Question about Hoover F5888-900 SteamVac Upright Wet/Dry Vacuum
Water wont transfer - Hoover F5888-900 SteamVac Upright Wet/Dry Vacuum
Steam wont come out although filled with water and heated as required
If you are using tap water the holes where the water comes out are plugged. You will have to take it apart to clean. After that you should use distilled water you can purchase at your local grocery store. That is what my wife uses after I insisted.
Dec 01, 2013 | Vacuums
I have a bissell 9200 proheat X2 wont **** up water
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
r
Aug 03, 2010 | Bissell ProHeat Turbo Deep Cleaner Upright...
Bissell ProHeat 8910 wont spray water or solution
heatman101
sgb
Mar 18, 2010 | Bissell 8910 ProHeat Clear View Upright...
Why wont my hoover 2320LAUS washing machine drain water
Sounds like the water pump is not running either from power lack or defective pump motor.
Nov 15, 2009 | Hoover My Dad Can Arrest Your Dad Kids...
Wont **** up water
Go to bissell.com go unger frq.asked questions. Also check your belt
Jul 23, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
I don't know where to put the water?
The clean water goes on top. You want to check your bottom tank and make sure the lid is not lose.
Jun 11, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Hoover steam cleaner wont pickup water
in the front on top the cover that curves down to the floor is where the suction is .it should be plastic you can see into.its probably clogged with hair and dirt.you need tro take that top off and it comes apart in two sections .the middle seperates from the outer part.once apart you can clean it with soap and water.after you get that off you will see on your left side a long square port that needs to be cleaned also.please leave feedback.i hope i was of some help to.pete
Apr 30, 2009 | Hoover SteamVac F5914-900 SpinScrub...
Bissel proheat no water will dispense
Check all your hoses and make sure that they are not blocked and everything can run freely through your sstem
Apr 25, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Water comes out when trigger is squeeze but wont **** up dirty water
A. Is your floor/hose knob in the correct position?
B. Do you have suction at the hose end, when in that position?
C. If you answered yes, no in that order then either your motor (provides the suction) is going bad, or it simply is clogged and needs to be serviced.
Apr 15, 2009 | Hoover SteamVac Carpet/Upholstery Deep...
My Bissell Pro-Heat 2x 12 amps Model 9200-2 The rollers wont turn and the water wont release
my bissell 9200 won't release water or solution when the trigger is pulled.
Sep 16, 2008 | Bissell 9200 Upright Vacuum
Hoover F5888-900 SteamVac Upright Wet/Dry Vacuum Logo
14 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
