Question about Refrigerators
I have a Jenn-Air side by side fridge freezer about 9 years old - sorry I don't know the model number - perhaps you can tell me where to look - and the bottom of the freezer compartment freezes up as if there is a build up of water/moisture. This slowly forms a block of at the base of the freezer necessitating a lengthy manual defrost. It has been "repaired" several times and the story given is that food dropping down inside the back of the freezer is blocking the grill causing the icing problem. This is impossible as the only contents that could drop small items like frozen vegetables are kept in the door shelves, which are at the front of the freezer. Other than the ice build up at the base the freezer temperature seems fine, and it operates on a nid coldness setting
  • hordens Jun 20, 2009
    I'm not really sure what I'm looking, for but having removed the back I've found a small plastic tube that hangs down over a very small plastic tray that sits in behind the compressor (looking from the back). Assuming this is the tube there is nothing in it, it doesn't feel like it has recently defrosted, and the tray is so dry that dirt in it is more like gravel than dust. This would seem to indicate no liquid has come down this tube for a long time, which could mean that it is blocked - the freezer has been off for about 8 hours as I try to clear the ice build up - rather than frozen. If it blocked then presumably someone more knowledgeable than me can clear the block, but could that be caused by the food issue it's been blamed on before? If it is an inherent design problem - as your email suggests - how do we go about changing things to ensure it doesn't happen again?
    Following my follow up email, I forgot to say that there appears to be an adequate gap between that pipe and the tray, especially as there is no sign of any water having come down the pipe for some time. So we come back to the pipe being blocked rather than frozen as the likely problem, so any ideas as to how I unblock the pipe?
  • 72 Answers
It sounds as if for whatever reason, the drain tube is freezing shut, if you take a piece of 14 gauge solid copper wire, put a couple of inches of it into the drain tube from inside of the freezer, take the other end and put a couple of turns around the defrost heater, this will transfer heat to the drain every time you go into a defrost, we have done this successfully in the past when drain tube heaters are not available for a brand or model that we are working on.
Posted on Jun 20, 2009
    President:
  • 1,136 Answers
Hi, I have found the drain tube that goes into the pan underneath the refrigerator does not have enough gap between the tube and the drip pan. This causes the water to stay in the drain tube enough that it freezes. To check this out, remove the rear cover to the compressor area and locate the drain tube.
Please let me know what you find.
Vic
Refrigerator side freezing
you could have a bad damper,this is located in the fridge section,all it is is a door that opens and closes to let cold air into fridge,sounds like yours is stuck open.remove the bottom kick panel and look for the tech sheet,it will tell you how to put it into diagnostics,the board will open and close,if it doesn't you know it's bad.go here and look at part number 13
http://www.searspartsdirect.com/partsdirect/part-model/JENN-AIR-Parts/Refrigerator-Parts/Model-JBR2086HES/1266/0161000/M0610191/00008?blt=06&prst=&shdMod=
Jul 12, 2012 | Jenn-Air JBR2086HES Stainless Steel Bottom...
I have a 15 year old Jenn Air Fridge/freezer Model no JRSD249OT . Recently side of doors feel hot and now fridge not getting cold. Appreciate any advice
You will need to pull the fridge out and remove the rear lower panel. If the unit is operating you will be looking to see that the fan in the rear is also operating. Most likely it is not. You will need to replace that fan motor if it is not.
May 21, 2010 | Jenn-Air 21.6 cu. ft. Side-By-Side...
I have a jenn air side by side. the freezer is
This is usually a sign of a defrost problem. I will need you model number to help you better. Sea Breeze
Jun 26, 2009 | Jenn-Air Refrigerators
Jenn-air fridge
is the defrost drain blocked(ice on freezer floor)
Jun 11, 2009 | Jenn-Air JCD2389G Side by Side...
My Jenn-Air frig, model JCD2389G,isn't cooling. It's less than 7 years old. Freezer seems fine. Frig is set at coolest and still is only 55 degrees. Cleaned back of frig, what else do I check? thank you,...
Check the fan located in the freezer compartment.
This fan blows the cold air from the freezer into the fridge and is about 40 dollars for the part. Simple to fix too.
Gary
Jun 05, 2009 | Jenn-Air JCD2389G Side by Side...
Freezer not working , clicking noise coming from fridge
Clicking was a relay. Replaced relatively inexpensive relay and now working fine.
Jan 17, 2009 | Jenn-Air JCD2389G Side by Side...
Frigadaire freezer cold but fridge compartment is warm
i need the complete model number to narrow it down they still make the frs20zrg to this day the last two numbers like frs20zrgwo or frs20zrgw9 is what will tell me what kind of defrost system it has the serial plate is in the fridge side up by the light bulb or on the left hand side or right hand side of the fridge compartment up near the top sorry to be a bother but its necessary
Mar 30, 2008 | Frigidaire FRS26ZSG
Refrigerators Logo
78 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
