watch #20 toast "wires"
May 04, 2009 | Kitchen Appliances - Others
My Krups model 288 toaster won't always latch down.
You can fix this yourself by following these instructions. Unplug your toaster before proceeding!... Clean the toaster first. Turn the toaster upside-down and shake out the crumbs. Remove and clean the bottom crumb tray. 1. Unscrew the four Phillips head screws located in the corners of the bottom base. Remove the screws completely if possible. Do this over a cloth or newspaper - that way a stuck screw won't get lost if it falls out later. 2. With the toaster right-side up, pull off the wide toast lever knob. Do not remove the round adjustment knob (it will not come off from the outside) but make a mental note of what number (1-7) is showing at the knob's adjustment mark. 3. Carefully pry up the end of the case cover with the knob on it (don't pull on the "stop" button). When the knob's plastic shaft is clear of the circuit board, gently pull off the cover. 4. On the inner part of the circuit board you will see a black plastic "cam" surrounded by two sets of electrical contacts. Rotate the cam to open the contact points if necessary. Insert a thin nail file between the points and rotate the cam to trap the file between them, then scrub back and forth several times to clean the contact points. Do this for each contact on both sides of the cam. When finished, rotate the cam clockwise so it is all the way back down to it's original position. 5. To make re-assembly easier, remove the round adjustment knob from the cover by depressing the half-round shaft flanges inside the cover with your fingernails. 6. Re-assemble the toaster by reversing steps 1 & 2. Replace the knobs, making sure that the round one is in the same position you noted earlier before you push it all the way down.
Mar 27, 2007 | Krups 288 SensoToast Compact 2-Slice...
Kitchen Appliances - Others Logo
85 people viewed this question
Top Hamilton Beach Kitchen Appliances - Others Experts
Greg Cann
Greg Cann
ken skalski
Are you a Hamilton Beach Kitchen Appliances - Other Expert? Answer questions, earn points and help others
