Question about LG LMX25981ST Stainless Steel Bottom Freezer French Door Refrigerator
My refrigerator recently had the condenser replaced and since than it works great for a few weeks up to a few months and than stops cooling for a few to several hours. The top freezer will get up to 4
Help
SOURCE: Really Noisy
I have the lrfd22850, 2 years old.The computer has burned out 3 times and we are now waiting for the fourth.We need new gaskets as they rub on each other due to the french door design. The ice maker won't stop becase the shut off arm falls under the first batch and keeps going.The lights constantly burn out{not the bulbs!} The latches keep breaking on the doors. Lg said after the warranty its not their problem. WILL NEVER EVER BUY LG again!!!!!The customer service is lousy and they are very condescending, apologetic and apathetic.
Posted on Jan 09, 2008
  • 1314 Answers
SOURCE: Brand new refrigerator not cooling
ok what he was trying to say is that the freezer does all the cooling for both sides as nothing in the fride side cools and in order for the fridge to reach its proper temp the freezer should run any where between -0 to-10 then the fan in the freezer draw-es air from the fridge and cools it and circulates to the fridge now i need to know a few things is the compressor running is the freezer fan running do you see any frost on the back wall of the freezer section is the fan running in the back that's near the compressor to cool the condenser coils then i can better advise pleas hold my rating till we are done where did you purchase the unit
Posted on Jul 22, 2008
  • 489 Answers
SOURCE: Ice maker stopped after electric shutoff
You may have a problem with the computer control board in the ice maker.  Try this.  Turn off the icemaker for about 2 minutes.
Turn on the ice maker and press the clear button.  Press and hold this button for 12 seconds to get it to force extract.  This will confirm that the motors will work and push the ice cubes out.  Afterwards, let it run by itself.  If it still doesn't make ice, you will need to replace the icemaker.
Posted on Sep 30, 2008
SOURCE: Error Code ER FF
I had the same problem. I can tell you that simply unplugging the fridge and letting it defrost isn't going to work. You need to get take it apart.
I had the Er FF code about 2 months ago and let the freezer defrost for a couple hours and it started working again. Then two days ago I got the error again. This time I decided to get inside there.
First and foremost, UNPLUG the fridge and TURN OFF the water!
Next empty everything out of the freezer and start taking it apart. You have to get everything out of it to get that back panel off. This includes the ice maker and the rails that the drawers slide on.
Now that the freezer is completely empty there are two screws that hole the back panel on. In my freezer one is a white screw high in the center and one was a gold screw in the little panel that the ice maker hooked up to.
Next grab the back panel by the little fins on the top of it in the middle. Give it a good firm pull, but take care not to yank it too far... it's still connected by wires back there. When I pulled my panel out I found a HUGE chunk of ice on the top of the panel just to the right of the fan that feeds cold are to the fridge. Get that thing off of there taking care not to damage the foam insulation and watch those shiny metal fins that are behind the panel.
While you're putting it back together try to dry everything off as much as possible (I tried see the bright side of the whole evolution and realized I could really clean my freezer).
Once it's all put back together plug that baby in, turn on the water, and enjoy the next four hours as it gets back to being cold.
I'd say you need moderate tinkering skill to do this. If you only own one screwdriver and you never use it you should probably call someone.
Hope this helps!
Posted on Apr 21, 2009
  • 7 Answers
SOURCE: LG french door with non working ice maker
Similar problem. Occasionally my ice maker goes on the fritz. Usually I can turn off the ice maker and place a piece of newspaper over the freezer holes for overnight and it starts making ice when I turn it back on. This time that didn't work so I unplugged it this morning for 3 hours and put all the stuff in coolers. I opened all the doors and removed the freezer bin (just the bin maa'm, not the frame) so I was sure the water lines inside the fridge doors and sides would unfreeze. Plus side is the Fridge got a good cleaning. I just heard my first ice drop about a 1/2 hour ago.
Posted on Sep 08, 2009
U-Line 75FF Bar refrigerator stopped cooling
it could be a problem start/run capacitor for the compressor or compressor failure
get a fridge technician in to test and get a quote
Most small fridges are cheaper to replace than repair
Jan 09, 2016 | U-Line Refrigerators
I have a kenmore elite frig that just stopped working not cooling at all it is only 13 months old
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Sep 08, 2011 | Kenmore Refrigerators
I have a Jenn Air JCD2289AEW side by side refrigerator. The freezer has not been cooling properly for a few days. Now the refrigerator seems to be maybe less cool than it should be. I still get cold air...
heatman101
Jul 16, 2011 | Jenn-Air JCD2389G Side by Side...
Model 685 Manufactured 02/04. EC 08 20 40 50. For a few months power off/on resolved the issue for a week but recently fridge side not keeping its cool. Freezer seems good. No condensation in fridge. ...
More than likely the control board in the refrigerator section has failed. The only thing that would cause this issue it a control. The breaker reset was only resetting the software in the control board.
Replace the board on the side and it will fix this issue.
Apr 13, 2011 | Sub-Zero 690 Side by Side Refrigerator
GE PTS22LCR (top freezer) will periodically stop cooling almost entirely. Leaving it unplugged several hours then plugging back in seems to fix the problem, at least for several weeks to a few months....
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
heatman101
Nov 26, 2010 | GE PTS22LCR Top Freezer Refrigerator
Compressor seems really hot. Had clicking sounds in my unit, but it was still cooling. Last week it stopped. I replaced the motherboard and it worked great for 2 days. Now it stopped cooling well. ...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
It sounds like you have a small leak in the refrigeration system and that your unit is low on freon...
.there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then…
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
heatman101
Sep 12, 2010 | GE Profile 22.2 Cu. Ft. Bottom-Mount...
Avanti WC42, stopped working. Compressor (ZEL GVY40AD) is warm and tube going to radiator is very cold. Digital dash has been blinking with err for a few months but was cooling ok.
As the weather is getting warmer for many people their freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong. If you are hearing a clicking or buzzing then check out the last two tips.
heatman101
Aug 27, 2010 | Avanti WC42 Wine Cooler
GE- GTS22WC refrigerator. Both the refrigerator and the freezer stopped cooling, We put it in the basement thinking it was no good, and after a few months we plugged it back in and it worked ok for about...
The auto defrost heat element is not working. When the ice buildup clogs the airflow the unit stops cooling. Once you unplug it and give it a chance to melt it works again. You need to have the defrost unit replaced.
Jun 27, 2009 | GE GTS22KBP Top Freezer Refrigerator
Refrigerator stops getting cold
Hi!!! You seem to have a bad defrost timer.Just replace the defrost timer. Good luck..Look for frost on the freezer section back panel..Its a sign of a bad defrost timer..
Jan 03, 2009 | Kenmore Refrigerators
LG LMX25981ST Stainless Steel Bottom Freezer French Door Refrigerator Logo
24 people viewed this question
Top LG Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a LG Refrigerator Expert? Answer questions, earn points and help others
