Question about Canon PIXMA MX850 multifunction InkJet Printer
We cannot use the ADF on our Canon mx850. From
We cannot use the ADF on our Canon mx850. From the day I took it out of the box the adf pulls in the top sheet crooked and it jams. Because this happened right out of the box, I feel like I must be doing somwthing wrong, but nothing has fixed this issue. Any ideas?
No. It's not probably not you.
If you have placed the paper between the guides, and snugged them up, it should go (relatively) straight -simple as that.
If not, then likely something is missing, bent, or broken. Return it for a new replacement - that's what warranties are for.
Posted on Jun 20, 2009
What does "ADF" stand for when faxing?
Hello, Automatic Document Feeder! Regards, nicam49
Aug 04, 2011 | Canon PIXMA MX850 Multifunction Printer
My printer is fine when i am printing from my computer, but when i make a copy, there is a line down the page
Be sure the glass is clean.
If the Canon is anything like HP and you are using the ADF there is a thin strip of glass on the left end of the flatbed. This is where scans are read when using the ADF (Automatic Document Feeder)
All it takes is a tiny speck on the glass to cause lines on the copy. Clean it by spraying a glass cleaner on a soft towel and wiping
Jan 03, 2011 | Canon PIXMA MX850 Multifunction Printer
While printing, red turned to pink on printed sheets. All cartridges have ink.
Try
Clean the Scanning Area sikaku.gif Cleaning the Platen Glass and Document Cover i_expl.gif Caution
Be sure to turn off the power and disconnect the power cord before cleaning the machine.
i_important.gif Important
bullet_s2.gif The inner side of the Document Cover (white sheet) (C) is easily damaged, so wipe it gently.
bullet_s2.gif If the glass of the ADF (A) is stained with ink, correction fluid, or the like, black streaks may appear on the printed paper when the document is loaded in the ADF. With a clean, soft, lint-free cloth, wipe the glass of the ADF.
With a clean, soft, lint-free cloth, wipe the Platen Glass (D), the inner side of the Document Cover (white sheet) (C), the glass of the ADF (A), and the inner side of the ADF (white area) (B) gently. Make sure not to leave any residue, especially on the Platen Glass.
sikaku.gif Cleaning the ADF i_expl.gif Caution
1. Open the Document Tray.
2. Open the Feeder Cover.
3. With a soft, clean, lint-free and dry cloth, wipe off any paper dust from the inside of the Feeder Cover (A).
4. After wiping, close the Feeder Cover by pushing it until it clicks into place.
5. Close the Document Tray.
6. Reconnect the power cord then turn on the machine.
Oct 27, 2010 | Canon PIXMA MX850 Multifunction Printer
Pieces of paper stuck in ADF of Pixma 850
open it ..and reset job by pressing the start button and keep it down and remove the paper ..this way will not break ...and also if there are pieces left ..open the cover ..and roll that rolers manually to extract the paper ...After that reset it ..and go for it ..
Jun 02, 2010 | Canon PIXMA MX850 multifunction InkJet...
Canon MX850 dust under ADF glass
This is a newer unit, and Canon has a one year warranty, any chance this is under warranty? Canon did design this as a sealed unit, no parts available except the entire assembly, and no dis-assembly instructions.
Jun 29, 2009 | Canon PIXMA MX850 multifunction InkJet...
Scanner stopped functioning
r u already try reinstall your driver?if not, try it 1st and see the result..i'm afraid the driver is damages....try to download from canon support website in order to get the updated one...hopes it will help ; )
May 26, 2009 | Canon PIXMA MX850 multifunction InkJet...
ADF won't draw document to be scanned into the scanner
The first thing I always do to a misbehaving ADF is take a dust blaster(canned air) and blow all of the dust and debris out of the ADF,This means lifting the ADF cover and cleaning everywhere.There is always a switch or sensor whose job it is to detect a sheet of paper placed in the ADF.Good Luck.
Mar 27, 2009 | Canon Office Equipment & Supplies
Canon MX850 printer - ADF copy has black line on it
Hello, my name is Steve,.
This is a common problem and an easy fix.
If you lift the ADF / top cover assembly up, you will see a small narrow piece of glass next to the flat-bed glass.
Ths is called a "Slit-glass". The only purpose is to read content from that point by the scanner, The Scanner will sit in the underside of it.
It is dirty. Wipe this with glass cleaner and a soft lint-free cloth. you may need to do this several times. Concentrate the part of the glass were this image problem is just by the orientation of the document you are installing with the direction of the document you are passing through the ADF.
It will take several attempts, but with each try, make a new test from the original document, unyil the problem disappears.
I believe this will solve your problem, Best , Steve
Mar 10, 2009 | Canon PIXMA MX850 multifunction InkJet...
Canon PC 1061 ADF Error
Hello, you should open the ADF and try cleaning pick-up rollers + separation pad with alcohol ( some chemicals products works best but i can t remmember what kind of product it is ).
Regards, Mug
Oct 06, 2008 | Canon PC1061 Copier
Canon PIXMA MX850 multifunction InkJet Printer Logo
135 people viewed this question
old marine
old marine
