Question about Life Fitness 95Ti Treadmill 95 Ti
Waxer empty notify maintence - Life Fitness 95Ti Treadmill 95 Ti
3 Suggested Answers
gymtech
  • 18 Answers
SOURCE: treadmill wont run its saying waxer empty and
Does this treadmill have a wax system ? If it does it will have side access panels on the side just above the rear leveler. The picture that shows here does not but need to be sure it does not really need wax.
If it does not have a waxer- enter maintenance settings on display console,I do not have one in front of me but I believe you hold pause button down and press clear twice. This should bring up maintenance settings.
Scroll using up down arrow untill you see replace wax bag or something to that effect. select [enter ] to save. press clear clear to restart.
Posted on Feb 07, 2010
ercupa190
  • 12223 Answers
SOURCE: What's your problem?I have a life fitness 9100 hr I have a problem how do I clear the message waxer tank empty?
see this step and fix it. God bless you
Unplug the treadmill. Locate the console key and place the safety or reset key into the treadmill console. Replace any parts that need replacing, or move on to the next step.
  • 2 Locate the reset switch on the underside of the treadmill console. Usually the button is large enough to trigger with a pencil eraser or Q-tip. Plug the treadmill plug back into the wall. Use the Q-tip to press the reset button. It may be necessary to hold the reset button down for a few seconds. "CL11" will appear in the display of the treadmill.
  • 3 Press the reset button one more time with the Q-tip. "CL21" should appear on the screen. Press the enter key. The display will change again and show "CL22." Keep pressing the enter key until the numbers cycle through to the number "CL26." Press enter one more time. The letter E should appear on the display screen.
  • 4 Press enter twice more. The letters "SS" should appear on the screen. When this happens, press the start/stop key. Making sure to keep well away from the tread, press enter to start the treadmill. The treadmill will start on its own. The treadmill will stop on its own after a few seconds. When it stops, press the power key two times. Remove the safety key and put in a safe place. Your treadmill is reset.
  • Posted on Oct 16, 2012
    Treadmiill keeps saying waxer needs filled after filling it
    please see the cause and remedy and fix it. Please read carefully your section of troubleshooting instr. manual or download
    Inspect spray pattern between 8" (200mm) and
    16" (400mm).
    If not, verify wax nozzle is clean, hoses are not
    kinked, wax bag is not empty, or wax is
    contaminated.
    http://www.sportsmith.net/images/product_support/lifefitness/Treadmills/TR9100/9100 Treadmill Manuals/Service/m05100k
    God bless you
    Nov 29, 2012 | Treadmill Doctor LifeFitness 9100...
  • Oct 15, 2012 | Life Fitness 9100 Next Generation...
    We have a Fellows Pwoershred 2200SC that keeps showing the full bin light even when it's empty. Tried cleaning the eye near the feed area with canned air as per recommendation by a shredder maintence...
    There are also sensors under the shredder head to indicate when the bin is full. You either have a defective sensors or a dirty one (clean with air).
    Aug 29, 2011 | Fellowes 2200SC Shredder
    I can't reset a fault named "wax empty" and my equipment doesn't work life fitness 9100
    hit the stop button and hold down pouse key until the counsel repowers up and tougle throug to mantinace enter then tagel throug to waxer refill and hit enter
    Aug 13, 2010 | Life Fitness 9100 Next Generation...
    I have a life fitness treadmill and put new wax in the blader how do i start the machine and put wax on the belt?
    you will need to go into service menu by pressing and holding the pause button then pressing the clear button twice , continue holding the pause until the service menu appears. then use the arrow up and select maintenance press enter then either use arrow up or down scroll and say refill waxer system or replacing wax bag press enter, this will reset upper console. Upon completion of this the go back into the diagnostic menu select system test press enter scroll up or down to waxer manual mode hit quick start and that will fire up the wax pump and your done
    Apr 12, 2010 | Life Fitness 9100 Next Generation...
    Treadmill wont run its saying waxer empty and notify maintainence
    Feb 07, 2010 | Life Fitness 95Ti Remanufactured Treadmill
    Empty cartridge
    HP Deskjet 3915 Inkjet Printer.
    Empty cartidge status is related to the refilled catridges.
    Please do not use any refilled cartriges in the above printer.
    There is a chance of leakage of ink as a result the entire printer will not work properly.
    Buy genuine HP Catridges and install the same in the printer.
    If the problem still persits, please lodge a complaint with local HP office and get the cartidge is replaced with a new and genuine one.
    Try to make user of Annual Maintence serice contract with local authorized ho Vendor for regular servicing of this printer.
    Jul 16, 2009 | HP Deskjet 3915 InkJet Printer
    2 red lights flashing service required
    press maintence power and the small ink button all at the same time this will reset the printer
    Apr 05, 2009 | Epson Stylus 2200 InkJet Photo Printer
    Life Fitness 95Ti Treadmill 95 Ti Logo
    69 people viewed this question
    Top Life Fitness Exercise & Fitness Experts
    Howard
    Howard
    Glenn Mayer
    Glenn Mayer
    Craig Butler
    Craig Butler
    Are you a Life Fitness Exercise and Fitnes Expert? Answer questions, earn points and help others
