Question about Dishwashers
Bosch silence plus - Dishwashers
2 Suggested Answers
  • 5101 Answers
SOURCE: What does error code 01 mean on my bosch silence plus 42 dishwasher mean?
The 01 error code means that the incoming water isn't coming fast enough. This could be a problem with the water pressure in the building, the fill valve or the water flow meter. Sometimes, this can be caused by something blocking the float from moving freely inside the dishwasher tub.
First check that you have sufficient water pressure in the house and that the shut-off valve is fully open. (If you have low water pressure, find out what is causing the issue.) Make sure that the incoming water pipe/hose isn't crimped or leaking. Next, flip your circuit breaker to off (or unplug the unit) to reset the dishwasher. Next you need to check that the fill valve is opening and closing properly; check that the wiring is good as well. If that is fine, then the problem is the flow meter or the circuit board that reads the sensors from the fill valve and flow meter.
I hope this helps.
Posted on Jun 28, 2015
Bosch silence plus showing fault E24. Have lost our manual . How do we fix this ?
Check the manual online:
https://www.manualslib.com/products/Bosch-Silenceplus-She45r55uc-3787557.html
Jul 01, 2017 | Bosch Dishwashers
Bosch silence plus 50dba not washing dishes! using Jet dry, recently cleaned the screen. any other troubleshooting ideas? ThNk you!
Check to make sure the spinner washing parts are loose and spinning. You can turn them by hand. Many times plates are too tall and block the washing arms from spinning. Push all the baskets in and look into machine and spin the arms. If that's not it then it's somehhing rlectronic that's not taking the machine thru the cycles.
Apr 08, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba dishwasher not draining it says E24
Error codes are cryptic but usually indicate the obvious. Probably drain pipe blocked with junk build up. Clear blockage. Spring curtain rod up the pipe. Ouch....
Perhaps a little draino.
Mar 02, 2015 | Bosch Dishwashers
Bosch silence plus 50 dba has error code h01
The statement below can be found at: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html,
The SHU4326 and 4326 models use "Regular Wash" and "Rinse Hold" to begin the test while the other three series in this section use "Scrub Wash" and "Delicate/Econo," but all use the same set of fault codes, shown not as lights but as numbers on the Cycle Countdown display. Here, 1 is an aqua sensor fault, 2 is a heating fault, 4 is a filling fault, 8 is an NTC fault and 0 means that everything is working as it ought. During an actual wash, when you aren't testing, the Cycle Countdown display may show the letter "F," which also signifies a filling fault.
Read more: http://www.ehow.com/list_6978265_bosch-dishwasher-error-codes.html#ixzz33JutQVQR
Apr 05, 2014 | Bosch Evolution 300 DLX SHE43P26UC Full...
Our Bosch Silence Plus 50 dBA shuts off and turns back on by itself.
You mean that you have to open it and slam it shut for it to finish?
Apr 25, 2013 | Bosch SHE3AR55UC Ascenta Series 50 dBA 42...
User Manual for Bosch silence plus dishwasher
Hi my dishwasher is showing an E01 error could when I switch it on . please advice
Nov 02, 2012 | Dishwashers
How to cancel cycle on dishwasher
On my dishwasher you have to press and hold the Stop or Cancel button for 5 to 10 seconds.
Sep 28, 2012 | Bosch Dishwashers
END OF CYCLE ALARM
The manual on my Bosch 500 plus 4.2 says to select a cycle and then push and hold two option buttons until you hear the beep to turn off the audible end of cycle alarm. Hope this works for you! P.S. It says not to try this with a load of laundry in the machine.
Jan 08, 2009 | Bosch Nexxt 300 Series WFMC2201UC
Dishwashers Logo
12 people viewed this question
Top Dishwashers Experts
Owen Barnes
