Question about Samsung HL-R5656W 56" DLP HDTV
Tv will not turn on
Replaced the lamp. All three lights on lcd will not even turn on everthing is out.
    Scholar:
  • 59 Answers
Check to see if there is a problem with the internal fuse. Your user manual should have a troubleshooting section that will address your particular symptoms.
You should also plug a different appliance into the outlet where your TV is plugged in to make sure there isn't anything wrong with the outlet.
Though this probably isn't the case, I have sometimes seen outlets that are controlled by a wall switch, and sometimes, the wall switch is accidentally turned off.
Posted on Jun 20, 2009
Heard a pop , bulb blew out , replaced bulb , it worked for two days , now red light blinks three times pauses then three times and so on , tv won't turn off light won't turn off unless I unplug...
3 blinks indicates lamp door is not on or has not been reinstalled properly. This also could mean the lamp door switch has failed itself. Try removing the lamp door and putting back on, if that doesnt correct the problem then I recommend having the switch replaced.
Oct 26, 2011 | Sony KDF-E42A10 42 in. LCD Television
I have a Sony KDF-60XS955 tv. It won't power on,
I have that manual. There are three lights to the left of the power button. One is labled LAMP. The manual states "The projection lamp, which illuminates the picture, has a limited life. If the screen becomes dark, the color looks unusual, or the LAMP indicator on the front of the LCD projector TV flashes, it is time to replace the lamp with a new one (not supplied). Use a Sony XL-2200 replacement lamp (not supplied) for replacement. Use of any other lamp may damage the LCD projection TV." I also found in a different page " LAMP LED lights up in red when the lamp for the light source has burnt out." I guess burnt out would be extream. I found one other if you had opened the light bulb cover and didn't close it properly. " If the lamp cover is not reattached securely, the self-diagnostic function may be triggered and the POWER/STANDBY indicator flashes three times." You can down the sony manual at http://www.docs.sony.com/release/KDF60XS955.pdf
Jun 02, 2011 | Sony Grand WEGA KDF-60XS955 60" Rear...
The power/standby light blinks red three times pauses then repeats on my Sony KDF-E42A10 TV... no power Thanks
Please make sure lamp cover is fixed properly as it was removed to replace/ check lamp in tv.
If lamp cover is not fixed, tv will not turn On and red light will blink 3 times.
Thanks.
Apr 28, 2011 | Sony KDF-E42A10 42 in. LCD Television
Sony model#kdf50e2000.turned it on a few days ag0 heard a few clicks, green light come on a few times then it gives me three red blinks stops then three red blinks again and again.no sound no picture.i...
Your lamp door switch or lamp switch (there are 2) may not be fully engaged or one may have failed. Try seating the lamp again, you may not have it fully installed.
Mar 17, 2010 | Televison & Video
Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
Sep 01, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
46 inch projection lcd, says tempature is to hot at bottom of scr
If you replaced TV lamp recently then check lamp cover and make sure to seat it properly.
Need further info, let me know.
Jul 02, 2009 | Zenith E44W46LCD 44" Rear Projection...
TV won't turn on after lamp was replaced
Check the switch on the lamp door. Listen for the color wheel to spin. if the door switch is bad the lamp wont come on, samething if the color wheel is bad.
Jun 16, 2009 | Hitachi 50V500 50 in. HD-Ready LCD...
I have a Panasonic 50" LCD TV PT-50LC13 and the power botton blinks orange 2 time and there is no pic but i can here the fn runing what can i do???
if the tv keps trying to turn on three times and later the lamp led stays steady red. (see owner's manual to replace the lamp process) the lamp is damaged. ones you open the lamp door and take the lamp out you can see the lamp damaged even before to buy it.
Apr 08, 2009 | Panasonic PT-50LC13 50" Rear Projection...
My 60" lcd projection tv wont turn on sometimes and throws a lamp light, and if i watch tv for a while and turn it off it wont turn back on and throws the red lamp light
The buzzing sound you most likely hear is the ballast trying to fire up the lamp. I would say replace the lamp and yes they can act up at will. If this is the first lamp replacement ever then you are doing good.
Feb 01, 2007 | Hitachi 60V500 60" Rear Projection...
Samsung HL-R5656W 56" DLP HDTV Logo
103 people viewed this question
Jerry Greenberg
Jerry Greenberg
