Question about Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner
Waiting for producing engine - Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner
WAT is the horsepower on 200cc
It depends entirely on the engine's properties.
Your standard lawn mower engine of 200cc produces about 2.5 hp.
Some production high-performance cars produce one horsepower for every cubic inch of displacement, a 200cc engine is 12 cubic inches, so if your little 200cc motor is engineered as well as these cars, it could produce 12 horsepower.
The above pertains specifically to four stroke engines. If your 200cc motor is a two-stroke, you can easily double those numbers because a two-stroke hits every time the piston travels up.
You may also note that some 200cc motorcycles can produce as much as 50hp
Oct 08, 2014 | Motorcycles
How to fix radio in 2004 durango radio won't play if i start engine without waiting for sound before i start engine. Now my daughter plugged her ipod in without waiting now it does't work at all
My suspicion is there is an issue with your vehicle's electrical system or the radio is poorly wired. It should not matter at all whether the radio is playing or not when starting the vehicle. If, while starting, your alternator is kicking out too much voltage, this could possibly put the Pioneer into protected mode meaning it would produce no sound.
I suggest having someone connect a DMM (Digital Multi-Meter) to the battery while you're starting the vehicle and see what voltage it's producing. It should be somewhere between 12-14 volts and after starting, be no higher than around 14.8 volts. If it is higher, get it checked by a mechanic.
Dec 22, 2013 | Pioneer Car Audio & Video
WHAT IS THE TAPPET CLEARANCE OF ISUZU MADE 4BC2 ENGINE FOR INTAKE AND EXHAUST VALVE
Dear sir,
we're one of the biggest producer of The piston calipers in Iran,now we want to produce the tapplet celearance .We need some imformation about it such as : process of produceing,Specifications ,what materials should be use in it,raw maerial.....
we are waiting for your kind reply.
Sep 10, 2011 | Isuzu Trooper Cars & Trucks
I was having trouble getting a signal on my xbox 360 so i unplugged and plugged my router back in, this caused it to not put out a wireless signal, it does produce internet through an Ethernet cord, but...
It can take up to 2-5 minutes before your router starts broadcasting a wireless signal and for the xbox to be able to connect to it, turn your xbox off and the router wait a minute then turn your wireless router on, wait a further few minutes and turn your xbox on and try using the wireless connection
Jun 27, 2011 | Paradyne Zhone 6218I2 ADSL2+ 4 Port WiFi...
Wolf 800 generator. Engine will run but very electrical power is
is the engine running at the correct speed
3000 rpm to produce 50hz
3600 rpm to produce 60hz
Mar 06, 2010 | Electrical Supplies
How do i add anti freeze when low on 2000 chevy venture
Open the radiator cap, by pushing down and twisting counter clockwise. and pour it in. If no radiator cap, line will fill from the overflow reservoir.
Either way, wait until the engine is cool, as radiators produce extreme heat and pressure, which will vent as you open the cap.
Jan 05, 2010 | Chevrolet Venture Cars & Trucks
Our franke flair coffee machine keeps saying please wait and will not let us produce any coffee please help
this is usually due to the overtemp device activated on one of the thermoblocks, an engineer will be required to replace this item,
Aug 02, 2009 | Bloomfield 9311 SS1
1994 c280
The 2 AC fsnd turns on when the Engine temperarure hot. It receives the signal from ECU throught the Engin temperature sensor ( Coolant). Your case happens since the Engine Temp sensor went bad. At beginning the temp sensor can not produce any resistance just like open then ECU thinking engine hot turns on the Fan. When your engine ia about 85, it is a normal temp then the sensor could produce some resistance matching the look up tabel for the ECU, then the ECU turn off the Fan. Some pepople has it run all the way since the wire contact to the sensor was off. Replace the Engin Temp sensor to take care of the problem.
You have 2 temp sensors on top engine, one for your temp read out, one for the fan purpose. If you don't know which one, wait for your temp at 85 and the fan is stopping, then unplug one, imediately the fan goes on, that the one. Good luck.
Jul 05, 2009 | 1994 Mercedes-Benz C-Class
I have a honda engine gx620 coupled with my generator and in tern connected through a power center to charge batteries and sync with my inverter. It's showing only 60hz dropping to 59hz and I need to know...
You did not mention how many amps your system is producing/drawing, however I don't think that you need to adjust the governor. Your engine can produce 18 hp at 3600 rpm. At 3600 rpm your generator is producing 60hz or cycles. As the load increases /decreases it has an effect on the governor thus the change in cycles. If the load increases past the capacity of the engine, the cycles will drop. To stabilize, reduce the load. 59hz is produced when the engine is turning about 3550 rpm. If you increase the speed of the engine to compensate cycles may increase past 60hz. 3650rpm will probably produce 61hz. Engine speed could be fluctuating due to other reasons (vacuum leak, dirty air filter, plug, etc ) if there is only a small load on the engine/generator. If you would still like to adjust the governor please email the load on the generator and I will help with instructions. Good Luck with your generator it is a very nice unit and built to last.
Apr 30, 2009 | Northstar Electrical Supplies
My garmin loses the satellite as soon as I turn on the engine.
I have heard of this before and it is said to be a power surge issue. Unplug the Garmin unit before starting your car's engine. If this does not work, you may have interference from the EMF (Electro-Magnetic Field) produced when you turn on your car. If so, there is not much you can do rather than just wait until it finds the satellites again.
Nov 30, 2008 | Garmin GPS
Rimage 2000i CDR 2 (52X), CD Duplicator External, CD-R Publisher Inkjet Printer, CD Designer, USB 1.... (CDR2000I) Burner Logo
48 people viewed this question
Top Rimage Computers & Internet Experts
Gareth Cockram
Gareth Cockram
Jerry Greenberg
Jerry Greenberg
Mike Carew
Are you a Rimage Computer and Internet Expert? Answer questions, earn points and help others
