Question about McCulloch Garden
My chainsaw won't start when I pull the recoil it pulls but does not seem to catch there is a racketing sound when the flywheel turns and all the cord does is snap back and seems to take tension off t
This chain saw has not run for years and am working on it for a Ag class project I. Also have one that is the same model as this I thought I d be able to interchange parts.
  • 17 Answers
SOURCE: Pull cord on chain saw will not retract.
Most of the rancher models are easy to look at. Take the four screws off that hold the starter cover on.When off have a look to see if the pulley is ok or one of the starter dogs(pawls) is jamed . If dogs ok take the screw out of the centre of pulley and remove it ,check for spring tension. if there is just be carful to leave sring in housing. look at spring if broken or out of shape renew it and rope.check for cracks in pulley. When renewing spring and rope get correct rope length and diameter. don't over tension new spring. hop this helps
Posted on Jan 03, 2009
  • 62 Answers
SOURCE: Poulan wild thing recoil froze up
You may need to replace the recoil assembly, check with poulan for availability.
Sorry I couldn't be of greater assistance.
Posted on Apr 17, 2009
  • 11 Answers
SOURCE: Pull cord does not turn engine over. This morning, follwowed operationg procedure tostart when engine turned over as if to fire. I closed the choke, pulled the cord twice and on the second pull, it pu
check that the 2 pawls are moveing in the pull start that engage the flywheel you should remove the cover for a closer look also check any warrenty before tinkering
Posted on May 14, 2009
  • 61 Answers
SOURCE: recoil spring on homelite chain saw doesn't retract pull rope
Easy suggestion would be to get new spring coil. Is it older saw? Have had to change mine on poulan saws before.
Posted on Jul 04, 2009
  • 583 Answers
SOURCE: Stihl ms 250 chain saw won't start, doesn't seem to catch spark.
dry the plug asmall squirt of aerostart in the top of carbywith air cleaner off full throttle pull the rope and she should fire up make sure the on/off switch is in the correct position. no don`t laugh ican remember nearly completely stripping amotor years ago before ichecked it put it all back together and it started first go try the aerostart and switch
Posted on Aug 04, 2009
Starter handle will not catch
It's possible that a few things are happening. Some recoil set us have the dog ears, the little plastic piece that flaps out and catches the flywheel bell. Have you taken that cover off the unit yet? If not, take it off, pull the cord and see if either the dog ear is broke or something else is...this is an easy fix, recoil assys are not expensive at all... it all starts with that pull cord assy. Should be 4 screws that hold on the side panel to the saw, just don't take the recoil pulley out or you may find the spring will pop free from where it sits..
Oct 05, 2015 | Garden
Stihl chainsaw MS460 Can't pull recoil
It could be the recoil is stuck. a couple of things to check. Take the clutch and chain cover off, remove the spark plug and manually try to turn the motor over by turning the clutch. If the motor/engine is not seized, take the pull start/recoil cover off and pull on the cord to see if it will work and that the cord returns back into the recoil automatically. Don't take the nut off the inside of recoil holding the cord spool on. If the engine is not seized, and the recoil now goes in and out by pulling the start cord handle reassemble and pull over the engine a few times. This a good time to check the spark plug is working, now put the spark plug back in and start the engine. It's a good time to clean the air filter as well while the chainsaw is mostly apart and clean all oily sawdust off the chainsaw in the crevices etc..
Jun 05, 2014 | Stihl Chain Saw Handle Models 044 046...
Starter cord will not pull
The pull cord or rope works on a tight spring just under the cover that the rope is in. Usually three to four small bolts on the edge of the cover to remove to repair/replace either the spring or the rope. First I would try to turn the motor manually with your hand on the flywheel, it should move around either direction freely with no effort. If it does not the motor itself maybe stuck not the rope. Then you have a seized engine and a different problem to deal with.
Dec 27, 2013 | Husqvarna 41 141 41 136 36 Recoil Pull...
Pull cord get tuck
If I understand properly, it sounds like the dogs on the recoil mechanism are worn. They are designed to engage with centrifugal force when you pull the cord. Make sure they are coming out when you pull the cord, you have to remove the housing to do this and make sure the dogs aren't worn. Also check the plate they engage onto on the flywheel and make sure it is tight and not worn/
Aug 03, 2013 | Briggs & Stratton Lawn-Boy 10642 20-Inch...
Pull started cord won't recoil after attaching a new one
your spring may be broke or might just have to rewind it they could be a pain somtimes
Apr 07, 2012 | Ryobi Factory Reconditioned 18" 40cc...
WHEN YOU PULL THE PULLEY CORD IT SLIPS AND WONT START THE WHIPPER SNIPPER. IT DOESN'T GRAB ITS SLIPPING WHEN YOU GO TO PULL IT TO START. PLEASE HELP ME THAT WOULD
The piece on the recoil that engages with the fingers on the flywheel is worn. You have to get another spool that goes in to the recoil it is usually plastic and it wears.
Mar 19, 2011 | Garden
I have a Toro electric start 22'' inch lawmnower Model No. 20018 with a Tecumseh LEV 90-120 engine. The mower may be started with the electric start or manually with the cord. The battery was in need of...
It sounds like the starter drive may be jammed. It should not be engaged unless you are using the starter motor. Take the spark plug wire off, put on heavy leather gloves, and try turning the blade by hand to dislodge the starter drive. If it does dislodge, plug the spark plug wire back up and try the pull start again.
Aug 29, 2009 | Toro Lawn Mower With Toro Power Tools
Ryobi BC30 trimmer - pull cord not engaging to turn over engine
The "pully" that you are refering to is called the recoil. There are a couple of simple reasons why this won't catch on the flywheel and if you try to fix it your self it will most likely fly apart and scare the living daylights out of you. Either order a new recoil unit off of Ebay or from a reputable dealer and save yourself the headache.
Jul 30, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
My Poulan chain saw has a sticking pull cord....r
Check the flywheel and flywheel key. It sounds like the timing is off.
Mar 27, 2009 | Poulan P3314 14" Gas Chain Saw 2.0 Cuin...
Pull cord on weedeater wont recoil
sounds like the spring is broken itself.there should be a hook at one end and a loop at the other end.the hook usualy breaks off but the spring looks good.replace the spring with part number..4140 190 0600 ....that is the stihl part number.let me know if this helped you...if not give me a quick mail and i'll try to help some more......
Mar 12, 2009 | Garden
Garden Logo
20 people viewed this question
Top McCulloch Garden Experts
Roland W VanLue
Roland W VanLue
roeb
Are you a McCulloch Garden Expert? Answer questions, earn points and help others
