Question about Epson Workforce 610 All-In-One InkJet Printer
Epson workforce 610 will not print with black ink unless photo paper is selected in the printing preferences. How do I get it to use black ink on plain white paper?
Epson workforce 325 printing blank with black ink
The print head is plugged up. Try the nozzle check function or the clean function on the control panel.
Oct 07, 2016 | Epson WorkForce 325 Inkjet Multifunction...
Correct setting for Epson Workforce 7520 printing on gloss paper
You need to start with photo glossy paper that's designed for an Epson printer. HP paper may not work well, and some other papers don't work either. Try some Epson paper, and that should work fine.
You can also try other paper settings, such as "transparency" or "matte paper", as the paper setting governs how much ink is laid down. I think getting the right paper is really what you need, though. Ink "puddling" is a common Epson complaint, and it's almost always the paper.
Nov 02, 2014 | Epson WorkForce WF-7520 Wide Format...
Why is my printer in error state
Can you Clarify which type of error are you facing ?
Sep 21, 2014 | Epson Workforce 610 All In One Inkpr...
Black printing is fuzzy. No sharp edges. Tried OEM cartridge and third party cartridges. Same thing on all.
Sounds like your printer hasn't had the printhead aligned so worth using the printhead alignment function in Printing preferences > Maintenance to sort that out.
While OEM cartridges are unlikely to experience the same problem if alignment was successful, it could be the compatible ink is lingering in the nozzles and needs to be flushed through with OEM inks to get crisp output.
Finally, consider using a different paper to see if your paper is more the issue than the ink.
Aug 05, 2013 | Epson Workforce 610 All-In-One InkJet...
Epson workforce 610 printing improperly
have the printer being discussed in this thread.... the Epson WorkForce 610. I just encountered the same issue, many lines were missing from the page that I wanted to print. Ink levels were fine, but every time I try to print the same thing, the same lines were missing. I read through the solutions mentioned above and I decided to see what the printer had in its maintenance toolbox on the printer itself.
Here's a solution that worked for me!
1. Go to "Setup"
2. Under Setup, select "Maintenance"
3. Select "Head Cleaning"
The printer does the head cleaning automatically. Print another page, all of the lines should show up!
Simple, no need to buy another printer or clean the ribbon...
May 01, 2012 | Epson WorkForce 600 All-In-One InkJet...
I have a Epson Workforce 600 printer. Changed all ink cartridges and cannot get the black ink to print. It will print in color mode only without the black ink. What should I do? Sandy
Hello Jaasp,
Follow these steps to print the nozzle check:
  1. Load a few sheets of plain paper in the sheet feeder.
  2. Press the Home button.
  3. Press cp_button_41_er.gif or cp_button_42_er.gif to select Setup.
  5. Press OK.
  6. Press cp_button_41_er.gif or cp_button_42_er.gif to select Maintenance, then press OK. You see this screen:
  8. Select Nozzle Check, and press OK.
  10. Press cp_button_6.gif Start to print the nozzle check.
  11. Shown below are some examples of what the nozzle check may look like.
    Nozzle check pattern with no gaps
    Nozzle check pattern with gaps
  12. Press Finish Nozzle Check and press OK when you're done.
Jun 18, 2011 | Epson WorkForce 600 All-In-One InkJet...
Keeps saying paper jamed when I try to print
On the Epson website it is confirmed that the Epson WorkForce 610 will not recognize transparency media. It is just the way the printer works; if it can see through the media, it doesn't think it's there.
However.....you can tape a sheet of white paper to the non-printable side of the transparency, and it prints just fine. I put two strips of scotch tape on either side, top and bottom. Works great. It's kind of a hassle, but better than not being able to print transparencies at all!
Jul 22, 2010 | Epson Workforce 610 All-In-One InkJet...
I replaced my ink cartriges and I'm still have a blurr and fade on documents that I print.
  1. Open your application program.
  2. Select Print from the File menu. A Print window appears.
  3. Make sure EPSON Stylus CX9400Fax Series is selected.
  4. Click the Preferences or Properties button. (If you see a Setup, Printer, or Options button, click it. Then click Preferences or Properties on the next screen.)
    A printer properties or preferences window appears.
  5. Select the type of document you're printing for the Quality Option setting.
  6. If you want to print borderless photos, click the Borderless checkbox.
  7. Make sure you've selected the paper type and size you're using for the Type and Size settings in the Paper Options section.
  8. Click the Advanced button. The Basic settings change to the Advanced settings.
  9. Make sure the High Speed option is not selected in the Print Options section.
  10. Make sure the Black Ink Only option is not selected in the Print Options section if you're printing a color or black and white photograph.
  11. Select ICM in the Color Management section if you're trying to precisely match on-screen colors.
Jan 18, 2010 | Epson Stylus CX9400 Photo Printer
Epson R2880 trying to change matt black to photo black
There are many solutions posted already - what I do is in photoshop i start to print - even though I cant select the paper I want because the wrong ink is recorded - and I click print preview... then click print. The epson drivers tries to print, THEN detects the NEW ink and sends me back to selecting the paper with the new ink properly sensed. I hope this helps.
Keith
Feb 01, 2009 | Epson R2880 InkJet Photo Printer
Epson Workforce 610 All-In-One InkJet Printer Logo
21 people viewed this question
Top Epson Office Equipment & Supplies Experts
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
