Question about Xante Office Equipment & Supplies
Sequential numbering ncr forms
How to I get this count started for a 3 part form.
4 Suggested Answers
The Machine
  • 788 Answers
SOURCE: Problems with Printing Special Size Forms
First I would print the menu settings by going into menu mode (Shift+Sel keys) then pressing the print key. Then I would reset the printer to defaults by turning it off and turning it back on while holding the Sel+LF keys. Then go back into menu mode and make sure to match the emulation mode, character set, language set, code page, page length, and all the Parallel I/F settings. Then try your print job again. If you problem still exists then it is most likely that your application of driver on the comptuter is sending the extra lind feeds and that the problem is not with the printer.
Posted on Jul 04, 2008
venexcsd
  • 1185 Answers
SOURCE: Printing on NCR paper. Trouble is it keeps
Print drums have a cleaning blade which scrapes off the excess toner after it has been hit with a charge to allow it to leave the drum.
If the blade is worn or has had a hard life then it may not be collecting all of the wast and returning it to the cartridge
You can take them out and clean them but it depends on your printer as to how easy that is to do
Posted on Jul 03, 2009
  • 18 Answers
SOURCE: 6-part NCr paper form being used. Pages 1 and 2
This is a problem with your paper. Using multi-part forms on an impact printer will get lighter print on each layer working from the top form to the bottom. The "carbon" paper has to impact the paper hard enough to make the marks. If your top and bottom copies look good but some in the middle are light it is a problem with the "carbon" paper and not the printer.
Now IF the top page is light and each copy under that is getting lighter then you need to close your platen gap (the lever on the right side of the machine mark A B C) go one click at a time (darkening) until the print quality looks good (or you go too far and it pinches the paper and jams *not good*)
Posted on Apr 05, 2010
Can you help me on this question?
This answer is correct. 4/12 divided by 2/2= 1/3
The reciprocal of 2/2 is 2/2
Then you multiply straight across and reduce to get 1/3
Mar 01, 2015 | Miscellaneous
Tv want come on but red led flashes
The pattern formed by the flashes is important. A simple regular on and off indicates it is in standby mode. Am irregular number count like say 3 flashes, pause then three will indicate a basic fault 'messages' which if you know the Make and Mode of the TV, you can look up via Google or the manufacturer's support website.
Jan 01, 2015 | Televison & Video
Lost instruction manual for pedometer I want to reset it
Instructions 1. Press the "Mode" button until you advance to the "Step Count" feature. 2. Hold the "Reset" button for three seconds. A screen will appear asking you if you wish to reset. 3. Press the "Start/Stop" button to select "Yes." 4. Press the "Mode" button to continue and return to the pedometer mode. You have now reset a New Balance sport pedometer.
Oct 06, 2014 | Exercise & Fitness
How do I print sequential numbers on xante Illumina
I have a xante ilumnia and use a program called numberpress to do seq. ncr forms, raffle tickets, well really any thing that needs numbers, It works great and is easy to use, their support is great.
Oct 11, 2011 | Xante Ilumina Digital Color Press Printer
Conversion of polar to rectangular form and vice versa
Conversion of polar form to rectangular:
  • Switch to CMPLX mode: [MODE] [2]
  • Enter complex number in polar form, e.g. r = 3, θ = 42°: 3 [SHFT] [(-)] 42 [=]
  • Switch to rectangular view: [SHFT] [2] [4]
Conversion of rectangular to polar:
  • Enter complex number in rectangular form, e.g. real part = 2, imag part = 3: 2 [+] 5 [ENG] [=]
  • Switch to polar view: [SHFT] [2] [3]
Jan 12, 2011 | Casio FX991ES Scientific Calculator
When i enter the binomial probability formula into the casio fx-115es it will not operate. it says that the problem lies in the (n-X)!X! part of the formula. I'm writing everything exactly the way it is in...
You may be writing the expression as they appear in the formula, but the problem stems from the fact the factorial function increase rather rapidly and you cannot calculate the factorials of numbers larger that 69 which is the limit of the calculator.
However if you use the built in Combination function nCr, you will avoid the problem. In the binomial function, the n!/(r!(n-r)!) factor can be replaced by nCr or nC(n-r).
Do not use the explicit form with the factorials because you will get an overflow.
Nov 09, 2010 | Casio FX-115ES Scientific Calculator
Feb 16, 2010 | IBM Infoprint 6500 Matrix Printer
A Committee has 19 members, of which 10 are Democrats and 9 are Republicans. A subcommittee is going to be formed with 3 Democrats and 3 Republicans. How many possible subcommittees can be formed?
How many ways can you select 3 members out of 9 republicans: nCr (9,3)
How many ways can you select 3 members out of 10 democrats: nCr(10,3)
For each single choice of 3 reps you have 1*nCr(10,3) possible subcommittees.
Hence the total number of possible suncommittes is nCr(9,3)*nCr(10,3)
Explictitly
# of possible subcommittees is [9!/(3!*6!)]*[10!/(3!*7!)] or 10080
To calculate you can use the explict formula above or use the nCr function of your calculator
To access the nCr( function press [2nd][5] (MATH) [7:Probability][3:nCr]
You can also just type the name of the command respecting the case ( C must be upper case)
Jan 31, 2010 | Texas Instruments TI-89 Calculator
I have a samsung lcd-tft monitor (syncmaster
call on 01122222222 and take the number or address form yellow pages
Nov 03, 2009 | Samsung SyncMaster 740N 17" LCD Monitor
Jul 03, 2009 | Office Equipment & Supplies
12 people viewed this question
Top Xante Office Equipment & Supplies Experts
Ottoniel
Dudeman321
CheckitRight
CheckitRight
Are you a Xante Office Equipment and Supply Expert? Answer questions, earn points and help others
