Question about Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty
Celebrity xl looses power when climbing slope my batteries is fully charged and it still hesitates to climb
    Master:
  • Electric Mob... Master
  • 401 Answers
Your Scooter Manual will tell you what percent grade the scooter will climb. If it is too steep, it may stop because the motor is getting too hot. The Motor will be using more battery power to climb slopes so you may experience a pause, that would be normal.
Posted on Jul 03, 2016
Why wont my celebrity x take a charge brand new batteries brand new charger
Is the charging circuit fuse blown? There are two hidden under the floor mat and hatch. Pride say that they don't exist, but there they are and one of mine mine was blown by a faulty XLR lead
Apr 25, 2014 | Pride Celebrity Xl 4 Wheel Scooter
Ventrac problems
that ventrac if i'm not mistaken has a turbo on it. Make sure the turbo is ok. That is a great motor and should have plenty of power to run all attachments
May 29, 2013 | Garden
I have an '06, 1200 Sportster Custom with 1300 miles on it. The Check Engine light comes on sporatically. I checked the trouble code, and it says the battery voltage is too high. Does this mean the voltage...
Test the output voltage. With a fully charged battery, connect a digital volt ohm meter across the battery. Red meter lead to positive and black meter lead to the negative post. Put the function selector switch in DC VOLTS, 20 VOLT range or there about. Start the engine and bring it to a high idle. The meter shoud read out a voltage and start to climb. If the battery is fully charged, it will settle down in just a short while. It should read between 14.5 and 15.0 volts. If it's higher than this, the regulator should be changed.
Good luck
Steve
Sep 23, 2010 | 2006 Harley Davidson XL 1200 C Sportster...
Car hesitates when I floor it
These symptoms point me in 2 directions.
The first would be the gas filter. I came across the same problem this week on a 1996 Corolla. It would hesitate and sputter while pressing the throttle. The cause was a clogged gas filter.
The second area I would check would be the catalytic converter. If it is partially blocked it could cause these symptoms.
If there was a vacuum leak large enough to cause a problem you would be able to hear a hissing or whistling noise from the engine at idle.
Post back with any new info and hopefully we can pinpoint the trouble.
Good luck.
Feb 03, 2010 | 1984 Honda Civic
Rascal scooter mo 655 motor stops going up hills
the batteries could be the problem, is it possible to try some other batteries, silly question , how steep is this hill ? remember scooters cannot climb steep hills as the motor will shut down due to the increased load.
1 Year old batteries ok ? but if they get used on a non daily basis and are not fully charged after use, I would question the batteries but again the motor could be overloading,
How much do you weight ? sorry for the personal question but it all loads the motor and that increases the current and that will cause the motor controller to shut it down.
Jun 14, 2009 | Pride New Mobility Legend 4 Wheel Scooter
Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
Nov 07, 2008 | Pride New Mobility Legend 4 Wheel Scooter
Hesitation
shift your gear to the left one tap to go into drive 1 when climbing steep hills and it keeps you from hesitating .it works for me i have a 2009 caliber automatic and i climb alot of kentucky hills ,mine only hesitates on the really steep hills after i slow down and take off again but when i shift to d1 its fine
Jul 23, 2008 | 2009 Dodge Caliber
Electric Mobility Mobility Electric Power Scooter Wheelchair. Heavy Duty Logo
53 people viewed this question
Top Electric Mobility Health & Beauty Experts
Robin Hill
Robin Hill
Colin Taylor
wcdoc1953
wcdoc1953
Are you an Electric Mobility Health and Beauty Expert? Answer questions, earn points and help others
