Question about Digiwave ANT-3045 Remote Control Outdoor TV Antenna HDTV Digital with
My antenna won't rotate and I now receive only local channels
    Sergeant:
    Champion:
  • 282 Answers
There could be a problem with the wires going from the control box to the rotator, or the remote itself
Good luck,
Marty
Posted on Jul 23, 2014
I have a Magnavox tv.. and I brought a ematic AT 103B converter box.. I can only get 11-1 and 11-2 and 11-3, I did a channel search.. and still can not get other channel's.. Katrina
Usually this means that you need a different antenna or to move your antenna. If you are using an indoor antenna, you may need an external antenna. Make sure that the antenna is pointing to the transmitters. If you have an amplifier on the antenna, it may be damaged and could be blocking some frequencies. In that case, you may need to replace the antenna or the amplifier. In some places, surrounding objects can block the signal; trees and buildings are the frequent problems.
Please use http://www.tvfool.com to check where the local stations transmitters are located and the recommended antenna to receive each station. ( http://www.antennaweb.org is a similar resource but usually is too conservative in the list of available stations.)
I hope this helps.
(In my case, I point a large external antenna towards the local stations farthest away. This lets me receive those stations and the ones from closer transmitters. If the antenna rotates, I lose some local stations but may gain access to stations that are outside my area. Then I have to climb up and turn the antenna. I tried an antenna rotor but it eventually burned out.)
Dec 09, 2015 | Televison & Video
Dish tv support
Hi Vicki,
You may call them at
  • CALL US 1-888-615-3725 for DISH
  • You can also try this steps:
  • MISSING OVER THE AIR CHANNELS The quality of reception and number of channels available depends on the antenna's placement and the customers location. Weather conditions may interfere with channel reception. The Channel Display receiver menu option may not be set correctly.
    1. Check Over-the-Air Antenna ConfigurationCheck that the wiring between your DISH receiver and your over-the-air antenna is configured properly using Setup OTA
    2. Reset ReceiverIf the issue is only on ONE receiver, unplug the DISH receiver for 10 seconds and plug back in.
      Please note: It may take up to 5 minutes for the reset process to be completed.
    3. Rescan Over-the-Air Channels to ReceiverAccess "Local Channels" select "Scan Locals" then "Save".
May 08, 2014 | Televison & Video
Cruzer tv antenna
Antenna rotators used to be available in the US but are practically non-existent today.
Nov 11, 2013 | Televison & Video
I CAN ONLY RECEIVE 2 OR 3 RADIO CHANNELS ON MY INSIGNIA RECEIVER
Radio tuners receiving AM and FM channels/broadcast MUST have some sort of antenna connection. For local channels a paper clip will work, but for more distant channels, use either a better inside antenna or purchase a outside antenna as needed.
Jan 30, 2013 | Insignia 200W Stereo Receiver
TV won't pick up channels 7-13
These are what once were VHF channels and are still mostly assigned to local stations.
You didn't mention the source for your received signals, if antenna, cable or satellite and it does make a difference as to the possible source of the problem.
If you are receiving via antenna, then the problem is within the set itself. If from one of the other two sources requiring a 'box,' then the problem is likely within the cable or satellite box that is between your incoming signal and the set.
Jul 29, 2012 | Magnavox 39" LCD 1080p HDTV 39MF412B -...
Do i need just an antenna or one of those digital converter boxes to get just local channels in Denver on this TV?
If your TV was made after 2007 it should have the digital receiver built in. If so you can just hook any antenna you wish up and receive all your local channels.
Jan 15, 2010 | Sony KV-35S42 35" TV
Sharp Aquos LC 32G4U not receiving any channels-
Most locations are real hard to get local stations using indoor antennas. If you are in a location where you do not have cable, I would try either a outside antenna on the roof or go with Direct TV Dish / Dish Network system.
I hope this helps,
Skyassoc
Jan 04, 2010 | Sharp Aquos LC-32G4U 32 in. HD-Ready LCD...
I just purchased an amplified indoor HDTV Antenna to better receive HD tv. Is the LCD display supposed to be on all the time??? How can I get better reception from a broken picture even rotating the...
I don't know in what area you live & therefore how strong your reception area will be, but as a general rule an indoor antenna is never the best type of aerial to have to receive digital signals, you will always find that you pick up some good strong channels but more often the rest of the channels will be poor or non-existant & will constantly break-up/freeze etc. The best advice would be to try & fit an outdoor antenna if possible.
Jul 15, 2009 | Televison & Video
Dish Network Channels Work but Local Television Channels Do Not
Do you have an antenna hooked up? You'll need one hooked to your converter box because the digital signal is so much more difficult to tune in to. This may help:
www.antennaweb.org
If you live closer than 15 miles, rabbit ears
If you live closer than 20 miles, omnidirectional
If you live closer than 50 miles, midrange outdoor (oldschool arial w/ rotator)
Further than 80 miles, you'll need a long range with rotator, perhaps even an amplifier to go with it. Print off what your results were on antenna web and bring it to a RadioShack or a local antenna store and they should be able to point you to the right antenna for your particular location.
Apr 21, 2009 | Sony KDL46S3000 46 in. LCD HDTV
Digiwave ANT-3045 Remote Control Outdoor TV Antenna HDTV Digital with Logo
167 people viewed this question
Top Digiwave Electronics - Others Experts
Are you a Digiwave Electronics - Other Expert? Answer questions, earn points and help others
